Need crank pinning kit
Old Sep 24, 2009 | 06:05 PM
Rdrcr's Avatar
Rdrcr
Cruising
Default Need crank pinning kit
Where can I purchase a crank pinning kit? What's the cost?
Old Sep 24, 2009 | 06:14 PM
lucky131969's Avatar
lucky131969
A&A corvette.
Old Sep 24, 2009 | 07:08 PM
vettenuts's Avatar
vettenuts
ATI? Which type of kit?
Old Sep 24, 2009 | 07:50 PM
sami85L98's Avatar
sami85L98
there are 2 types most common, one u drill hole from front usually to stock balancer, and another to drill from side for SLP, PB, aTI....may some more.
I have a brand new magnuson kit, which is good for pinning stock balancer and drill from front, see how to intsall manual online at magnuson.com for installling maggie SC on a C5 vette.
will do $55 shipped to your door. LMK
Old Sep 25, 2009 | 10:07 AM
SDPC's Avatar
0SDPC
Former Vendor
The 1st (that he has for sale) is the easiest type if everything is installed, as you don't have to pull the steering rack and balancer to do it.
Old Sep 25, 2009 | 12:29 PM
HinsonSuperCars's Avatar
0HinsonSuperCars
Former Vendor
From: Birmingham, AL www.hinsonsupercars.com 205-909-9402
ATI Crankshaft / Harmonic Balancer Pinning Kit $136.99
In stock.
Seth
Old Sep 25, 2009 | 01:30 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I used/borrowed the ATI Crankshaft / Harmonic Balancer Pinning Kit from a buddy.
It was OUTSTANDING!
I installed a Power Bond damper and it has a machined slot for the side pin machined in it as purchased. If the damper that your using does NOT have a machined slot for the side pin, use the front pinning kit.
Old Sep 25, 2009 | 04:17 PM
vettenuts's Avatar
vettenuts
The only thing I don't like about the front drill kit is if later removal/re-installation is required. Seems that would be a bugger to line up again or you end up re-drilling.
To Need crank pinning kit
