Low torque numbers
Old Oct 26, 2009 | 03:53 PM
11sec_C5Z51's Avatar
11sec_C5Z51
Default Low torque numbers
My buddies C5 w/ prc ported LS6 heads, MS3 237/242 114 lsa, FAST 90, LS2 90mm TB, LG Street headers and tune did 440rwhp 382lbs-ft tq through the stock clutch setup. Why is the torque so low and how could he get the TQ higher???
Old Oct 26, 2009 | 10:03 PM
ttribe's Avatar
ttribe
I have:
g5x3 (rumored to be 236 / 242 or close to that)
cold air intake
lg street headers, ghl bullets
stock heads, intake, throttle body, etc.
435.7 & 405.7 (thanks to england green tune)
I don't want to start a war, but the first thing i would look at if that were my car is the cylinder heads and who ported them. That stuff is an art/science and there are only a couple of heads i would consider and only a couple people I would let change the port work.
Also the tune. My old tuner had it at around 426/386, EG managed to up those numbers a bit.
Also, if he has 410 gears or something like that, he will show different dyno numbers.
Old Oct 27, 2009 | 08:30 AM
AU N EGL's Avatar
AU N EGL
Cam is too big. Designed for high rpm use not low rpm torque
I have 224/224 581/581 112+4
407 rwhp and 405 rwtq
400 lb feet at 3000 rpms
Old Oct 27, 2009 | 08:48 AM
CTD's Avatar
CTD
The good news is the stock clutch will live!
Old Oct 27, 2009 | 12:13 PM
bryanthomas's Avatar
bryanthomas
What cam do you have? Is it a Lunati?
Old Oct 27, 2009 | 12:16 PM
vettenuts's Avatar
vettenuts
What kind of dyno was used?
Old Oct 27, 2009 | 01:08 PM
AU N EGL's Avatar
AU N EGL
Comp Cam XE-R lobe
normally come with a 114+2 had them do the 112+4
If I do it again, which most likely will I will do a 224/230 581/588 112+4
for more high end HP
http://www.compcams.com/Cam_Specs/Ca...csid=1092&sb=2
Possibly this one, but not sure on the low end torque
http://www.compcams.com/Cam_Specs/Ca...csid=1093&sb=2
other goodies
LS6 intake polished not ported
TPIS 78mm TB pp
my own CAI
TPIS LTs, high flow cats then straight pipes.
3qt accu-sum and oil cooler
Old Oct 27, 2009 | 01:56 PM
Anthony @ LGMotorsports's Avatar
0Anthony @ LGMotorsports
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Can you post a dyno graph up?
There are a couple possibilities.
1. If the car spun the tires on the dyno you would see a spike in HP and a dip in torque this could be part of that.
2. Head to cam match up
3. Cam might be off as well. If it is either advanced or retarded a couple degrees that can throw this off as well.
Old Oct 27, 2009 | 05:05 PM
11sec_C5Z51
I don't know how to post a dyno graph, but could I scan it and email to you?
Old Oct 27, 2009 | 05:23 PM
Former Vendor
Sure can, anthony@lgmotorsports.com
Old Oct 27, 2009 | 08:38 PM
Bill Dearborn's Avatar
Bill Dearborn
We all want to see it. Just scan to a jpg file and save it on Photobucket. Then follow the instructions shown here:
http://forums.corvetteforum.com/help...al-inside.html
It is as easy as falling off a log.
Bill
Old Oct 27, 2009 | 08:46 PM
0331MARINE's Avatar
0331MARINE
From: You know your drunk when you swerve to miss the tree then you realize its your air freshener! Covington Ga
I have the same cam in mine but stock heads (241) and stock LS6 intake manifold and protted TB 412RWHP and I think 366RWTQ. I think you need a re-tune.
Old Oct 28, 2009 | 09:00 AM
11sec_C5Z51
I emailed you the dyno sheet
Old Oct 28, 2009 | 09:27 AM
11sec_C5Z51
When I just had LTs (LG streets), CAI (V-ram) and tune on my '02 C5 w/stock 241heads, stock LS6 intake and stock LS1 cam, I made 351rwhp and 365rwtq. Your torque numbers are low too w/ the MS3. I spoke with Patrick G from Thunder Racing and he said that the MS3 loves high compression. 10:5 comp ratio is too low for this cam and it has a horrible DCR. He said it's an RPM cam and not suited for torque and that it was extremely weak in the low/mid range.
Old Oct 28, 2009 | 11:55 AM
ALVETTE00's Avatar
ALVETTE00
Anthony, can you elaborate on point #3. I've always thought my #'s were on the low side and maybe this is why? See Sig for mods.
Old Oct 28, 2009 | 12:11 PM
Former Vendor
Advancing or retarding the camshaft can move the power band around. If you retard the cam it should move the power band up in the RPM range, conversely retarding it would move it back down.
Of course this is all going to play with how the cam is setup and your over all combo.
Old Oct 28, 2009 | 01:00 PM
AU N EGL's Avatar
AU N EGL
To Low torque numbers
Old Oct 28, 2009 | 01:06 PM
ALVETTE00's Avatar
ALVETTE00
Thanks...maybe a combo of the converter being unlocked, A4 loss and stingy dyno are the cause of my percieved low #'s.
Old Oct 28, 2009 | 01:12 PM
chaase's Avatar
chaase
St. Jude Donor '12
Its an MN6 so there isn't a torque converter issue. A stingy dyno would report everything low. The HP is computed based on the TQ, so everything would be low. Now, if the HP was low too, the dyno could be considered stingy, but that is a pretty big spread between HP and TQ.
Old Oct 28, 2009 | 06:19 PM
ALVETTE00's Avatar
ALVETTE00
FYI...was referring to my personal sidebar...not the orig post!
