Is 400 RWHP possible on stock 243 heads?
Old 01-30-2010, 08:03 PM
chrisbenoit
chrisbenoit's Avatar
Default Is 400 RWHP LS1 possible on stock 243, Z06 heads?
I have a 99 FRC. I am thinking very hard on going heads and cam in the near future. Like the title says i'm looking to get 400 RWHP, on an LS1. Is this possible on 243 heads, not CNC, just stock ones? If not what is the most they will produce? I have a LS6 intake, long tubes, CAI, etc. 400 HP is pretty mild compared to some on here but i'm on a budget and 400 is a number I think I will be pretty happy with.
Also, how big a cam would I have to go with?
Any insight good or bad is appreciated. Thanks.
Old 01-30-2010, 08:12 PM
Pete W
Pete W's Avatar
I've got a dyno from ECS from my car that says I have 400 rwhp. My car has their cam package with long tube headers, borla exhaust,and other typical bolt ons. With heads and Fast intake guys are making over 500! Hope this helps.
Old 01-30-2010, 08:41 PM
black98c5
black98c5's Avatar
It's possible but you'll need a decent size cam, something in the range of a 23x/23x.
Old 01-30-2010, 09:02 PM
chrisbenoit
How do you think this will affect my driveability? I don't race often, and I still need to be able to drive on the street. I don't mind a lopey idle, I actually would like that .
Old 01-30-2010, 09:08 PM
Y2Kvert4me
Y2Kvert4me's Avatar
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Some Z06 owners have hit 400rwhp with just bolt ons (stock heads and cam).
Although that's not exactly the norm, the point is you don't need a huge cam to pull it off.
If concerned about drivability, a nice little 224/228 or so should easily do it for you, and be very easily drivable with no bad manners.
Old 01-30-2010, 09:13 PM
printmanjackson
printmanjackson's Avatar
St. Jude Donor '06-'07-'08-'09
you can get there easly with 243 heads and a good mild cam. Look for a cam in the 225-230 duration with @ .600 lift and you will be fine.
here is an example
http://www.ls1tech.com/forums/dynamo...is-tuning.html
YeloFevr
YeloFevr's Avatar
Do '99 FRCs have 243s??
Old 01-30-2010, 09:15 PM
0Shawn @ Va Speed
Former Vendor
Shawn @ Va Speed's Avatar
400rwhp is fairly easy for a set of 243's.We have made 407rwhp with a bolt on 03Z06,been in the mid to high 420rwhp range with mild cam Z06's
Old 01-30-2010, 09:16 PM
black98c5
black98c5's Avatar
Drivability is all in the tune. As far as the lope goes, a cam on a 112 lsa will chop pretty good.
Old 01-30-2010, 09:24 PM
Y2Kvert4me
Y2Kvert4me's Avatar
St. Jude Donor '03
No, it would have come with 853 castings.
Old 01-30-2010, 09:35 PM
Quick 68
Quick 68's Avatar
I made 443whp on bone stock heads and a healthy cam. 400whp is very possible
Old 01-30-2010, 09:43 PM
0331MARINE
Support Corvetteforum!
0331MARINE's Avatar
Location: You know your drunk when you swerve to miss the tree then you realize its your air freshener! Covington Ga
413RWHP with 241's heads and a 237/242 cam. 243's would be easy
Old 01-30-2010, 10:10 PM
~Josh
Banned Scam/Spammer
~Josh's Avatar
Received 1,319 Likes on 788 Posts
400+rwhp is no problem, but getting torque #s to match isn't as easy.
Guys with mid-400hp and barely cracking 400tq is common.
Old 01-30-2010, 11:03 PM
printmanjackson
so you first say tq to match isn't easy but then you say its' common?
what does that mean?
the OP asked if 400 RWHP is possible with 243 heads
Old 01-31-2010, 03:55 AM
chev03SSR
chev03SSR's Avatar
i'm thinking ~joshua meant that making about 450 hp and BARELY ~400 tq is common...not that it's common to match hp/tq w/ 243 castings....rather it would be rare to see tq matching hp with the stock 243 castings and a cam. i have been wrong before though.
Old 01-31-2010, 05:54 AM
~Josh
Banned Scam/Spammer
~Josh's Avatar
^ correct.
Old 01-31-2010, 08:02 AM
AU N EGL
AU N EGL's Avatar
We are real close.
Old 01-31-2010, 10:37 AM
The Wrench
The Wrench's Avatar
Chris, we just made 381 RWHP with stock lS1 heads and a baby torque cam 216/220. Just bolting on a set of 343 heads would probably net right at 400 with that combo. Want more HP and less low-end torque, use a bigger cam.
DG
To Is 400 RWHP possible on stock 243 heads?
Quick Reply: Is 400 RWHP possible on stock 243 heads?
