Ls1frc is getting upgraded
Old Jun 15, 2010 | 09:17 PM
Greg_E's Avatar
Greg_E
Originally Posted by stryderss
why would i want to do the trunion upgrade? I have 42lb injectors going on for got to add that one.
The stock rockers on your '99 can spill the rollers into your engine. If your lucky, they just find their way to the bottom of your oil pan. Either upgrade the trunions, or get the Yella Terra Ultralight rockers.
You're upgrading the pushrods correct?
Those injectors are bigger than you need for the mods you listed, but as long as they can tune it, they should be fine. I think you will do better than 410 HP. With similar mods, and a much smaller cam (LPE GT2-3), mine made 403 HP.
There were some threads regarding the use of underdrive pulleys as being the cause of some engine failures. I think it was something about certain brands of underdrive pulleys not doing the job of dampening the harmonic vibrations. I'm not sure what that was all about, but you might want to research it just to be sure. I love it when people tell you not to do something with no explaination why!
Good luck with your project.
Old Jun 16, 2010 | 10:22 AM
stryderss's Avatar
stryderss
cool i wil look into it
Old Jun 16, 2010 | 10:39 AM
amidei's Avatar
amidei
Upgrade your gears to 3.42
Old Jun 16, 2010 | 08:19 PM
Greg_E's Avatar
Greg_E
Here's one of the threads discussing underdrive pulleys as the possible root cause for timing chains breaking. There are others. Do a search on underdrive pulleys and harmonic balancers in the tech section.
http://forums.corvetteforum.com/c5-t...eas-why-2.html
Old Jun 16, 2010 | 08:43 PM
alxltd1's Avatar
alxltd1
St. Jude Donor '10-'12-'13-'14-'15-'16-'17
He has a 6 speed so he should already have the 3:42 gears as standard.
Old Jun 16, 2010 | 08:47 PM
jonnyc's Avatar
jonnyc
i highly doubt you'll pass smog with that cam.
i always suggest getting a 2 piece timing cover.if you ever want to change the cam again it will pay for itself in the time saved in doing the swap.even if you do your own swap.
Old Jun 17, 2010 | 02:41 AM
stryderss's Avatar
stryderss
99 frc with z51 which includes 3.42 gearing
Old Jun 17, 2010 | 02:45 AM
stryderss's Avatar
stryderss
its all in the tune, but like i said before im not worried about it. as long as i can pass the sniffer i will be good when that time comes around again.
Old Jun 17, 2010 | 08:50 PM
jonnyc's Avatar
jonnyc
it's actually more about overlap.
biggest cam i've heard passing the sniffer was a 228/228 114lsa.and he said it barely passed and spent alot of time tuning it.
i've known 2 people not pass with the 224/224 112lsa cam.
Old Jun 18, 2010 | 12:24 AM
stryderss's Avatar
stryderss
my car is registered in colorado so california emmisions dont mean squat to me. when i smogged my car i was way way way below average. on another note i haven't been able to do much to the car the last couple days since i am recoverying from surgery.
Old Jun 19, 2010 | 12:04 AM
stryderss's Avatar
stryderss
heres a couple of pics of where i am now and whats going on. I had surgery 2days ago and am forced to chill on the couch with beer in hand lol. not really using a how to just going at it. but once it goes back together i will be using alot of the how to's.
Old Jun 19, 2010 | 05:15 AM
stryderss's Avatar
stryderss
any opinions on my ptv clearence? heads are prc2.5 ls6 castings, and the cam is a 228/232 114+4 i will check anyway just wouldn't mind some others input. i am using the gm mls head gaskets
Old Jun 22, 2010 | 12:35 AM
  #33
stryderss's Avatar
stryderss
any opinions on my ptv clearence? heads are prc2.5 ls6 castings milled to 62cc, and the cam is a 228/232 114+4 i will check anyway just wouldn't mind some others input. i am using the gm mls head gaskets
im gonna bump this Question since im still at a stand still from surgery
Old Jun 22, 2010 | 04:38 PM
  #34
MVP'S ZO6's Avatar
MVP'S ZO6
ISIS SUCKS FAT CHOAD
Ok luke Lookin good buddy. Chances are you wont have PTV clearance issues with your current setup even with your current combustion chambeactill good prr size. However, its still good practice to check and it dont take that long to check. Then again if you dont check another way (more expensive way) is to put the whole car back together get it up to normal operating temp and the first on ramp you see pull that ****er to redline from second to 4th If after all that you dont hear any really abnormal noises and you do a quick compression check and everything checks out, chances are your clearances are good to go Of course I dont condone or endorse that method but what ever works for u i guess. lol
FOR GOSH SAKES CHECK THE PTV WITH CLAY AND A DIAL CALIPER OR RULER IF YA WANT TO GO THE CHEAPER ROUTE
Old Jun 22, 2010 | 10:21 PM
  #35
stryderss's Avatar
stryderss
thanks for the support. i havn't found a good i mean good how to for doing the ptv check i mean pics and the clay and all lol. would be nice if you would come down and give me some help lol
Old Jun 22, 2010 | 11:06 PM
  #36
MVP'S ZO6's Avatar
MVP'S ZO6
hey dude to hell with that GM crossover tube for the LS6 intake just get rid of all those fins on the bottom of the intake. Yes I know what they're for you ante gonna hurt anything. then sell that cross over tube thing and make your money back. (J/K whwhat ever floats ur boat) you know ill be down when I can. I have some of those comp cams checker springs if you wanted to remove your stock valve springs to check ptv clearence... google or you tube i know for a fact theres a good U tube video on checking PTV clearence.
HERE YA GO BUDDY! http://www.youtube.com/results?searc...clearence&aq=f
Old Jun 22, 2010 | 11:16 PM
  #37
stryderss's Avatar
stryderss
sweet thanks buddy, yeah im gonna take those stockers out. but wouldn't those checker springs have to go on the new heads?
To Ls1frc is getting upgraded
Old Jun 26, 2010 | 01:20 PM
  #38
stryderss's Avatar
stryderss
well i can use the stock coolant tubes with the fast intake i have i just need to smush it down a little. i think i will keep it though. well an update I finally got the steering rack out, the powersteering pump was kind of a pain in the *** i finally realized that you had to undo all 4 mounting bolts at the same time cus that damn pulley gets in the way. thats all i got done last night i only had about an hour to spend so i thought i did that pretty fast. I am gonna spend alot of time like vsocks1 did cleaning everything up 90000 miles will make an enginebay really dirty. I have duty today so maybe i can get a couple of otherthings done tomorrow night.
Old Jun 26, 2010 | 10:28 PM
  #39
stryderss's Avatar
stryderss
heres a question..... I have a 85mm MAF is it worth swapping the stock LS1 and the LS6 MAF?
Old Jun 28, 2010 | 09:44 PM
  #40
Greg_E's Avatar
Greg_E
If you already have an 85mm screened MAF there is no need to buy a LS6 screenless MAF. My understanding is that the two have a slightly different calibration, but if you want to run a screenless MAF the screen can be removed, and your tuner can make the necessary adjustments.
I don't know how much the screen affects airflow, but depending on your choice of CAI, it can be benificial. Too much turbulence across the sensor can result in inaccurate measurements and codes being set.
I'm not certain, but I think all the newer gen engines have a screened MAF, so GM obviously thinks that's a better way to go.
Edit:
Your profile says you have an '99 FRC which had a 78mm MAF, so I assume you already upgraded to an 85mm MAF at some point.
