Harmonic balancer bolt
Old Jul 28, 2010 | 09:25 PM
00Corvette's Avatar
00Corvette
oh forget everything i said then...LOL
calibrated impact...LOLOLOL
Old Jul 28, 2010 | 09:27 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
BACK IN BEFORE THE LOCK!!!!!!!!!!!:lol :
Old Jul 28, 2010 | 09:33 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Originally Posted by brit2001
Bill,
When I did my cam I just slid it to the passenger side of the car. I have a new AR bolt coming. I was just wondering if you could lift the rack high enough to get the bolt out and the new one in. I have a Torque wrench that goes that high.
BRIT
Try the bolt replacement in the least complicated and least involved steps first. There are some good tips here. Never thought of lowering the K member!! Just unbolt the rack mounts and pic up on it. The wheels will point INWARD but that wont hurt anything. Just point them back straight before you reconnect the steering shaft.
BC
Old Jul 29, 2010 | 12:37 AM
Josh@SpartanLSX's Avatar
0Josh@SpartanLSX
Former Vendor
Just for the record, the stock bolt can be reused. I've been building LSX engines for 10+ yrs, and based off that experience (opposed to just reading the internet) I've found that they can in fact be reused in a pinch. I've never done it on a customers car, but reused them on my own using loctite and leaving them put at the 250 ft lbs TQ setting.
Now, I wouldn't recommend using an impact gun such as Mr. Whistler suggested, but it can be done.
Old Jul 29, 2010 | 01:07 AM
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
Originally Posted by Whistler
I'm no hobbyist. I watch every episode of Horsepower TV and read at least five magazines a month, as well as all the internet writeups.
Now that's an expert with qualifications
Old Jul 29, 2010 | 01:20 AM
lionelhutz's Avatar
lionelhutz
I think people still don't get it.
You can do whatever you want on your own car.
GM recommends replacing the stock bolt and not re-using it. Do not be a self proclaimed expert and say that GM is wrong. You are not the one that has to fix the car when re-uisng the old bolt goes wrong. It may only happen once every 1000 times but the person who read your "expert" advice and followed it is the one that just got screwed by it, not you.
Peter
Old Jul 29, 2010 | 01:23 AM
00Corvette's Avatar
00Corvette
Just for the real record...GM has build thousands of these engines. they recommend you swap the stock bolt. i'm not saying it won't work in a pinch..of course it will but for how long? do you want to find out? over 14 bucks? Just run your old bolt for awhile then...but don't recommend to this guy to leave it in there over torqued with lock tite? WTF man?
Old Jul 29, 2010 | 05:11 AM
vettenuts's Avatar
vettenuts
Peter
Its sort of like the expert advice on LS1howto.com that has resulted in numerous damaged crank threads
Old Jul 29, 2010 | 07:50 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
He hasn't spent a night at a Holiday Inn Express. He's still on the "learning curve".....
Old Jul 29, 2010 | 08:52 AM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
Interesting thread on how to save a $14 bolt with a high risk if damaging or distroying thousands of dollars of other parts, like a crankshaft. I guess this makes cents to some folks. I'm not so much into saving a $14 bolt, but hey, your car, you need to do what you feel is right....I guess.
Old Jul 29, 2010 | 09:41 AM
0Josh@SpartanLSX
Former Vendor
If you guys are paying $14-20 for a crank bolt then you're shopping at the wrong dealership.
Old Jul 29, 2010 | 10:59 AM
brit2001's Avatar
brit2001
Originally Posted by legman
The ARP should cure your loose bolt problem.....
I would check with them about the correct torque spec. At one time it was 240lb's and thats what alot of people use but I think ARP has since lowered it to 190.
I would double check with them to be sure.
Will do. Going to pull the rack tonight.
Old Jul 29, 2010 | 12:38 PM
  #33
lionelhutz's Avatar
lionelhutz
Good luck. Personally, I would try lowering the cradle first unless You think just undoing the 2 rack mounting bolts and lifting the rack will get you enough clearance. I've been into mine but it was leaking and needed to be replaced so I didn't really look at how much clearance there was with it partly removed.
Peter
Old Jul 29, 2010 | 04:04 PM
  #34
printmanjackson
Scroggin-Dickey sells a nice re-usable crank bolt for $22
http://sdparts.com/details/sd6621
Old Jul 29, 2010 | 09:50 PM
  #35
Eric D's Avatar
Eric D
I think it is about time this thread gets locked down, it is getting far too silly!! JMHO
Old Jul 29, 2010 | 09:53 PM
  #36
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
YEP! The funs all used up and it going SOUTH quickly!
Old Jul 29, 2010 | 10:00 PM
  #37
lionelhutz's Avatar
lionelhutz
My girlfriend's ex-boyfriend is the assistant manager at Tuffy Auto Center, and he showed us how to find out the torques. If it's rated at 500 ft-lbs, and the dial does from 1-10, then each notch is 50 more ft-lbs.
So for spark plugs you just use the 3/8 impact, and dial it down to 2.
And for the balancer bolt, you use the 1/2 drive impact and put it on 5. You can either use red loctite on the threads or just tack weld the balancer on if the bolt breaks off once you get it tight.
This must be a joke...
