Harmonic balancer bolt
Old Jul 27, 2010 | 11:28 AM
brit2001's Avatar
brit2001
Default Harmonic balancer bolt
My question is can the bolt be replaced without removing the steering rack from the car. Can the rack be lifted enough to remove old bolt an intall new one. I have done a cam on my car so I know how to remove the rack for that process. My bolt loosened for some reason that is why I'm replacing with an AP one. Thanks in advance.
Old Jul 27, 2010 | 12:50 PM
zeevette's Avatar
zeevette
IN your case, I'd back out the bolt as far as you can, coat it with thread lock, and tighten it back down. Observe it often for a while to make sure it's holding, and don't bother changing it out yet.
Old Jul 27, 2010 | 01:03 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Ive done a cam swap and I have never completely removed my rack. You have to disconnect it and slide it part way out. Then you can slide it towards the front and remove the balancer and bolt.
REMEMBER! The OEM bolt is a ONE TIME USE torque to yield bolt. If it came loose,,,I would replace it. The ARP bolt is reuseable and gets torqued to 240 FT/LBS. I rented the 0-250 torque wrench from Autozone.
Old Jul 27, 2010 | 01:23 PM
brit2001's Avatar
brit2001
Bill,
When I did my cam I just slid it to the passenger side of the car. I have a new AR bolt coming. I was just wondering if you could lift the rack high enough to get the bolt out and the new one in. I have a Torque wrench that goes that high.
Old Jul 27, 2010 | 01:26 PM
brit2001's Avatar
brit2001
I thought about that because of the pain it is to replace it. I drive it daily and have already torn up two belts and a hood liner so I'm leaning towards replacement. Might give it a try though and keep an eye on it. Thanks. Laurence
Old Jul 27, 2010 | 02:57 PM
vettenuts's Avatar
vettenuts
Go to the Magnusen web site. They have installation instructions for the supercharger, the first part of which is removing the bolt and pinning the crank. They do this by dropping the cradle slightly to sneak it out. That "might" be a better approach in your case. I don't think they touch the rack itself.
Old Jul 27, 2010 | 03:01 PM
corvettebob1's Avatar
corvettebob1
DO NOT RETIGHTEN the stock bolt unless you want to remove the broken piece out of the crankshaft!
It is a torque to yield bolt that means it is tightened until it begins to streach.
Old Jul 27, 2010 | 03:04 PM
vettenuts's Avatar
vettenuts
OP is replacing with an ARP bolt.
Old Jul 27, 2010 | 03:31 PM
brit2001's Avatar
brit2001
I'll give it a look. Thanks.
Old Jul 27, 2010 | 03:32 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Already warned...
Old Jul 27, 2010 | 03:33 PM
brit2001's Avatar
brit2001
I have a bolt coming. I only thought for a moment to try and retighten but my mechanical side came out. Too many years as a Jet Mech.
Old Jul 27, 2010 | 09:39 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Originally Posted by Whistler
You can reuse the stock bolt if you don't have a new bolt to replace it with. Coat the first three or four threads with red Loctite, as well as the underside of the head. Use a strong impact with 500+ ft lbs rating and stop when the bolt head stops turning.
This seems to work better for the average hobbyist who doesn't have the flywheel lock tool that bolts in place of the starter, much to the disdain of the internet metallurgical engineers.
More important than replacing the bolt.. don't use either the old or the new bolt to draw the balancer onto the crank. Obtain either the correct Kent Moore installation tool or make your own using a length of 16mm 2.0 threaded rod and a pair of washers and nuts.
Old Jul 28, 2010 | 01:39 AM
00Corvette's Avatar
00Corvette
LOLOLOL
For 20 bucks or whatever, I think I paid full retail for the bolt and it was less than 20 bucks...the peace of mind. Think about what the thing is holding on..ever held a dampner in your hand? They aren't light..
You're advising the OP to take the bolt to twice it's rated capacity with an impact wrench? and how ever many more I can come up with..
The arp bolt is the way to go if you're going to reuse. I'm not even going to get into the stress you put on your threads by over tightening. Do some research before you give someone advice. This isn't a hobby shop
Old Jul 28, 2010 | 02:10 AM
lionelhutz's Avatar
lionelhutz
And just how will that bolt come back out with red Lock-Tite on it?
It's worth doing it right it you're going to do it. And I would agree that the bolt is torque to yield, typical of most torque to yield is the instructions to tighten so far then turn so many degrees. It ~probably~ won't not break but why take that chance?
Now, the brake caliper bracket bolts are an example of bolts GM recomends to change so the thread compound is new on them.
Peter
Old Jul 28, 2010 | 07:35 AM
ipuig's Avatar
ipuig
St. Jude Donor '09
GM requiring a new fastener is a result of the threadlocker they apply to the underside of the head, which is to assist the non-keyed pulley from spinning on the crank snout. It's more of a problem on cheaper aftermarket pullies that lack the interference fit of the OEM unit.
You statement only addresses part of the reasoning for a new fastener. You will not achieve the desired clamping force reusing a previously torque-to-yield fastener using the installation procedure in the service manual. How many additional degrees of bolt rotation do you recommend to achieve the desired stretch and clamping force?
Old Jul 28, 2010 | 02:14 PM
brit2001's Avatar
brit2001
Thanks for all the inputs. I'm going to relace the bolt with a new ARP bolt. I'm not looking forward to removing the rack but I have done it before and it's not that hard. Must be getting soft in my old age. Hope to have the back on the road this weekend. Thanks again for all the inputs.
Laurence
Old Jul 28, 2010 | 04:41 PM
legman's Avatar
legman
Laurence
The ARP should cure your loose bolt problem.....
I would check with them about the correct torque spec. At one time it was 240lb's and thats what alot of people use but I think ARP has since lowered it to 190.
I would double check with them to be sure.
To Harmonic balancer bolt
Old Jul 28, 2010 | 08:48 PM
lionelhutz's Avatar
lionelhutz
I'm no hobbyist.
Self proclaimed expert? Condescending expert?
If you're a pro then you're a perfect example of why everyone should fix their own vehicles instead of trusting the shop.
It's plain stupidity to chance screwing up any chance of successfully taking the engine apart again by red lock-titing that bolt into the crank. When the next person who tries to work on it breaks the bolt off down inside the snout of the crank then the owner pays for a full tear-down and possibly a new crank or has to replace the engine with another one.
Peter
Old Jul 28, 2010 | 09:06 PM
00Corvette's Avatar
00Corvette
OMG they sure arent light.
What was I thinking? How does this impact work anyways? It torques out of my hand every time I turn it on. Is there a write up somewhere on using an impact?
I'm no hobbyist. I watch every episode of Horsepower TV and read at least five magazines a month, as well as all the internet writeups.
Okay, the impact wrench isn't designed to torque anything as far as I know. It's designed for quick removal of larger fasteners. half inch drive even 3/8's...I'd recommend never using these for tightening anything other than snugging down your lug nuts(before torquing still)
Impacts can be used to tighten stuff down but it's more for heavy equipment/farm vehicles(slow moving)
and on those "shows"/articles...they skip about half the steps on each job they do. Reading is great man and that's how I've learned a lot too, but don't give advice out based on what some article says. When it comes to individual balancers/engines/bolts...
They are VERY different. You may have seen Joe Elmore running a balancer bolt on to an old school SBC w/ an ARP bolt or something?
This has NOTHING to do with an LS1, very different engine as far as design/torque yields/strength.
I've literally NEVER used an impact for any job on these cars other than removing lug nuts.
I still have to do the TT bushings and I'll prolly bust the bushings off of the tube itself using an impact but I still won't use it to tighten..it may be fine but why risk it? It's very easy to just tighten a freaking bolt...if you have enough room to get an impact in there...just use the impact to remove the bolt. nothing else
Old Jul 28, 2010 | 09:16 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
His IMPACT WRENCH is calibrated and can be dialed in to a specific Tq!
REMEMBER,,,,,,,,,,,,,,,,, He watches ALL the epsodes of HP TV.
and reads at least five magazines a month, as well as all the internet writeups.
AND he STILL gives out bum dope!
