Battery (which) Replacement C5
Old Jul 28, 2010 | 12:16 PM
bojangles5169's Avatar
bojangles5169
Default Battery (which) Replacement C5
I have a dead Delco on my '02 Z06 Garage Queen - (10,200 mi). I have used a battery tender but the Delco won't hold a chg anymore. I understand mechanics but electricity is FM (friggin magic) to me. I have been reading about wet cells (rather not), gel cells, dry cells and deep cycle - totally confused. The only other electrical drain from stock is that I added a complete LG sound system - 1 amp is 500w and the other 300w run straight to the batt w/a #1 ga wire. The car does sit in my garage for long periods of time (up to 30 - 60 days) but I've been using a battery tender most of the time during those periods. If price were no concern (it is somewhat) what batt is going to fit and give me the best service with the above options and use in mind.
Any knowledgeable info or advice will be greatly appreciated! (I know that there are other threads on this but feared it might be outdated info with technology improving so fast)
Many Thanks,
Bojangles5169
Old Jul 28, 2010 | 12:24 PM
cdkcorvette7's Avatar
cdkcorvette7
Many Thanks,
Bojangles5169
This has been covered a fair amount and the general consensus is that there is no consensus. Personally I've had good luck with DieHard and Optima in the past. Just buy a name you've heard of and you really can't lose.
If you drain and recharge a lot go for a deep cycle battery like the optima yellow top...
Old Jul 28, 2010 | 12:58 PM
corvettebob1's Avatar
corvettebob1
Delco professional period!
Old Jul 28, 2010 | 01:07 PM
Higgs Boson's Avatar
Higgs Boson
Duracell!
Old Jul 28, 2010 | 03:07 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
WALMART BATTERY. It has a very good warranty, will EASILY last 4-5 years or longer, works as well as any other battery and it only cost $75.00
Old Jul 28, 2010 | 04:34 PM
98vettedave's Avatar
98vettedave
Yep the same battery (MAXX-78N) that I use.
Old Jul 28, 2010 | 04:53 PM
vetteracerx's Avatar
vetteracerx
My 2yr old optima left me 2 hrs away from home. i was close to a Wal-Mart so thats what mine got. So far so good. I just hope that it dosent leak.
Old Jul 28, 2010 | 09:27 PM
Hi/Tek/Vette's Avatar
Hi/Tek/Vette
optima yellow top deep cycle
don't buy a red top they SUCK
Old Jul 28, 2010 | 09:35 PM
bojangles5169
Default Yellow Top?
That's the deep cycle - right? As I said - electricity is "FM" to me - I know I have 6v deep cycle batts hooked in a series in my diesel pusher motor coach. Those are the "house" - not engine batt. Is there an advantage to the deep cycle in the Vette? And what? I'm definately going gel cell.
Old Jul 28, 2010 | 10:15 PM
Milan's Avatar
Milan
Wal Mart battery is the best, here is why:
1) It's cheap
2) They come with a decent warranty...there is Wal Mart everywhere in the US, no matter where you get stranded, if you ever do, they will recondition/test/replace your battery for free
Old Jul 28, 2010 | 11:40 PM
MMH2009's Avatar
MMH2009
Yupper I saw them today $75. Can't beat that!
Old Jul 28, 2010 | 11:51 PM
KCvetteowner's Avatar
KCvetteowner
1) It's cheap
I agree, except I will never let a WalMart employee try to lift out my old battery or put a new battery in. It's a recipe for disaster... The greeters at WalMart have bigger muscles..
Old Jul 29, 2010 | 12:02 AM
jrose7004's Avatar
jrose7004
I've had good luck with a Red Top as well as Delco.
Old Jul 29, 2010 | 01:40 AM
00Corvette's Avatar
00Corvette
My next battery will be walmart special, after 2 over rated/priced Red tops and one my 68 camaro.. i may run a little better battery in the camaro but if the CCA are over 8-900 I'll throw a walmart special in that thing too...who cares with a 5 year warranty?
Old Jul 29, 2010 | 01:42 AM
Kale's Avatar
Kale
My sears platinum battery has been rock solid.
I trashed my ac delco battery right quick tuning my stereo.
So far so good with the sears...
Old Jul 29, 2010 | 01:59 AM
00Corvette's Avatar
00Corvette
that platinum is a badass battery.. a lot of dough though
Old Jul 29, 2010 | 03:47 AM
Rebel 1's Avatar
Rebel 1
I Only use Delco.
Paid $68.39 over the dealer counter for a 5 year Delco battery that has Always Lasted a lot longer, 7 to 10 years usually.
And it is original G.M.
To Battery (which) Replacement C5
Old Jul 29, 2010 | 06:23 AM
SEE3ER's Avatar
SEE3ER
St. Jude Donor '21
SEARS DIEHARD PLATINUM!......
Old Jul 29, 2010 | 09:27 AM
cdkcorvette7
I'm not an expert, but my understanding is that deep cycle batteries respond better to being drained and recharged repeatedly. If you don't drive your car much and don't use a good battery tender this is probably the way to go.
Old Jul 29, 2010 | 09:48 AM
bobby777's Avatar
bobby777
Buy a RED TOP--its lighter than the heavy Yellow Top--
