Battery (which) Replacement C5
If you do have heavy current drains due to a high-amp audio system, then a deep-cycle battery is preferable. However, expect a shorter life span from any battery that is repeatedly drained almost completely.
Good luck.
Thanks again,
bojangles5169
Ok, I bought a deep cycle yellow top since I do have quite a bit of audio and guess what the lawyers wrote in to the red top guarantee "void if audio eq, amps, inverters, etc are added" or something like that. It's in the fine print of course!
Thanks again to all - - -
L
97-00 batteries tended to develope leaks at the positive terminal. Rumor has it that this was due to overtightening at the factory.
01-03 C5s came from the factory with AC Delco AGM batteries (similar in design to the red top and Sears Platinum). They were considered to be leak and vibrationproof but were susceptable to early deaths if not kept charged via a maintainer or frequent, long-distance (7+ miles) driving. Some owners (like myself) were able to extract 7 years or more out of them.
In 2004, AC Delco switched manufacturers (now Johnson Controls, I believe) and in the process, received non-AGM batteries that featured much more robust cases. To this day it extremely rare to hear of ANY 2004 and newer batteries that leak. In other words, the sky isn't falling and you can buy almost ANY battery and NOT worry about it leaking acid. Instead of feeling that you have to spend $140, you can spend less than $100 and have a battery that'll last 5-8 years.
L
this is a great post very informative thanks to the OP for asking my upcoming question
If you use yours as a DD, the Red Top should work just fine.
1) It got really good marks in Cons Reports for both CCA and reserve capacity. Tested much higher than all the others.
2) Great warranty, 4 year free replacement warranty (not prorated). I intend to keep the car for at least that much longer.
3) I have extra power needs (air compressor for air horns/tire inflation) and high powered stereo.
4) Sears are everywhere in case something does go wrong.
5) Broken down by year, even if this battery lasts only 4 years the extra cost of this more expensive battery breaks down to what, $25 more per year?
Padrino
There's no doubt, though that the Sears Platinum is a good battery.
I replaced with AC DELCO Professional 78V6YR for $78.95.
The V Vintage series does not have the handle molded into the side case and has a nicer OE appearance.
This is just my experience. I may just put my 30 year old charger on my first Optima red top and just go and have it load tested , for the Halibut
