Head recommendation
Old Oct 30, 2011 | 11:51 AM
hermancar's Avatar
hermancar
Default Head recommendation
1999 ls1,ls6 topin,ls2 timing chain,comp cam xr265 high lift cam,xr power exhaust system,ls7 lifters,automatic trans,3:15 rear and zo6 air intake. What head would you recommend for this setup? 99% street and highway use. Thanks
Old Oct 30, 2011 | 05:07 PM
67ermine's Avatar
67ermine
AFR 205 if $ isn't an issue, or ported or non-ported GM243s
Old Oct 30, 2011 | 07:06 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
AFR or Trick Flow if cash is no option. I have PATRIOT PERFORMANCE Stage II heads on my heavly modded 02 ZO6. There supporting 450 RWHP! The CASH savings is pretty significant!
Ive been told that IF,,,,,,,,,,, I step up to AFR or a different ported head like TFS, I would expect to see some HP increases. IM very happy for now and there working WELL! Patroit Performance is a stand up dealer and will work with you with all your needs!
Price the heads and YOU deside what you want to do! If cash isnt a problem,, GO AFR or TFS!!
BC
Old Oct 30, 2011 | 10:11 PM
trevheff's Avatar
trevheff
wondering if i can put LS3 heads on my 03 Z06
Old Oct 30, 2011 | 10:46 PM
CPhelps's Avatar
CPhelps
I believe the LS3 heads require a 4.00 inch or larger bore, which your '03 Z06's LS6 doesn't have if it's stock bore.
Old Oct 31, 2011 | 12:34 AM
mitchell c's Avatar
mitchell c
The stock bore size of an LS6 is 3.90. To small for LS3 heads.
Old Oct 31, 2011 | 12:45 AM
mitchell c's Avatar
mitchell c
If you are still running the stock converter with 3.15 gears. You will gain MUCH better performance with a high stall T/C like the Yank SS3600 and 3.42 or 3.73 gears.
Old Oct 31, 2011 | 08:51 AM
AU N EGL's Avatar
AU N EGL
heads, Cam and intake/TB should work as a package for best results.
Not Cam from bin A
heads from Bin B
Intake from Bin C
Old Oct 31, 2011 | 09:23 AM
hermancar's Avatar
hermancar
Thanks for the input, but my build is very mild with 853 heads (stock) and dont want to put more head than needed. One guy mentioned having all my parts match and that is what i am talking about. What head configeration is best for my application even if it is a stock 243 heads. Thanks for all your help.
Old Oct 31, 2011 | 09:49 AM
AU N EGL's Avatar
AU N EGL
comp cam xr265 isnt that a DODGE cam ?
http://www.compcams.com/Company/CC/c...?csid=661&sb=2
Stick with the stock 243 heads, light wt valves, and a 224/230 581/588 114 cam or XER273HR
http://www.compcams.com/Company/CC/c...csid=1092&sb=2
Old Oct 31, 2011 | 10:03 AM
Irish Whiskey's Avatar
Irish Whiskey
my 2000 is daily driver w/ 100K miles - I have the Patriot heads - they are the cnc'd stock Z06 "243" heads (chamber 62cc) - I think this fits into your daily use category - I have 218/224 comp cam/double gold springs - heads flow 300 cfm - Have Yank 3600 stall - Kooks headers - 3.42 gears w/ hardened shaft -
wife says it drivers fine for her - will do 11.83 in 1/4 mile - also still gets 28 mpg on the highway
Old Oct 31, 2011 | 10:08 AM
hermancar's Avatar
hermancar
The cam i have is comp cams xr265hr-high lift,212/218,558/563 @.50 and 115 ls. as you see not much more than stock z06 cam except 8 degs mor intake duration. I have been leaning towards the z06 243 heads in stock condition.Thanks
Old Oct 31, 2011 | 12:43 PM
chevy406's Avatar
chevy406
I"m curious why you selected that cam profile?
To answer your question on head selection, it sounds like you will be plenty happy with a set of 243 castings. But I would encourage you to get ported 243 heads. You might think that a 40-50 hp bump with that cam and stock 243 heads is "all you will ever want", but it won't be enough in 6 months. If you are paying someone to do the wrenching, start out with good parts (bigger cam and ported heads), so you don't have to pay labor again.
Old Oct 31, 2011 | 12:59 PM
99 vett babycar's Avatar
99 vett babycar
AFR 205 if $ isn't an issue, ...
Old Oct 31, 2011 | 02:54 PM
AU N EGL's Avatar
AU N EGL
From Comp Cam
XR265HR 212/218 .522/.529 114 LSA
http://www.compcams.com/Company/CC/c...csid=1085&sb=2
tremendous torque in a range (2,800 to 5,400 RPM's)
Good torque and very strong mid-range power. Good performance cam.
Old Oct 31, 2011 | 02:58 PM
trevheff's Avatar
trevheff
Thank you guys for the answer. one more thing what would be the best heads to go with? I plan on supercharging it and I all ready have a cam, headers, injectors. Last dyno it made 490 to the rear wheels and I would like to get to a solid 700 to the rear. any help would be great!!
Thank you to all that ae helping me get to the 700 mark
Old Oct 31, 2011 | 04:04 PM
hermancar's Avatar
hermancar
The http://www.compcams.com/Company/CC/c...=1089&sb=2comp cam
part number 54-424-11. comp cam
To Head recommendation
Old Oct 31, 2011 | 04:13 PM
lucky131969's Avatar
lucky131969
Start your own thread....
Old Oct 31, 2011 | 10:49 PM
alxltd1's Avatar
alxltd1
St. Jude Donor '10-'12-'13-'14-'15-'16-'17
Originally Posted by AU N EGL
From Comp Cam
Confusion comes from Comp Cam using the same "XR265HR" descriptor for two different cams. The XR265HR 54-424-11 is in their XFI RPM HI-Lift family and the XR265HR 54-412-11 is in their XFI RPM family. Similar duration different lift and LSA.
Old Nov 1, 2011 | 06:28 PM
PRE-Z06's Avatar
PRE-Z06
That cam is very mild and ported/aftermarket heads will not show as big of a gain as a bigger cam would, but if you're happy with that cam then I'd recommend looking at PRC stage 2.5 5.3 or 243 heads. I run them with my 218* cam and you can see my numbers below...
