615hp LS3 427 longblock
Old Jun 20, 2012 | 10:39 AM
SDPC's Avatar
0SDPC
Former Vendor
Default 615hp LS3 427 longblock
We receive so many requests for this engine that we have decided to start stocking them as longblocks!
615hp LS3 427 - $7999 shipped!
LS3 blocks with bronze lifter bushings
Manley 4.100” stroke crankshaft
Scat 6.100” Rods (24X)
Eagle 6.100” Rods (58X)
Manley -7cc 4.068” bore flat top pistons
Ackerly moly rings
Clevite “H’ series rod and main bearings
Durabond cam bearings
SDPC custom roller cam 236/248 – 601/615 – 112
LS7 lifters
N-MOTION billet timing set
ARP cam bolts
LS2 front cover W/cam sensor
SD3964B ported oil pump
Assembled rear cover installed
LS2 valley cover (24X)
LS3 valley cover (58X)
Manley Pushrods
Stock rockers
LS3 CNC heads with PAC 1211X springs
24x engines include the necessary cam/knock sensor harness.
These are in stock and ready to ship immediately, no wait at all!
Jesse - (800)456-0211 ext 358
If you have any questions feel free to give me a call.
Old Jun 20, 2012 | 10:42 AM
C5R USA's Avatar
C5R USA
From: Ideals are peaceful...History is violent...St.Charles, MO.
C5 of Year Winner (appearance mods) 2019
St. Jude Donor '08-'09-'12 thru'22
Old Jun 20, 2012 | 11:54 AM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
wow nice !!!
Old Jun 20, 2012 | 02:01 PM
Millenium Z06's Avatar
Millenium Z06
Moderator
Wow, that's a pretty good deal. I may skip heads and cam and go directly to this.
Old Jun 20, 2012 | 02:03 PM
tomlink's Avatar
tomlink
Seems like the hot ticket to replace my 130K mile LS1.
Anybody dropped one of these into their C5 yet?
Dyno graph or Youtube idle vids?
Subscribed.
Old Jun 20, 2012 | 03:36 PM
Tulsa Vette Guy's Avatar
Tulsa Vette Guy
May be just what I am looking for,, But, I may be able to buy a craet motor for about the same,, Checking things out, Adding the cost to complete the long block, What the cost will total??
Old Jun 20, 2012 | 04:52 PM
tomlink's Avatar
tomlink
Good point Tulsa,
Other than needing the obvious intake/TB/injectors/waterpump, what LS1 parts could you re-use (oil pan, valve covers/coils, balancer, accessory drive, flywheel, etc?) and what would you need to buy to swap this into a C5?
Old Jun 20, 2012 | 05:11 PM
Toque's Avatar
Toque
Will the C5 Computer work with it?
Toque
Old Jun 21, 2012 | 11:17 AM
SDPC's Avatar
0SDPC
Former Vendor
The C5 computer will work fine, we have these in stock in 24x setups specifically for you guys. You'd just need a good tune.
Most everything will swap over from your existing vehicle. Exhaust, accessories, water pump, oil pan, coils, flywheel/clutch etc. If it's in good condition (not needing replaced anyways) and suitable for your newfound power (clutch), swap it over and use it.
You will need:
Intake setup completed with fuel rail, injectors, and TB of your choice (Nick Williams or LS2)
Injector adaptors
Your balancer will work if in good condition, also consider a new one while you are in there or even an aftermarket underdrive balancer.
To drill and tap for your knock sensors on the side of the block. New harness included with the engine.
I wouldn't consider running this engine with your factory exhaust manifolds. If you don't have them already, please get headers.
Old Jun 21, 2012 | 11:30 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
What a thing of beauty! Good price too!
Thanks,Matt
Old Jun 21, 2012 | 01:03 PM
AU N EGL's Avatar
AU N EGL
$8 grand ?/ DAMN that is great.
Daily dry sump and I am good to go
Old Jun 26, 2012 | 03:42 PM
SDPC's Avatar
0SDPC
Former Vendor
We appreciate the response so far and we have more available. Thanks guys!
Old Jun 27, 2012 | 12:19 PM
tomlink's Avatar
tomlink
Jesse,
What is the compression ratio and redline for this motor?
Old Jun 27, 2012 | 04:11 PM
Chicago1's Avatar
Chicago1
Boost friendly?
Old Jun 27, 2012 | 04:21 PM
SDPC's Avatar
0SDPC
Former Vendor
Originally Posted by Chicago1
Boost friendly?
No. I wouldn't boost ANY 4.100" stroke setup.
Old Jun 27, 2012 | 04:35 PM
SDPC's Avatar
0SDPC
Former Vendor
Jesse,
Right at 11.0
Old Jul 19, 2012 | 03:39 PM
SDPC's Avatar
0SDPC
Former Vendor
The response on these has been great, thanks guys. We are still doing these and have some ready to ship right now!
To 615hp LS3 427 longblock
Old Jul 19, 2012 | 04:09 PM
AU N EGL's Avatar
AU N EGL
Impressive.
Old Jul 19, 2012 | 06:25 PM
evo2ls1's Avatar
evo2ls1
I sent you a pm but I am curious of what is the cost of buying the motor and actually having it installed and tuned, this is a long lock bu I would need rule pump, intake manifold, file injectors correct, thanks!
Old Oct 14, 2012 | 03:03 PM
didntdoit11's Avatar
didntdoit11
St. Jude Donor '12
do you still offer this product
sent a pm and never answered
