Thermostat Question
Old Jul 23, 2012 | 02:18 PM
vetteboy850's Avatar
vetteboy850
Default Thermostat Question
What would be the price range for a 180 thermostat for my 98 A4?
Old Jul 23, 2012 | 02:26 PM
Corvette_Ed's Avatar
Corvette_Ed
I don't know what the price is, I'm sure Autozone or O'Reilly can help you there, but why would you want one? OEM is 187.
Old Jul 23, 2012 | 04:01 PM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
Since the OP lives in FL, a 160 degree stat might be a better choice for his climate. Here's one at Autozone:
http://www.autozone.com/autozone/par...923_1640_93208
Old Jul 23, 2012 | 05:16 PM
vetteboy850
Wouldn't that be to cold? I thought the 182 degrees was right in the ls1 power range?
And..
Is it worth it spending $60 for a Hypertech brand?
Old Jul 23, 2012 | 05:20 PM
bumble-z's Avatar
bumble-z
And..
Try an AC Delco replacement.
Get one with the stat built into the housing & comes with a rubber O ring.
Old Jul 23, 2012 | 05:34 PM
baxsom's Avatar
baxsom
whatever.
once the temp of the stat's rating is reached they will all open up and flow anyway.
Old Jul 23, 2012 | 07:33 PM
NukeC5's Avatar
NukeC5
Oh God, here we go again!!!
My opinion is that a cooler thermo matched with a lower fan switch setting can allow lower temps. Not just a thermo that opens sooner. I wouldnt just shove one in and call it good. Do it along with other mods and get a tune and have them set the fan lower.
Old Jul 23, 2012 | 07:59 PM
vettenuts's Avatar
vettenuts
Note that you can change the opening temp of your stock thermostat for about $1 in parts and a few minutes labor.
Old Jul 24, 2012 | 01:03 AM
happiedazs's Avatar
happiedazs
Yea, I'd be interested in the details too.
Old Jul 24, 2012 | 01:47 AM
vetteboy850
Well my mods are:
Borla Exhaust
BBK UD
BBK Headers
K&N cai
Hypertech Tuner
And right now I'm currently running with the stock thermostat, but since it gets really hot here in Orlando I wanted to change that to help my car stay cooler. So back to my question "Is it worth buying the Hypertech thermostat for $60? rather than spending $30 for an autozone brand?"
Old Jul 24, 2012 | 05:10 AM
vettenuts's Avatar
vettenuts
Originally Posted by 8VETTE7
Can you post some details????
I posted the following a couple of years ago but the thread has since been closed and the host server for the photos went away. So I uploaded the photos to Photobucket to duplicate the old thread. If you find the old thread, the photos are missing.
In the first photo the thermostat has been disassembled. You can see one of the shims that I made and the hole into which it is installed. The shim is made from 1/8" aluminum rod from the local hardware store. The thickness of the shim will alter the opening point by lowering it, or as is the case if you get to approximately 0.100” thick shim, the thermostat will barely close.
One of the problems I ran into was how to measure data so it wasn’t subjective and I could repeat the test fairly well between the different shims and get a good comparison. After some messing around with the test, I decided to take the temperature at three points in the opening sequence. First, by hanging the thermostat such that the neck was downward, it was easy to trap air behind the rubber door that opens in the thermostat. The first data point would then be when the thermostat opened enough to release the trapped air. This doesn’t take much movement at all and you can barely see the rubber door move at all when this occurs since the movement is so slight. The second point of measurement would be when the rubber lip on the seal was even with the flat mounting surface of the thermostat (see the photo). Finally, I took a third measurement when the rubber lip was 0.2” from the same flat mounting surface. While this seems to be a precise number, it is actually the width of my flat screwdriver that I could hold in the water and use for a measuring tool. With one edge of the screwdriver against the flat mounting surface of the thermostat, when the lip was even with the other edge of the screwdriver blade that is when I wrote down the temperature.
Below is a photo of the shim installed prior to re-assembly of the thermostat.
Next was the method of heating up the thermostat so it was immersed in water. In the next photo you can see I bent up a coat hanger and hung it from a small stick across a large pot of water (my wife thinks I should be committed at this point . The wire next to the thermostat is the thermocouple that was tied into a Fluke Meter for measuring the temperature.
Below is the Fluke Meter that was used to monitor the temperature, which is accurate to 1/10th of a degree.
Here is the data that I obtained, noting each shim was tested several times to obtain these average values:
It appears that with the 0.098” shim, the thermostat is barely closed. The 0.075” shim didn’t quite get me to where I wanted to be. The performance of the 0.058” shim, which seems to seal the thermostat better when it closes down again, will hopefully provide me the temperatures I am trying to achieve in the motor. However, if it is too cool the data will be used to make adjustments as necessary to get to my final goals.
This modified thermostat is now running in a C5 with a DeWitts radiator. On a hot day cruising the motor temp stays right at 180, cooler temps and the engine temp goes to 178 and no lower. At this point, the motor is a little too cool and I plan to modify the thermostat this fall to hopefully bring the running temp up to 185 in cool temps, which is my target running temperature.
Old Jul 24, 2012 | 08:16 AM
Quicksilver Vert 01
And..
The actual temperature that your engine will run at cruising speed, with a 160degree stat installed, will somewhat vary with the outside temperature. In Florida, I'm thinking it would not be too cold.
The Hypertech brand thermostat is overprisced in my opinion. The VERY SAME one is about $30 at Autozone. Both are made by Motorad in Germany, and then repackaged for sale under several different labels here in the US.
Old Jul 24, 2012 | 11:02 PM
02koolC5's Avatar
02koolC5
Man I love this forum, I mean this kind of ingenuity all I can say is
Old Jul 25, 2012 | 01:03 AM
vetteboy850
Thanks for all the info guys
To Thermostat Question
