Magic Clutch Fluid
Old Sep 28, 2012 | 04:26 PM
wcsinx's Avatar
wcsinx
Originally Posted by bladeboy2025
that sound's horrible. The clutch isn't slipping
Mine didn't slip either when it got contaminated. In fact, it did the opposite and started binding because the pad material swelled up.
Old Sep 28, 2012 | 04:40 PM
LoneStarFRC's Avatar
LoneStarFRC
that sound's horrible. The clutch isn't slipping, when I checked it out the drive and bearing seemed dry. The clutch still had a glossy powder coat on it too, I say this because I know how corrosive fluid is.
Is there a UV dye or anythign that you can add to the fluid? That way I can get in there with a black light and maybe find a glowing spot.
If your clutch is not slipping, chances are you're still good. Never know though.
There may be some sort of dye product out there on the market for use with brake fluid (that's actually the fluid used in the clutch hydraulics here), but I'm not aware of any. Probably more trouble than it's worth really.
I see you're in Crestview (I spent a week there one night unfortunately ), but if you can get your vehicle to JAX (Green Cove Springs actually), I can recommend a very good shop to get work done. They work on strictly Camaros/Firebirds and Corvettes. Knowledgeable, reliable, fair and MOST importantly - honest. Can't ask for much more.
LMK if you're interested.
Old Sep 28, 2012 | 07:04 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
Changed all the bearings out and added a Tick Performance Speed bleeder.
Curious, hows the pedal feel with the Tick? I have the mantic single with an ECS modified GM master and its soft and smooth like stock.
Old Sep 28, 2012 | 07:13 PM
LoneStarFRC
I think he's speaking about his Tick speed bleeder, not M/C. Speed bleeders don't have any effect on pedal pressure.
I DO have a Tick adjustable M/C and the pedal pressure did go up over stock, but not so bad as to want me to remove it. I'm very accustomed to it now, and what's more I never get pedal-stuck-to-the-floor-at-high-rpm-shifts like I used to.
Old Sep 29, 2012 | 03:23 PM
cptinjak's Avatar
cptinjak
There are TWO parts to the clutch hydraulic system: A master cylinder and a slave cylinder. The master cylinder is (pretty much) in plain sight, so if you cannot see a leak there, I would feel pretty confident assuming it is THE ONLY OTHER PART OF THAT SYSTEM. The slave cylinder, (which just so happens to be hidden from view.)
Replace it.
Jack
Old Sep 29, 2012 | 03:25 PM
wcsinx's Avatar
wcsinx
It's slightly stiffer, but honestly it took me 1 drive to get used to it. Now I don't even think about it. Then again, I did learn to drive on a '67 Jeepster Commando with a cable clutch.
Old Sep 29, 2012 | 11:14 PM
Coach62's Avatar
Coach62
St. Jude Donor '12
There are UV dyes you can use, that was my first thought if you want confirmation. My first thought overall is the slave sorry to say. Here's a couple of links for you. I'm a huge proponent of UV dyes, can save many hours of work.
http://www.ehow.com/how_6741808_bad-...-cylinder.html
http://www.supercool.ac/products/aut...-1-oz-29-5-ml/
Old Oct 1, 2012 | 10:25 AM
Ashc2025's Avatar
Ashc2025
How old was the clutch...please don't say new
Thanks for the shop reference! I'll probably do the clutch in our shop on base, I dropped the bottom once, I'm sure I can do it much quicker now. If I come across some burried money or lottery I might take it there.
Replace it.
Jack
So depressing You're probably right, I'm going to really give the whole system another walk arround. Dropping the tube out isn't a fun job, especially with an STS.
Thanks for the reference, I'm going to try this.
For now the car will be parked. If i'm not slipping, then I'm not going to risk blowing my clutch. If there is a leaky seal then there's no telling when it might give up on life and destroy everything.
Forum member are as awesome as always, I'll keep ya'll informed of what I can find
Old Oct 1, 2012 | 11:05 AM
wcsinx's Avatar
wcsinx
That was clutch #2, and it only had about 20k miles on it (car had 90k). The shop that put in that clutch swore up and down that they used a new slave, but I'm pretty sure they did not. It kept binding worse and worse until the slave completely tore apart. When it was torn down for clutch #3, the mech (whom I trust) said that there would have been no air-gap based on his measurements.
You won't blow your clutch, you'll blow your slave. It won't "destroy everything", but you'll be stranded. Some cars you can drive clutchlessly, but I have not found this to be the case with C5s.
Old Oct 1, 2012 | 12:24 PM
cptinjak's Avatar
cptinjak
Ah, yea that would make it a pain! Good luck, but if I were a betting man, I would have my money on slave. All day any day. :/
Jack
Old Oct 7, 2012 | 11:13 PM
Ashc2025's Avatar
Ashc2025
http://www.southerncarparts.com/corv...er-p-3145.html
Says durable for high performance.....or is it just a stocker?
I'm having trouble getting into Reverse with the engine running. Engine off-Key on; all gears are butter, but turn the car off and Reverse is hit or miss, mostly miss. Also 2nd is hard to shift into in the higher RPM's. Friction point is almost on the floor. Still no fluid present either.
I'm going to throw the back end up on stands and start it in first with the clutch down, to see if my wheels are spinning. Sorry if I'm talking in circles a bit, but I'm in denial if the slave went out. Only because I don't want to drop the bottom out again LOL.
Old Oct 8, 2012 | 02:19 PM
cptinjak's Avatar
cptinjak
I've never seen one in person, but that RAM unit looks exactly like a stocker painted black. Hopefully someone who has experience with one can share some more info.
Jack
Old Oct 9, 2012 | 08:21 PM
  #33
Ashc2025's Avatar
Ashc2025
Nobody's heard of the RAM slave cylinder?
Old Oct 9, 2012 | 08:57 PM
  #34
bumble-z's Avatar
bumble-z
Of course we have heard of it.
Why not ask who uses it & their opinion?
Why are you so adamant against a GM slave?
Old Oct 10, 2012 | 02:17 PM
  #35
Ashc2025's Avatar
Ashc2025
Well, that's what I was getting at.
I'm not against a OEM slave just weighing my options. If Something's been designed for higher performance then I would want to go with that. Been told the Stock hydraulics arn't the greatest in the car too. So why would I get something that would blow from the pressure of the aftermarket clutch?
If it's good to go then that's what I gotta do. But if there's somethign better out there I would really like the peace of mind. Already dorked it up once.....
Old Oct 13, 2012 | 11:44 AM
  #36
cptinjak's Avatar
cptinjak
Originally Posted by Venomous
The Ram is just an adjustable O.E. as far as I saw. The internal plunger stop is shorten for a lil further pump action, no restrictors in line, and adjustable rod to set slave extension.
I've had great results with modding a factory one like Ram does! Look up " adjustable master cylinder mod"
That is from this thread: http://forums.corvetteforum.com/c5-t...er-vs-oem.html
Seems to confirm my assumption that they are using a mainly OEM piece. The "adjustability" is a band-aid for improperly shimmed units, IMO.
Jack
Jack
Old Oct 13, 2012 | 04:42 PM
  #37
johnson-rod's Avatar
johnson-rod
Contamination? Not necessarily.
I ran a leaking slave all winter one year. It would lose the entire reservoir overnight.
When I replaced it in the spring, the clutch and disk were dry as a bone. That was 45K miles ago and the clutch is still going strong.
To Magic Clutch Fluid
Old Oct 14, 2012 | 09:18 PM
  #38
tak06's Avatar
tak06
I'm scheduled to have the OEM slave/disc/pressure plate/flywheel replaced this coming Tuesday Oct 16th. at a Dealership, car is a '02Z 12k. miles, not tracked and totally stock. Don't wish to remove the driveline twice, good insurance and peace of mind. I noticed brake fluid at the lower bell housing and the clutch would stick to the floor at times and diminished fluid level at the m/c, so I'm assuming that it's the slave. Maybe an expensive assumption of $1900.
After reading this thread, is there actually an inspection plate whereby I could have looked at the slave or bleeder screw without removing the driveline? If so can someone tell me where and how difficult is it to get at?
Old Oct 14, 2012 | 10:03 PM
  #39
cptinjak's Avatar
cptinjak
After reading this tread, is there actually an inspection plate whereby I could have looked at the slave or bleeder screw without removing the driveline? If so can someone tell me where and how difficult is it to get at?
If you do not have headers, it is extremely easy to remove. There are a few 10mm bolts and I believe a couple 13mm bolts holding it to the botom of the bellhousing. If you get underneath the car it will be obvious when you see it.
Jack
Old Oct 14, 2012 | 11:00 PM
  #40
tak06's Avatar
tak06
Jack, Thanks for the tip, I'll get them to check that b4 removing the driveline. I can keep the clutch parts for future use if it's only a loose bleeder screw.
