ignition switch
Old Oct 23, 2012 | 03:42 PM
  #41
lucky131969's Avatar
lucky131969
Originally Posted by The Rabbi
The codes won't do much good if the car is working ok. Mine was intermittent and that was confirmed by several people if you read the posts the culprit is the solenoid.
No......a POSSIBILITY is the solenoid. You could have an issue with the lock cylinder, which will cause the exact same symptoms. That would show up in the codes...
Old Oct 23, 2012 | 04:10 PM
  #42
The Rabbi's Avatar
The Rabbi
2018 C5 of Year Finalist
St. Jude Donor '14,'18
Switch was replaced earlier this year.
Old Oct 23, 2012 | 04:14 PM
  #43
wcsinx's Avatar
wcsinx
Whoa there, I was not confirming anything. I merely offered that up as likely suspect given your symptoms. A starter solenoid is a very easy component to test. And I would recommend you do precisely that before you replace it.
Old Oct 23, 2012 | 04:33 PM
  #44
lucky131969
Lock cylinder and ignition switch are two different parts.
Old Oct 24, 2012 | 02:24 PM
  #45
The Rabbi's Avatar
The Rabbi
codes
B0432H
B0436H
B2587H
B2282H
B2262H
U1064H
U1016H
B2283H
B0851H
U1255H
B0507H
B2809H
B2286H
B2261H
U1096H
B0502H
B2482H
B2593H
B2284H
B2285H
Old Oct 27, 2012 | 03:30 PM
  #46
The Rabbi's Avatar
The Rabbi
I've posted the codes and no one has responded.
Old Oct 27, 2012 | 04:21 PM
  #47
pjensen's Avatar
pjensen
codes
B0432H Rear Defogger Relay Circuit BCM Stationary Windows
B0436H
B2587H Column Lock Open or Short to Gnd BCM Steering Wheel and Column
B2282H
B2262H
U1064H
U1016H
B2283H 12V Power Feed #1 Fault RDCM Doors
B0851H
U1255H Lost Communication with XXX All Modules
B0507H
B2809H
B2286H +5V Reference Fault LDCM Doors
B2261H
U1096H
B0502H RH DRL Relay Circuit BCM Lighting Systems
B2482H Backup Lamp Relay Circuit BCM Lighting Systems
B2593H Column Unlock Open or Short to Voltage BCM Steering Wheel and Column
B2284H 12V Power Feed #2 Fault LDCM Doors
B2285H 12V Power Feed #2 Fault RDCM Doors
Looks like a possible column lock short or open. I put the code info in your quote.
Old Oct 27, 2012 | 05:10 PM
  #48
FRITZM's Avatar
FRITZM
Default Codes
Try this list. If none are affected by you ignition switch then you can probably delete them. Also, if they are followed by an "H" they are history codes and have probably been addressed or have been "relearned" by the appropriate electronic module if the problem no longer exists. If they are followed by a "C" then you have a problem with that system. Try pulling the codes with the car idling and see if any "C" codes popup.
http://www.obd-codes.com/trouble_cod...d-ii-codes.php
Old Oct 27, 2012 | 07:05 PM
  #49
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
My friend,,,, That is still a LOT of DTCs. Seems that you have a POWER ISSUE some where somehow... Make SURE that the battery is 100% GOOD and properly charged.
Make sure that the battery cables are properly installed. CLEAN, & torqued to 11 Ft/lbs.
The door electrical harness connectors are WELL KNOWN to have connection issues. Especially the power connector. POP OUT the rubber accordion tube , pull up the connectors from the A Pillar hole, examine the FEMALE PINS and make sure that they are not SPREAD APART.
If they are repair or replace the pins.
FIND THE BAD PINS!!
BC
BC
Old Oct 27, 2012 | 07:50 PM
  #50
The Rabbi's Avatar
The Rabbi
No C codes while idling. I couldn't figure out how to delete the codes even with the instructions.
Old Oct 27, 2012 | 07:54 PM
  #51
The Rabbi's Avatar
The Rabbi
FIND THE BAD PINS!!
BC
BC
Thanks Bill. The pictures explained what you said. "A picture is worth a 1,000 words" especially to the mechanically challenged like me.
Old Oct 27, 2012 | 08:02 PM
  #52
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Get into MANUAL MODE and when your in EACH MODULE,,,,,,,,,,,,,,,,,,,, press and HOLD RESET until the codes go away!!!!!!!!!
Go into EACH MODULE and press and HOLD RESET until the codes go away!!!!!!!!!
BC
Old Oct 27, 2012 | 08:27 PM
  #53
The Rabbi's Avatar
The Rabbi
BC
Thanks again Bill. I wasn't holding the reset in. It just so happens I had a new battery put in this week.
Old Oct 28, 2012 | 11:07 AM
  #54
K-Spaz's Avatar
K-Spaz
From: Central PA. - - My AR15 identifies as a muzzleloader
I believe in the Beer Fairy
Disconnecting the battery does not clear the codes, just so ya know.
And btw, you'd have gotten this diagnosis 10 days ago if you'da posted the codes... However, R&R on the battery won't give you all the codes you listed. Some of them, yes.
Let everyone know what you still have after clearing them and moving forward will be a snap. (probably going to end up finding an issue or two you didn't know you had)
/edit
And just so you know, virtually all your codes you will get are going to be "H" codes. Even when they are current. It's just the way the system views the conditions. That does not mean it'll take any time for them to come back. Literally within seconds of setting the key to run, or possibly starting the car, they'll be back. In the case of the codes you have, I don't think any of them will require starting the car (could be mistaken).
I wrote a reply yesterday but saw it was redundant so I nixed it. In there, I did see that 3 of your codes you list are not even in my service manual. Might be cause mine is a 98 manual. I forget which 3. Possibly B0436H, B2809H, B2261H??? Sorry, don't recall.
