Green Oil?
My biggest concern is that it is a partial synthetic. In general, the basestock in mineral oils will shear down faster than that of synthetics which were required for the LS1/LS6. That is the molecules in the oil break due to shear forces and become smaller, thus the viscosity drops.
Though this is a diesel oil test mainly regarding fuel dilution which is a real problem in modern diesel engines with particulate filters, it will illustrate the point:
40 Grade Diesel Oil Shear Stability (644k pdf file)
Note how much viscosity some of the oils lost from the initial viscosity to the sheared viscosity (1st to 2nd columns).
The Brad Penn oils have high levels of zinc and phosphorus, at 1500 ppm and 1400 ppm respectively, well above the API SN limit of 800 ppm phosphorus, but that doesn't necessarily translate into better performance.
One of the measures I look at in an oil is the High Temp High Shear which is a measure of the oil's viscosity at 300F under high shear - potentially representative of how the oil will perform in protecting your bearings. Not all oil companies report HTHS. Using factory reported values, here is how the Brad Penn 30 grade oils stack up:
Mobil 1 5w30: 3.1
Brad Penn 5w30: 3.185
AMSOIL Sig Series 5w30: 3.2
Mobil 1 High Mileage 5w30: 3.3
Mobil 1 High Mileage 10w30: 3.5
Brad Penn 10w30: 3.54
AMSOIL Z-ROD 10w30: 3.6
Not sure if you got the 5w30 or the 10w30 so I included both. The Brad Penn HTHS is slightly better than that of the base Mobil 1 and slightly below AMSOIL's best API SN oil the Signature Series - noting that neither the Mobil 1 or the AMSOIL benefit from extra ZDDP (both are API SN so have no more than 800 ppm phosphorus). The Mobil 1 High Mileage 5w30 which has 1100 ppm zinc and 1000 ppm phosphorus jumps the Brad Penn despite having well less ZDDP. AMSOIL does not have a high ZDDP 5w30.
In 10w30, the Brad Penn is similarly slightly better than the Mobil 1 High Mileage 10w30 and slightly behind that of the AMSOIL Z-ROD 10w30. FYI, the ZDDP levels of the Mobil 1 High Mileage 10w30 are 1100 ppm zinc and 1000 ppm phosphorus, and the AMSOIL Z-ROD 10w30 is 1440 ppm zinc and 1320 ppm phosphorus.
Nothing I see indicates to me that Brad Penn is anything but an average oil - but it is comparible to Mobil 1 5w30 (assuming you got the 5w30) so I'd use it as you already have it. I wouldn't use it long without oil analysis as I'd be concerned about viscosity shear down of the semi-synthetic basestock.
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
That all being said, I'll still stick with the Mobil 1 in the C5 - they are about comparatively priced.
