What component does a U1064 error...
Old Sep 18, 2013 | 01:52 PM
P15-D24's Avatar
P15-D24
8th Gear
Default What component does a U1064 error...
indicate it lost communication with? Trying to track down an service active handling issue and this is one of the historical errors. My understanding is the "64" identifies a specific component. (Also had a U1000 error)
Old Sep 18, 2013 | 06:19 PM
P15-D24's Avatar
P15-D24
8th Gear
Default I cleared all the codes for this test...
Drove it until I got the service active handling warning, then parked it and pulled the codes again.
To your question I had a 28 TCS 1288 H with the B0 RFA U1000 H, U1064 H errors.
So that points to the steering sensor correct?
Old Sep 19, 2013 | 01:11 AM
P15-D24's Avatar
P15-D24
8th Gear
Default More info...
Originally Posted by 8VETTE7
C1288 does point toward the Steering Wheel Position Sensor. Have you recently had work done where the rack might have had to be dropped out of the car?? Like for example the balancer pulley was replaced?? If so the rack could have been turned while out of the car and is no longer centered electrically.
The RFA is the remote function adapter or the module that receives transmissions from the Key FOB's and the TPMS. Have you been having issues with either one???
No work done ever on steering or rack. (did have the issue with steering column lock not releasing 18 months ago and installed kit to get rid of lock issue). No issues with key fob, however I did get a weird tire pressure reading on RR when I did a 80 mile round trip on the freeway last weekend. I haven't had a chance to verify the reported pressure but I believe it is wrong. (Filled to 32 or 35 lbs a week ago and now reporting 15 lbs) I will check it in the morning. Also the RR has the wheel bearing going and I'm waiting on parts to do that work.
Will report back on TPMS reading tomorrow.
Old Sep 19, 2013 | 01:43 PM
P15-D24's Avatar
P15-D24
8th Gear
TPMS is working correctly and I need to find a slow leak!!
Old Sep 19, 2013 | 02:18 PM
Corvette_Ed's Avatar
Corvette_Ed
Sorry to butt into the thread but this just caught my eye as I have been throwing 1016, 1064, and 1096 codes on my BO RFA since I bought my car. Could these be caused by the use of aftermarket key FOB's? I had an aftermarket alarm system installed the day after I bought my car and use the key FOB's that came with it.
Thanks, and again sorry for butting in.
Old Sep 19, 2013 | 03:43 PM
P15-D24's Avatar
P15-D24
8th Gear
Thread on procedure for testing the Steering Wheel Position Sensor?
I tried searching but didn't see anything directly on topic.
To What component does a U1064 error...
