Need DIC Help
Old Nov 4, 2013 | 12:09 AM
Suzukibooii247's Avatar
Suzukibooii247
Originally Posted by Bill Curlee
Purchase or borrow a strong magnifying glass and examine EACH one of the soldered pins for the display. The solder joint should be smooth and continuous and shouldn't have any cracks.
Some of the solder joints on the EBTCM board are horrible. I cant believe that they passed inspection.
One of the solder joints on your board or something where the vacuum florescent tube connects is poor.
Bill
I never even thought about looking through a magnifying glass
Old Nov 4, 2013 | 07:28 AM
dadaroo's Avatar
dadaroo
This could also be the time to maybe see if a local electronics repair store might be able to see a problem. I remember when I looked at my dim HVAC solder joints they did not look bad. Resoldered them and now it works fine.
Old Nov 4, 2013 | 12:17 PM
Suzukibooii247
Yeah that is a pretty good idea
Old Nov 4, 2013 | 12:31 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I AGREE!
Just make sure that you properly communicate to the repair tech that you have an INTERMITTANT issue with the vacuum display. That will allow him to concentrate on looking in the correct areas.
Bill
Old Nov 4, 2013 | 12:44 PM
Corvette_Ed's Avatar
Corvette_Ed
As it appears BC has things well in hand I'll just say this.....
I think I would have worded the title of this thread a little differently.
Old Nov 4, 2013 | 12:52 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Like I stated earlier "
YOUR DIC IS DEAD.... Thats what she said!
I once told a FEMALE FORUM member (Not knowing I was speaking to a FEMALE),,, that you need to read your DIC and get the codes.
It turned out funny BUT,, it could have gone in a completely different direction!
BC
Old Nov 4, 2013 | 04:10 PM
Suzukibooii247
BC
Hahahaha
Old Dec 9, 2013 | 04:49 PM
David Shiel's Avatar
David Shiel
Default So, did you get the IPC problem resolved ?
Originally Posted by Suzukibooii247
Hahahaha
Sent you a PM. MIne was replaced with a factory new one at 13K miles. Did not solve the problem. Goes in and out. Not my DIC, but the whole IPC.
