injectors shutting down
Old Feb 13, 2015 | 10:19 AM
rigidy1's Avatar
rigidy1
2nd Gear
Default injectors shutting down
Hi I have a 2001 z06 just put the motor back in after major rebuilt and I can't get the injectors to work. She'll turn over , fire for a sec then nothing. I've checked the grounds and don't know what else to do.
Old Feb 13, 2015 | 03:15 PM
LoneStarFRC's Avatar
LoneStarFRC
Check Bills pictures in post #4
https://www.corvetteforum.com/forums...need-help.html
Old Feb 13, 2015 | 03:45 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You don't have proper:
1-GROUND
2- Coil Power
3-Coil Driver signal
4-Any or all of the above.
Start by actually MEASURING the voltages on the COIL CIRCUIT FUSES. Yes there's more than one... Measure the test point slots on top of the fuse/s to chassis ground and look for FULL BATTERY VOLTAGE on each fuse.
I agree,, read and post your DTCs.
Bill
Old Feb 20, 2015 | 01:25 AM
rigidy1's Avatar
rigidy1
2nd Gear
thank you for the tips ill post dtc's asap.
Old Feb 21, 2015 | 12:09 PM
Mark Estrada's Avatar
Mark Estrada
Default fuel injectors
you have checked the pump pressure and relay, right?..
Old Feb 21, 2015 | 03:16 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Here are some schematics to help you take some meter readings. If you dont figure out whats missing,,,,,,, ,,,,,,,,,, Its going to cost you a LOT of time and cash:
INJECTORS;
COILS:
Old Feb 21, 2015 | 04:39 PM
Mark Estrada
Default Ps....
If it worked when before you replaced the engine, you forgot to hook something back up...look for a ground or a wire connector you missed...put some temporary grounds between the motor ,frame, etc so you can either discover its a ground or eliminate it all together...If it ran, you just missed connecting something...
Old Feb 21, 2015 | 05:14 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Like ground on the back of the drivers head G-106:
Or the ground on the engine block for the PCM/BCM
Old Feb 22, 2015 | 10:05 PM
martysauto's Avatar
martysauto
St. Jude Donor '14
My money is on g106
To injectors shutting down
