electrical
Old Jul 17, 2015 | 11:30 PM
78vettemass's Avatar
78vettemass
Cruising
Default electrical
Hi,,,, just got a 2000 coupe with 112000,,,, very happy with it,,, just a couple issues
electrical,,, tail lights and instrument lights only work if twilight function is on,,,
also,, traction control and service engine soon,,, thoughts?
and sometimes blinkers dont work
thanks
darold
Old Jul 18, 2015 | 08:19 AM
dadaroo's Avatar
dadaroo
Your light issues make me think the Multifunction (MF) switch may be the issue.
When you say turn signals do you mean you are having issues with the Left and Right or just one side? If both sides then the Hazard switch is the issue. If one side only it should be an MF issue.
Old Jul 18, 2015 | 01:35 PM
78vettemass
Cruising
i havent pulled the error codes yet, but the blinkers are both sides im having issues with,,,after having read the posts here, i think the hazard switch needs changing
Old Jul 18, 2015 | 11:48 PM
BigGun's Avatar
BigGun
What about your tail lights and instrument lights. The hazard switch isn't going to affect them. If every thing works with twilight sentinel (except the turn signals) then I would look at replacing the multifunction switch. You need to pull the codes!
Old Jul 19, 2015 | 12:20 AM
fasttoney's Avatar
fasttoney
I agree with dadaroo.
Old Jul 19, 2015 | 07:53 AM
dadaroo's Avatar
dadaroo
Replace the Hazard switch first since it is obviously the issue with the turn signal.
Old Jul 19, 2015 | 10:02 AM
78vettemass
Cruising
will do! thank for the info guys,,keep you posted
Old Jul 21, 2015 | 02:57 PM
78vettemass
Cruising
pulled codes
b2282
b2284
b2276
b2578
b2583
p1626
Old Jul 22, 2015 | 07:46 AM
dadaroo's Avatar
dadaroo
Your first 3 codes are related to the driver door.
B2578 and B2583 are related to the turn signal circuits. It is saying that it detects you have turned on a turn signal circuit but there is no pulsing of the voltage. This could be a Hazard switch flasher issue or an internal problem with the MF switch.
Based on the other issues with lights you could replace the MF switch first and see what that fixes. It certainly looks like the MF switch has issues for sure.
Now if you can perform electrical diagnostics then I can provide all the FSM info to figure out if it is the MF switch , Hazard switch, or another circuit issue.
If you need DIY on replacing the MF switch, here it is. Some people try to take it apart and try to resolve their issues.
https://www.corvetteforum.com/forums...-a-how-to.html
The last code is related to the Theft Deterrent system and fuel shutoff.
You can try deleting your codes and see if any come back. You never told us if they were H or C. If you turn the ignition OFF and then pull the codes they will almost all show as H.
Old Jul 22, 2015 | 10:50 AM
dadaroo's Avatar
dadaroo
Your statement is true. I was just keying in on once your turn the ignition OFF then most all codes you later pull will show as H. Would have been better to say pull codes BEFORE you turn the ignition OFF which is what I normally say. But I'm not entirely normal, you should know that.
Thanks again Chuck.
To electrical
