Harmonic balancer
Old Dec 12, 2017 | 12:06 AM
  #41
Millenium Z06's Avatar
Millenium Z06
Moderator
Originally Posted by GoldenFlame
I'm sure your internals will love that impact gun
You use the gun to remove, if necessary. Guess you missed the torch to heat the bolt 1st.
Old Dec 12, 2017 | 12:09 AM
  #42
Millenium Z06
Moderator
Originally Posted by SG Lou
I have a HB replacement in my near future...only thing I dread is being able to get that 240 lb/ft of torque while lying on my back with the car only 2 feet off the ground, not to mention finding a torque wrench that can achieve that torque !
Get the longest torque wrench you can find, I torqued it from the top passenger side with the car in 6th.
Old Dec 12, 2017 | 07:31 AM
  #43
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
I had my car on "blocks", located underneath the jacking points, and had my car 18-20" off the ground, when I replaced the HB. I couldn't generate the required torque, while underneath the car, so I stood on the drivers side of the car, and pulled the wrench toward me, in order to get to 240 ft/lbs (ARP bolt).
I bought a Husky torque wrench at Home Depot, for this job, and haven't used it since. Yeah, I probably could have "borrowed" a wrench from Advance Auto Parts (where I worked part time, at the time I did this job), or Autozone, but seeing the "amateurs" that borrowed tools from the store, and the way they treat them, I figured that one of those wrenches wouldn't have been anywhere near calibrated correctly, so I bought a new one.
I spent $400 to buy an ATI balancer. There's NO WAY that a torch is getting anywhere near it.........
Old Dec 12, 2017 | 07:59 AM
  #44
vettenuts's Avatar
vettenuts
Lot of bad information in this thread. The lubricant is used on the threads and the underside of the bolt head to ensure the proper preload in the bolt (some call it stretch, but it is really a joint preload). You can achieve the correct torque value no matter what you use, even peanut butter. However, it doesn't provide the proper preload.
Torque is one of the most inaccurate methods of preloading a bolted joint. The biggest factor of these inaccuracies is the friction. ARP uses their own lubricant and method of application to ensure the friction is controlled in such a manner to achieve the correct bolt preload.
If the bolt is backing out, there are other issues with the joint. Not sure how many (and I would wager it is few if any) determine the interference fit prior to installation of the balancer hub. ARP is very specific on the interference fit and it falls within a range of 10,000's of an inch. Most won't have tools to properly measure. Point is, if the bolt backs out the interference fit is more likely the cause and not the bolt. If you spun the prior balancer hub, the interference fit may have been affected. The bolt is likely the symptom and not the cause.
Old Dec 12, 2017 | 10:00 AM
  #45
pjdbm's Avatar
pjdbm
I have read and saw vids on heating the HB with a torch, I would never do this.
Heating up a HB that has a rubber bond between two metals is something I would never do.
Also, sliding that hot HB into the front seal and possibly warping the seal is a second reason not to heat up the damper prior to install.
I purchased the correct tool to remove and install this damper and the job came out perfect.
Old Dec 12, 2017 | 12:16 PM
  #46
lane_viper's Avatar
lane_viper
I heated my balance in the oven before I put it on to about 150 degrees. Remember, the oil seal probably sees temps hotter than that regularly. I would def say the balancer sees temps around the 150 range when you drive in stop and go traffic.
Old Dec 12, 2017 | 08:23 PM
  #47
GoldenFlame's Avatar
GoldenFlame
Your car, your problems.. Guess you can use JB Weld to hold it next time
Old Dec 13, 2017 | 07:08 AM
  #48
leadfoot4's Avatar
leadfoot4
Old Dec 13, 2017 | 11:17 AM
  #49
radar502's Avatar
radar502
If one can follow instructions . I did a cam install on my 04 Z ported heads ( Myself) lots new parts ,even remover and replaced the old pulley .. The pulley was a bitch for sure but a 6' 3/4 pull handle an old 12" pipe wrench and 4 friends we got it off.. Made a puller got that off you tube as well .. All this info is on YouTube and in this Forum . Just saying read and follow the instructions , 30,000 miles 500+ Hp later NO problem .. APR sends the lube and the how to install read it do it .. Some have made this sound Way tooo hard to do ( TORCH ) what . Just saying all this info is out there and the right info not some old I think you should do this or that . Just look it up and pay attrition and if go get a torch you did not pay attention . These Ls-motors are not the old 283s from back n the day ,that train left the station . Its a new day ,people sound like they are creating problem that are very unnecessary .. These LS-motors are very easy to work on making way hared they needs to be .. If I can do it anybody can .. If going to give some info on the forum make sure you know what in the heck you are talking about ..
Old Dec 16, 2017 | 11:53 AM
  #50
Millenium Z06
Moderator
ATI's own instructions suggest heating the balancer in an oven prior to install, secondly, IF it needed removal, you'd be heating the bolt head, not the balancer. A propane plumbing torch isnt going to get hot enough to damage the balancer anyway
Old Dec 16, 2017 | 11:56 AM
  #51
Millenium Z06
Moderator
Yeah, some dont get that, warp a crank seal...OK
Old Dec 16, 2017 | 12:50 PM
  #52
pjdbm's Avatar
pjdbm
If you use the proper install tool there is no reason to heat it up, PERIOD!
Old Dec 16, 2017 | 01:55 PM
  #53
Millenium Z06
Moderator
Well, I agree with that, I used ATI's instructions the 1st time and the correct tool. The next time, I just used the install tool and had no issues.
Old Dec 16, 2017 | 03:31 PM
  #54
feeder82's Avatar
feeder82
here's the torque wrench ya need for this job
Old Dec 16, 2017 | 06:06 PM
  #55
SG Lou's Avatar
SG Lou
Attachment 48235809
HOLY CRAP
Old Dec 16, 2017 | 07:26 PM
  #56
Millenium Z06
Moderator
Attachment 48235809
Thats essentially how I did it from the top. My torque wrench is almost 3 feet long. That thing you have is a monster. Semi truck wheels?
Old Dec 18, 2017 | 11:54 AM
  #57
thbwlZ's Avatar
thbwlZ
Thank you for this ACCURATE post.
There's a lot of misunderstanding about bolted joints and what is actually happening.
To Harmonic balancer
Old Dec 18, 2017 | 12:09 PM
  #58
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
We used a torque wrench about the same size. The 1st one we did I stood on the brake with the car in gear. The 2nd we purchased a flywheel holder, much easier. You can get the flywheel holder off Amazon.
Old Dec 18, 2017 | 12:18 PM
  #59
ASRoff's Avatar
ASRoff
ok I have spent THOUSANDS of hours torqueing bolts over the years on things that are WAY MORE CRITICAL than a dampener hub....everything from 35 inchlb worm clamps to 18,000 ftlb "jesus nut" (17* to 20* angle) that we have to use a hydraulic wrench to acheve the torque. Vettnuts is ABSOLUTLY 100% correct. Use the PROPER ARP lubrication to get the PROPER preload on the bolt and it should not back out. if the bolt does back out...... there are three possibliltys. the most common is false/bad torque meaning the user of the torque wrench hit something (a stud or subframe or some other part) and created a false torque. 2. bad /distorted threads meaning cross threaded or rolled threads. and last 3. improper heat treat of either the part or the bolt. At work our torque wrenches, mic's calipers and temp probes get re-calibrated. if you can take your home torqe wrench and get IT calibrated may are off quire a bit. OH! my line of business? I build Jet engines for General Electric...... so yeah.... it has to be CORRECT.
Old Dec 18, 2017 | 02:56 PM
  #60
leadfoot4's Avatar
leadfoot4
Originally Posted by ASRoff
........ At work our torque wrenches, mic's calipers and temp probes get re-calibrated. If you can, take your home torque wrench in and get it calibrated. Many are off quite a bit....
That's one of the "fringe benefits" that I missed, after I retired.
