Elec. Question.
Old Mar 1, 2018 | 08:09 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
IF,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, , I had to bet all the marbles, Ide say bad sensor.
BUT,,,,,,,,,,,,, If it were me, I would remove the one in there NOW and test it just like the Vid.
I like to PROVE the fault.
Bill
Old Mar 1, 2018 | 11:37 PM
pcfred's Avatar
pcfred
St. Jude Donor '05
Still could be ignition switch or wire moving and shorting.
Old Mar 2, 2018 | 10:42 PM
Dennis Wilson's Avatar
Dennis Wilson
Picked up a new Delphi sensor today. (made in America) Will throw it in in the morning, and keep my fingers xxx. D.
Old Mar 3, 2018 | 12:44 PM
pcfred's Avatar
pcfred
St. Jude Donor '05
Dennis, double check wiring while you're at it.
Originally Posted by Bill Curlee
I had a wire issue that blew fuses when I went FULL THROTTLE
Here was the culprit: A pinched wire. Easily fixed once I opened the harness and looked for it.
The PINK wire is 12 VDC Switched power for one bank of coils.
SUCKS HARD to have to drive the car on SIX CYLINDERS when that fuse blows!!
Old Mar 3, 2018 | 01:18 PM
Dennis Wilson
So, If it threw code PO118 (high voltage) with the connector disconnected, and connected with paperclip, and PO117 (low voltage) with the sensor completely disconnected, Does that deem like the prob. is in the sensor? Thanks, D, P. S. The thing that throws me , is how it will run fine for 3-400 miles each time before prob pops up again?
Old Mar 3, 2018 | 04:23 PM
Dennis Wilson
OK, I cleared codes, unhooked batt. installed new coolant temp sensor, hooked batt. up started car, coolant temp flashed xxx for couple seconds. then went to normal, car running normal , ran codes, only had a BO 605H . Cleared it. Car has been running for 10 min. now Coolant temp. at 180 deg. everything is normal. so far. Can`t find code BO 605 anywhere. ? D.
Old Mar 3, 2018 | 04:28 PM
Dennis Wilson
Might have been PO
Old Mar 3, 2018 | 04:43 PM
Dennis Wilson
CRAP!!! Went out to take car for drive, Turned Key, would not start, Ran codes. NO CODES! Tried again. Started , ran normal, But DIC read oil temp low! Still no codes, all other gauges normal seems to be running normal. Just says oil temp low. hope this will gave us a hint to the prob. Things def. changed after the new coolant temp sensor installed, Maybe time to think ign. switch. ?? Thanks again !!! D.
Old Mar 3, 2018 | 05:00 PM
Dennis Wilson
Just went back Car hes. then started oil temp normal, all other temps normal had code PO118C. Shut off, Started back up, Everything normal, Code gone. Waited few minutes went out started normal, no codes, Thinking ign. switch more possible all the time, it has been the only moving part this morning so far.
Old Mar 3, 2018 | 09:16 PM
pcfred's Avatar
pcfred
St. Jude Donor '05
Ignition switch I'm willing to bet due to the fact you get a no start here and there.
Old Mar 4, 2018 | 03:31 PM
Dennis Wilson
Ordered new AC Delco ign. switch from Rock Auto. Should be here in 4-7 days. What is the trick to getting key cylinder out of old switch and into new one? Don`t want to mess it up! Thanks, D.
Old Mar 4, 2018 | 08:47 PM
pcfred's Avatar
pcfred
St. Jude Donor '05
Here's the writeup on ignition switch from the Man, the Legend, Mr. Curlee.
Scroll down the post and you'll find instructions on removing the switch.
https://www.corvetteforum.com/forums...ch-repair.html
Old Mar 4, 2018 | 09:15 PM
  #33
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Thanks!!
Bill
Old Mar 4, 2018 | 11:20 PM
  #34
Dennis Wilson
Thanks guys! I just need to know if there is a trick to getting the key cyl. out of old switch, and into the new one? Might there be instructions with the new switch? I saw a post where the guy had all the little parts fall out of the cyl. when he got it out. Thanks so much for all the help!!! P. S. What do you guys think the odds are that the switch is the prob.? After all the symptoms I have had. D.
Old Mar 5, 2018 | 05:04 PM
  #35
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Remove the entire Cylinder/switch assy from the dash. Put the key into the cylinder, turn it to ON/RUN.
There is a small tab inside a small window on the plastic body of the assy. Press in on that tab and the lock cyl will come out.
Switch being the cause of the lssue. Scale of 1-10 10 being 100% the cause: My rating = 1.5
Bill
Old Mar 5, 2018 | 07:22 PM
  #36
Dennis Wilson
Bill
Thank you Bill! poop! I was hoping for better odds than that. Time will tell.
Old Mar 5, 2018 | 10:53 PM
  #37
pcfred's Avatar
pcfred
St. Jude Donor '05
You'll get better odds from him once he has a couple beers
To Elec. Question.
Old Mar 6, 2018 | 08:16 AM
  #38
vinceg's Avatar
vinceg
Dennis this all started after header install an tune. Then a 200 mile run to Lone Pine. Damaged wires are a good chance. You were sometimes able to get things going after moving wires in left door. My 2 cents.
Old Mar 6, 2018 | 08:19 PM
  #39
Dennis Wilson
Ok Bill, here is the latest. Went out, started car, everything,normal, All temps normal, let run 10 minutes or so, Everything good. Shut off, and restarted few times.no probs. all temps good. Backed out to go around block, Got about few hundred feet, car misfires, oil temp on DIC. reads LOW. Went around block missfired a few times, Got in garage, left running, ran codes NO CODES! Shut off and restarted 3-4 times started normal, but oil temp still LOW! maybe the 4th. or 5th. time shutting off and starting oil temp back to normal! 180 deg. or so. Still no codes. couple more on & off`s and still everything is good. its a new oil temp sensor. couple months ago. D. The oil temp sensor wires are pretty close to the headers, But looked good when I replaced the sensor.
Old Mar 6, 2018 | 08:23 PM
  #40
Dennis Wilson
Thinking maybe I should look a bit closer at them. ?
