Black Jack C5
Old Apr 1, 2019 | 12:25 AM
  #101
bigsapper's Avatar
bigsapper
Round 3
Old Apr 1, 2019 | 12:30 AM
  #102
bigsapper's Avatar
bigsapper
Semi-finals
Old Apr 1, 2019 | 12:33 AM
  #103
bigsapper's Avatar
bigsapper
Finals
Old Apr 1, 2019 | 03:57 PM
  #104
bigsapper's Avatar
bigsapper
Originally Posted by bigsapper
I usually take a bunch of pics & vids at the track, but for some odd reason, my phone wasn't charging at the track. Weird.
Figured this out.
Whenever I have my phone plugged in to my head unit, Android Auto takes over my phone. That was interferring with me running Track Addict and logging/videoing my runs.
So I turned off my head unit. Guess that turns off power to the charging port too. :S
Old Apr 6, 2019 | 06:27 PM
  #105
bigsapper's Avatar
bigsapper
No pictures but I installed the 9011/9012 HIR bulbs and the RadioFlyers HI-4 harness today.
I *may* get their DRL upgrade kit. That would be *it* for cosmetic upgrades; I swear!
Old Apr 8, 2019 | 10:37 PM
  #106
FX VETTE's Avatar
FX VETTE
SUBSCRIBED!
Old Apr 17, 2019 | 09:42 AM
  #107
bigsapper's Avatar
bigsapper
Got my lab results back.
Engine...
Universal averages show typical wear levels for the 5.7L LS-1 after about 4,000 miles of oil use.
Copper (from brass/bronze parts) is a bit higher than average, but iron (from steel parts) stands out more.
Operational factors like heavy use or lots of idling can make extra iron, and iron from that sort of source isn't
an issue. Otherwise, steel parts are wearing a bit more than average. No contamination was found, and low
levels of silicon and insolubles point to proper air and oil filtration, respectively. This is a good report,
overall. Just check back on steel wear.
Trans...
We don't see anything in this sample that looks altogether concerning. Lead is a bit high, and while
maybe that could show bearing wear, it might also be from something temporary or harmless, so let's just
see how it trends, assuming you're not having any problems shifting. The rest of the metals look great,
particularly when you consider that the averages are based on just 35,000 miles. We'd believe this oil could
be factory oil. The viscosity was a little thin, showing it's been in place a while, but insolubles aren't too high,
so this was a perfect oil change interval.
Old Apr 18, 2019 | 07:57 AM
  #108
StickTail's Avatar
StickTail
Interested to see that DRL kit. What was your time in the finals?
Old Apr 18, 2019 | 08:08 AM
  #109
bigsapper's Avatar
bigsapper
Last run was ...
60' -- 1.955
1/8 -- 8.230 @ 87.46
1/4 -- 12.679 @ 109.88
I was dialed at 12.72. The other guy was racing me at the stripe so had me good. But I would've broken out anyway.
The problem with having such a shitty 60' is the other guy can catch you pretty easily and then just pace you the rest of the way.
Old Apr 18, 2019 | 10:12 AM
  #110
BudgetPlan1's Avatar
BudgetPlan1
St. Jude Donor '09-'10
Trans...
Yep, was waiting until 100k for tranny flush/change so still factory fluid in there. Probably factory washer fluid too...
Old Apr 20, 2019 | 04:57 PM
  #111
StickTail's Avatar
StickTail
Last run was ...
60' -- 1.955
Sorry didn't see you posted them earlier.
Your video brings back memories. I had a black 99 6 speed back in the day. Made it to finals up against a 69 Z28 race car on slicks lifting the front wheels.
Old May 25, 2019 | 09:13 AM
  #112
bigsapper's Avatar
bigsapper
I wonder if this means something
Old May 25, 2019 | 09:17 AM
  #113
bigsapper's Avatar
bigsapper
Not much to report. Missed the last two races. Another tomorrow but I probably won't go. Too busy enjoying my new pool.
I've got my ported LSX 92 manifold & LS2 throttle body from Tony Mamo. But they're just going to sit until I can budget for the install & re-tune.
A/C didn't seem to want to cool down the car after sitting in the sun. Guess I'll need to get that checked out. Makes sense. My house A/C just went out, too.
Old May 26, 2019 | 09:23 AM
  #114
BudgetPlan1
Did we forget to mention the car was also known as the 'Devil's Chariot'?
I always wondered why they had us sign the original sales contract in blood but figr'd it was just some peculiar policy of that dealership.
Interesting...
That (A/C) could be a problem in Texas, both house and car. Hopefully a relatively easy fix. We hadda replace total HVAC system in our house last fall as well; bitter pill but necessary.
Just uncovered pool and starting to clean it up.
I have cars I can't drive in winter, and a pool that is only usable 4 months a year...why I continue to live on Ohio becomes more puzzling with each day.
Pool was a mess when we pulled safety cover but getting there. Working for a pool company comes in quite handy at times, cheap chems.
Wife is really diggin' her new C7; using it to go everywhere. Rain, sun, warm, cold...true daily driver. Still, only 1200 miles as she only works about 3 miles away. A few trips to Columbus, once to Pittsburgh are the bulk of the miles.
Definately smaller inside but even at 6' 2" driving is comfortable for me but absolutely NO WAY I could ride as passenger on long trip. That side has very limited room for tall, lanky folks like me.
Old Jun 24, 2019 | 09:55 PM
  #115
bigsapper's Avatar
bigsapper
Looks like the A/C blows cold, just not getting thru the dash vents. I'll need to dig into that.
Old Jun 28, 2019 | 07:37 PM
  #116
BudgetPlan1
Any new progress...besides what sounds like a blend door possibly dead?
Old Jul 1, 2019 | 07:47 AM
  #117
bigsapper's Avatar
bigsapper
Unfortunately no. Trying to run down what I'll need to upgrade if I run flex fuel. Not sure how big an injector I'll need with a H/C & E85. And not sure if that's going to necessitate a fuel pump upgrade.
Fantasizing about a head & cam package.
I'd install the intake & throttle body, but I don't have funds for a re-tune, at the moment.
To Black Jack C5
Old Jul 20, 2019 | 06:51 PM
  #118
bigsapper's Avatar
bigsapper
New mod update!!!! Finally got my Flameball!
Used the SickSpeed adapter.
Flameball ... MAKE SURE YOU GET THE MANUAL WITH OVERSIZE THREADS!
I love it with the light inside, but I don't see that I could run the wires with this adapter, so I didn't have it drilled for the light.
Always run a flameball in all my cars.
Old Jul 20, 2019 | 06:57 PM
  #119
bigsapper's Avatar
bigsapper
So this looks like something I may need to
address sooner rather than later...
Car was running 203* water temp (with a 160* t-stat).
Oil temp was 194* and trans temp was 194*
Need a Dewitts radiator?
Old Jul 20, 2019 | 07:24 PM
  #120
BudgetPlan1
