Headlight Ninja needed!
Old May 22, 2019 | 06:36 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Position the headlight switch to the OFF/CLOSED position. Pull the fuse for the headlamp control unit. MANUALLY close the head light using the manual ****. Crank it down nice and tight on the lower stop. Insert the fuse and see if it will stay shut.
Old May 28, 2019 | 10:14 AM
jjc508520's Avatar
jjc508520
I tried this and it did not work (removing inside fuse #52). But I noted that you said to "crank it down nice and tight on the lower stop" - in my case - when the doors are closed - the lever is resting on the upper stop not the lower stop.
If you scroll up and look for my "A and B" pictures - the "A" picture shows the lever hitting the top stop - this is how I'm oriented when the door is closed.
Do I have the lever improperly installed?
Old May 28, 2019 | 02:24 PM
jjc508520's Avatar
jjc508520
I just spoke with the people I purchased the motors from - they suggested I simply reverse the 2 wires that run down to the motor from the harness - this sounds simple enough.
Should the new ballasts have insufficient resistance I'll look at other posts for guidance
Old May 29, 2019 | 05:03 PM
jjc508520's Avatar
jjc508520
Success!
Old Jun 3, 2019 | 05:53 PM
jjc508520's Avatar
jjc508520
Polarity on the motors switched and resistors installed - it works
Old Jun 5, 2019 | 08:04 AM
jjc508520's Avatar
jjc508520
Annnnndddd one of the Chinese housings cracked while cranking on the adjusters
I've contacted the "well-known vendor" who sold me these repaired units at a discount to see if we can work out a swap for the better units and just be done with it.
You get what you pay for people - don't cheap-out.....
