Tunnel plate update, please read
I did have to loosen the passenger header to get it in there but once tightened back up, there were no fitment problems.
This is on an 02 vert.
No problems with the LAPD plate and my LG's.
I find it really amazing that there is only 1/8 clearance between the 02 sensors and *any* plate. I do realize that the stock plate is recessed, where as the aftermarket plates sit lower than the additional thickness would indicate.
But my point remains.. IMHO I think LG (and whomever) is playing with these clearances a bit too much, and there should certainly be an additional 1/8 inch if required.
It also needs to be mentioned that the clearance can vary from vehicle to vehicle. A slight twist of the exhaust piping while bolting in place can produce a variance.
