1990 Vett Problem
Old Nov 25, 2004 | 12:49 PM
tramminc's Avatar
tramminc
Default 1990 Vett Problem
My Frends Car Motor Is Stock No Work Done In 14 Years, Motor Shakes, And Hessitates While Driving, I'm Having Him To Being It To My Home As A Winter Project,
Question Will A Car Of That Year Show Codes?
3 Years Ago He Did Take It To The Dealer After 2 Days They Coundn't Find The Shaking And Stalling Problem. I Went With Him To Get The Car And We Saw 1 Reason They Coundn't Fix It Because They Had 2 Kids With The Service Manual Opened On The Hood Stairing At It. Would You Beleave They Tryed To Charge Him For That, He Got Mad A Took His Car Out Of The Bay And Told Them What To Kiss. (never Payed)
Old Nov 25, 2004 | 01:17 PM
Goody's Avatar
Goody
Post this in the C4 section for more replies. This is the C5 section. That sounds like a miss and it may or may not set a code simply because it is older technology and it would just depend on what the error is. If it is monitored by a sensor it will set a code. If it is a bad plug then it might not. You may get something else related to it like a lean or rich condition.
Poor idle performance can be a multitude of things:
Bad gas
Vacuum leak
Poor spark (wires and plugs)
Poor tune up (timing)
Blown head gasket
Timing chain slipped
lifter malfunction
poor valve spring function
throttle body gunked up
power enrichment slow to react
clogged injector(s)
No work done in 14 years?? If that is true I'm surprised it still runs at all.
Your friend should be happy the service techs had the service manuals out. If you work on it without the Helms manuals are you any better then them? The manuals are there for a reason, not something to collect dust with. You think they have all these different manuals memorized? A dealership can have a car for a couple of days because they aren't going to just drop everything they are doing to start a new car. They clear out the customers on a first come first serve basis. Now if you called ahead to make an appointment I can understand being a bit peeved. Car repair takes troubleshooting at times because the fix isn't so obvious more often then not especially as cars have become more complex......maybe they were out of IBM Pixie dust.
Old Nov 25, 2004 | 01:25 PM
tramminc's Avatar
tramminc
They Said They Had No Idea What The Problem Was, I Forgot To Say This Was The 2nd Visit With The Car To The Dealer
Old Nov 26, 2004 | 12:14 AM
GrayC5's Avatar
GrayC5
Yes, the people over in C4 Tech/Performance would be in a better position to help you than here in C5 Tech. Good luck with the fix.
Old Nov 26, 2004 | 07:44 AM
vettenuts's Avatar
vettenuts
Car is OBD I and will show a limited number of codes, not as sophisiticated as a C5. Some important things, like a bad distributor cap won't show up as a code.
Old Nov 26, 2004 | 09:14 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I forget if that car has OPTI Spark or a standard Distributor. The very first thing that you need to do is change the plugs and wires. If you do not change the wires, at least check them with an ohm meter. They should rear 2000-3000 ohms.
OBD1 cars will show codes and all you need to do to read them is jumper terminals "A" + "B" together with a piece of wire and the "CHECK ENGINE" light will flash out the codes. First code that you will see is a 12 code which is normal and will always be displayed. It flashes each code three times and then moves on to the next code. It wil end the code session by flashing the 12 code again three times.
If the car has been running that bad for that long, you may have BAD CAT"S If they are clogged up the car will idle fine but will not run well or at all at higher RPM.
You should get lots of help in the C4 section. If not, you can PM me. I use to have an 85 coupe!
Old Nov 26, 2004 | 02:37 PM
Mike Mercury's Avatar
Mike Mercury
WOW; it's been 17 years since I last tried to repair something on a C4.
Probably best to post this in the C4 section.
Old Nov 27, 2004 | 12:10 AM
tramminc's Avatar
tramminc
thanks
Old Nov 27, 2004 | 12:13 AM
tramminc's Avatar
tramminc
thanks bill
Old Nov 27, 2004 | 12:47 AM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06-'07
as a ex c4 owner i would do this
Plugs and wires cap rotor
replace fuel filter and check pressure running 38psi
Clean throttle Body they are always nasty on a C4 tpi car
it is more than likely not a computer related issue.Spark/fuel/or air intake system. Doesn't hurt to replace the IAC valve on throttle body they get sticky.I used to tear the top intake off my c4 all of the time when i first got it.PM if if you need any help.
Old Nov 27, 2004 | 12:49 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Some more good info!!! You can PM me also!
BC
To 1990 Vett Problem
