anyone else want a real key ---> RANT
#43
Originally Posted by 2vettes
Don't want to hijack this thread, but fob batteries last a long, long time. My 96 collector edition has remote keyless access. More than 9 years on the road, and I have never needed to replace the batteries.
BTW, hope GM can figure out what your problem is and get it fixed pronto.
#45
Please Explain the Advantage of Push Button Start?
I don't really care one way or the other. Doesn't matter to me whether I carry a key or a fob....you have to carry something with you either way....right?
Seriously, I'd appreciate it if someone can explain the added value of the push button start.....?
#47
Originally Posted by coolcat
I don't ever want to go back to yesterdays technology. THE KEY IS DEAD!!!
#48
You just have to tap the starter button and it takes over. Kinda neat that you don't have to hold it down.
#49
If dense drivers constantly attempt to engage the starter with the engine running, it will booger the flywheel ring gear and the starter pinion gear. Usually the damage won't keep the starter from functioning, but cranking will begin to sound junky.
With the push button start, pushing the button latches a relay until the starting sequence is completed. I suspect that pushing the button again won't do anything if the engine is already running. It only makes sense that they designed the control system to lock out any start activity with the engine running, but I don't intend to try it...anyone tried this yet?
#54
Originally Posted by corvette pilot
mine's done that a couple times, but I realized I didn't have the clutch completely in, just almost in.
#55
Its called progress. But sure, you can get through life with none of the above.
#56
Originally Posted by EB20003
The difference is that you do not have to remove that something from your pocket.
To the rest, thanks for sharing. Now I need to get dressed...neighbors have asked that I go back inside before day break on weekends.....
#57
Alright smart ***....what if you aren't wearing any pants?!
#58
Have had 1 message one time when I turned off the engine. Got the no fob message. Took the fob out of my pocket and everything was okay.
Wouldn't trade the keyless unlock & keyless start for anything. I frequently get into or out of my C6 with both hands full. Don't have to bother looking for the car key.
#59
Cruise-In VI, VII & XII Veteran
St Jude Donor '07-'08-'09
