!!! C6 RATTLES NOISE GUIDE !!! - All Members Feedback Required
Old 09-08-2011, 11:26 AM
  #141
talon90
Support Corvetteforum!
talon90's Avatar
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
I'll help where I can but my '05 with 32,000 miles has no rattles. The only area where I have any vibration is with my aftermarket radar detector which is attached to the sunvisor.
talon90 is offline
Old 09-09-2011, 12:31 AM
  #142
Jimsan
Jimsan's Avatar
05 Coupe, 18,800 miles, no rattles, still have roof "pops' during acceleration.
Jimsan is offline
Old 09-09-2011, 02:17 AM
  #143
paganharley
paganharley's Avatar
St. Jude Donor '11
05 vert 55k no rattles.
paganharley is offline
Old 09-09-2011, 02:23 AM
  #144
tclhb
tclhb's Avatar
07, 30k miles and no rattles. My 2004 Nissan 350Z was full of rattles. I traded that in for the Vette. Great move!
tclhb is offline
Old 09-09-2011, 04:25 AM
  #145
kemomek
kemomek's Avatar
My 08 with 13,000 miles and no squeaks or rattles at all !
kemomek is offline
Old 09-09-2011, 06:39 AM
  #146
LloydP
LloydP's Avatar
2010 with 5000 mi. I had a minor rattle at idle. One of the springs that supports the exhaust was loose. Bent the tab a little to keep it under tension. No other rattles. I installed the insulation kit and it is much quieter inside now.
LloydP is offline
Old 09-09-2011, 07:08 AM
  #147
FortMorganAl
FortMorganAl's Avatar
Location: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
I've added 25K miles since my first post to this thread over 3 years ago and still no rattles.
Sometimes old dead threads get squeaks and rattles also. How do you fix those?
FortMorganAl is offline
Old 09-09-2011, 07:15 AM
  #148
Street Rat
Street Rat's Avatar
2008 Z51 Coupe with 35,000 miles. The RR speaker trim is driving me crazy with a squeak. I'm thinking I'll pull the trim and felt or putty the clips. Any suggestions?
Street Rat is offline
Old 09-09-2011, 09:52 AM
  #149
Boomer111
Boomer111's Avatar
No rattles here either, creaks and buzzing yes. 08 21,000 miles. Changed out the end links they kinda of rattled but this was under the car not in it.
Boomer111 is offline
Old 09-09-2011, 11:09 AM
  #150
Eppieguy
Eppieguy's Avatar
My passenger door rattles over every bump. I removed the door panel and can't find anything loose. It's driving me !!!
BTW 2009 w/ 9k on it.
Eppieguy is offline
Old 12-29-2012, 02:21 PM
  #151
faychinc6
faychinc6's Avatar
Default C6 noisey creaking hatch fix.
Originally Posted by djfullshred
Just to add some useful info...
I have found that the plastic interior panel on the rear halo (b-pillar) on my car creaked because of some foam insulation that is rubbing inside. This foam piece is glued on the inside of the panel.
I strongly believe that some of the 'clicking' noise I hear is from the metal clips on the panel that push into the halo. The noise went away when I took the clips off, but then of course the panel is not secure, so I can't leave it like that.
A vibration noise was being caused from bolts in the halo assembly that needed tightening up. That was a LOUD vibration noise at freeway speeds.
The windows rubbing were the notorious weather stripping issue.
My front dash squeaked because one of those damn metal clips was rubbing in the slot under the dashboard. I pulled the clip off, and the problem went away. The piece is looser now, but at least it doesn't squeak anymore.
My driver door will get pulled off soon, as the rattle in there keeps getting louder and more constant. It started at first with just the bass sounds from the speakers.
I fought a top/hatch creaking noise all last summer. My C6 2005 was quite for 20,000 miles and then started a cracking noise on hot days and got worse in time. I siliconed all the stripping and adjusted the hold down bumpers for no help. Finally recalling that my 2000 Z28 camaro hatch thumped when I went accross a bump, I started to look at the hatch. It creaked at top of travel when I opened and closed it. Seeing the four bolts at the top, I tightened them a quarter turn each just to see. Guess what rattle gone for the last four months from hot to cold weather on a daily driver. I hope this helps others. This is a great post and I wish I would have found it much earlier.
faychinc6 is offline
Old 12-29-2012, 05:14 PM
  #152
rpm462
rpm462's Avatar
08 coupe, little over 50,000 miles and counting.
Have the creaking popping top I havent been able to quiet yet. Already tried the o-rings and lubing everything with dieletric grease. Guess I'll try that c-clip thing next.
Also have a rattle at the upper part of the instrument cluster bezel. Already pulled it off once and put some padded tape in there but still does it. Guess when it warms up a bit I'll pull it off again and add some more.
rpm462 is offline
Old 12-29-2012, 05:20 PM
  #153
larrymcgraw
larrymcgraw's Avatar
2006 z51...Creaking popping top. Tried number of things but it seems to always reappear. Otherwise a great car!
larrymcgraw is offline
Old 12-29-2012, 05:37 PM
  #154
not08crmanymore
not08crmanymore's Avatar
Did you guys notice this thread started back in 2008 ?There is a wealth of info up in FAQ section and there is or was a TSB and a warranty replacement of the latches too.I just had mine done on my 13000 mile 08 a couple of months ago with the help of GM customer service since I was out of warranty but had just bought the car last March. In the mean time,there is a white grease available at the Honda dealer parts depo that quieted down the noise on my last 08 to almost nothing until I had the latches done under warranty.I forget what it's called.Put the stuff in the holes and on the inner latches.Then there is the small "o" ring fix.They are available at Loewes or Home Depot for a buck or 3 and fit right by the "ball" on the latches. And if you have painted tops,there's a recall for separation on those.
not08crmanymore is offline
Old 12-29-2012, 06:32 PM
  #155
ATC399
ATC399's Avatar
1045 miles no rattles...lmbo
ATC399 is online now
Old 12-29-2012, 06:36 PM
  #156
CaryBob
CaryBob's Avatar
Originally Posted by obaidan
No one has rattle issue?!!!
The entire car shudders, rattles, and flexes. Interior rattles are minor compared to that.
CaryBob is offline
Old 12-29-2012, 06:38 PM
  #157
Brian2010
Brian2010's Avatar
Roof ceaked a little.Put grease on went away.
Brian2010 is offline
To !!! C6 RATTLES NOISE GUIDE !!! - All Members Feedback Required
Old 12-29-2012, 06:54 PM
  #158
BLU JET 07
BLU JET 07's Avatar
'07 C6 with 32K on the odo and only has the occasional roof creak/ popping on drivers side. Occurs mostly when the weather gets warmer. Usaully just reapply silicone grease to the roof seals every spring seems to quiet it down and so I live with it. Eventually will do the E-clip repair......
BLU JET 07 is offline
Old 12-29-2012, 07:46 PM
  #159
gwalsh88
gwalsh88's Avatar
I have a 2012 GS coupe. When my mild to wild switch is open I get an annoying rattle at the B pillar on both the drivers and passengers side. Sometimes just one or the other and sometimes both at the same time. Close my exhaust and it goes away. It is very annoying and I’m afraid the dealership will only make it worse.
gwalsh88 is offline
Old 12-29-2012, 09:50 PM
  #160
K B Vettin
K B Vettin's Avatar
i had rattles but bought a egg crate bed pad from wal mart for $20 cut it up and put it in every place i heard a vibration/rattle and haven't had any issues since.
K B Vettin is offline
Quick Reply: !!! C6 RATTLES NOISE GUIDE !!! - All Members Feedback Required
