Navigation sucks!!!
when the goofy nut case from GM called me to do my post purchase survey she was so intent on reading from her script I had to repeat three times that my only complaint was the Nav POS.
People expect the stock nav to be as easy to use as a garmin. It clearly is not that.
I have found that the GM nav is far more sophisticated than any of the many Garmin's I have owned and once I learned how to use all of it's capabilities I was very pleased and really like the integration into the HUD of the nav info. That is something because there is no HUD integration available with any of the aftermarket units. That is one feature after using it for a year I just will not give up.
I had the Kenwood touchscreen with the Garmin interface in the convert I sold last summer and it worked fine but it was not nearly as integrated or sophisticated as the GM unit is.
Take the time to learn it and you will grow to really like and appreciate it.
100%I've used the Factory NAV in my 09 since new.
Yes it was a little slow learning at first, but after that no problem.
At one point I got brain washed by all the Negative posts on how bad the Factory NAV is supposed to be.
So I was able to try a number of aftermarket units and they were not just cheap one dimensional units either.
Yup, they all worked great and easy to use, but that's where they ended.
Being used to all the capability of the Factory NAV, I found None of the other NAV units came close to the capability of the Factory NAV.
Sorry, but IMO the only thing wrong with the Factory NAV is learning how to use it
Perfect? No.
Still our favorite? Yes
100% I also was brain washed with negative comments about the nav when I first came upon the forum before becoming a member. Then I took some time and learned how to use the unit. It is not perfect, but it is pretty good and quite capable.
I also think the Corvette team placed the intelligence of the average Corvette owner high enough to figure the nav out also. They did not account for just how many people became used to the garmin units being so easy to use. No knock on garmin as they are great little units.
If you do not like a garmin hanging from your window or a after market nav stuffed in your dash, then the stock nav is a capable unit.
Sadly each choice has a negative. The garmin has to hang from your window or stick on something on the dash or cup holder. The after market looks after market. Then we have the stock nav that is not easy to use and requires DVD updates that are expensive.
Paul
Without exception. His Corvette website and business should reflect that.
When I put in a destination I get 3 choices to choose from.
From there I can see where and how each route is going to take me to my destination and make my choice.
Then if I see a segment that is not congruent to the easiest/shortest or what ever, I can change "only" that segment if I want, before starting my journey.
I will agree, it's not the NAV for everyone
And as petes Z06 says, other units are good and the Factory NAV is not the cure all..
But it is way better than most users will give it credit for and has more capabilities than most users even know about
The Factory NAV is simply underestimated and misunderstood
PS: you can also turn off the Split screen if you want
I have used the NAV on many of my road trips, and it has never let me down.
It always gives you 3 routes, and each of those routes can be customized, etc etc.
I like it best because it comes up on the HUD
If you read and try things per the Manual, it works just fine. There are a couple very good instructional articles on this forum, check them out also. I have GPS in every vehicle I own, both factory installed and aftermarket and they all have their quirks, but if you just work them a bit they all provide good results. I've had no issues with the factory NAV in my Vette once I read through and tried things out.
Paul
Unfortunately I will not be able to come to your seminar.
Thanks again,
George
