Bleeding ABS
Old Jan 21, 2018 | 01:24 PM
babby blue's Avatar
babby blue
Default Bleeding ABS
Are you ready for some football.good day everyone I need a little help with my brakes.i took my brakes apart and drained all the fluids out so now I need to bleed the ABS. I don't have a scanner to do it with.i would like to buy one but I don't know what kind to get or were to get one. I have looked at snap on tools but there again witch one do you get. I don't want to pay an arm and 2 legs for one. Any ideas thank you.its a 2006 vett all stock LS2.
Old Jan 21, 2018 | 03:36 PM
Dano523's Avatar
Dano523
I still prefer my Tech II to the VX GM nano, but if you just need a tech II type tool on the cheap to wrench on the car, then the GM nano may have you covered instead.
https://www.corvetteforum.com/forums...ternative.html
P.S, I'm in the Denver area, and could stop over to get you squared away with a Tech II, so you don't have to wait for slow mail to get the needed tool isntead.
Old Jan 21, 2018 | 04:59 PM
Corvette_Ed's Avatar
Corvette_Ed
I've said it before, and I'll say it again. This is what the Corvette Forum is all about.
Old Jan 21, 2018 | 05:01 PM
babby blue's Avatar
babby blue
Thank you Dano for getting back with me am very interested in what you have to say.maybe we can get together after the snow storm if you're interested. Ps can I give you my number on the form page or you can give me yours. Thank you again chuck
Old Jan 21, 2018 | 05:11 PM
subfloor@centurytrans's Avatar
Supporting Vendor
2024 C6 of the Year Finalist - Modified
2020 Corvette of the Year Finalist (track prepared)
2019 C6 of Year Winner (track prepared)
I've said this before (and gotten blasted for it) but I'll say it again anyway - you can bleed your brakes just fine without using a Tech 2 or any other scanner by bleeding them normally, making a few panic stops to activate the ABS and then bleed them again.
After doing my own several times I ended up having the dealership do it once to see if they felt any better - nope, they felt exactly the same.
And if you were curious as to how well they continued to work afterwards without using a scanner, I have no trouble slowing down on a regular basis from 130MPH at the dragstrip.
Old Jan 21, 2018 | 05:46 PM
mikeCsix's Avatar
mikeCsix
That's a pretty tremendous offer. Tip of the hat to you Dano!
Old Jan 21, 2018 | 07:00 PM
babby blue's Avatar
babby blue
Thank you that sounds pretty easy I would like to try it. But I don't have no brakes to stop going down the driveway.its down hill.lol thank you chuck
Old Jan 21, 2018 | 09:12 PM
Dano523's Avatar
Dano523
With a tech II, your completed with brake bleeding in a few mins all by yourself, including cycling the ABS pump to get the air out of it as well.
Hence brakes, special options, brake bleeding.
Old Jan 21, 2018 | 11:13 PM
Vet Interested's Avatar
Vet Interested
Worked for me.
To Bleeding ABS
