PLEASE HELP! Major car problem
Old Apr 3, 2018 | 10:55 AM
  #61
iw172's Avatar
iw172
From: Retired early,everyday is Saturday...Hocking Hills Ohio
similar thing happened to me when I separated from my crazy, ex-girlfriend. her Dad and a few of his thugs took a 454/400 turbo out of my ‘55 Chevy P/U. like you, I was playing nice and got totally fucked that day. I took the Sheriff w/me, a few days later, to where it was stored (while they had a huge barn sale going on) and got my **** back, after the Deputy threatened grand larceny charges. thank God I never knocked her up. Hang in there buddy...
Old Apr 3, 2018 | 01:13 PM
  #62
artz66's Avatar
artz66
Veteran: National Guard
Seems like a lot of money for an easy fix. Siphone gas/water out. Put in new gas. Crack fuel line and run pump until you clean fuel. Pull plugs and turn engine over a few times to get and water in the cylinders out. Put back together and enjoy.
Hope you recoup your money and it all works out.
Old Apr 3, 2018 | 01:57 PM
  #63
Yokesc5's Avatar
Yokesc5
did the water thing- ethanol gas with no stabl, moved one year later again-carbed bike.
that water -alcohol sets up a nasty white flim that can only be cleaned by scrubbing with an 90-100 % alcohol soaked cloth. My wifes arms were small enough but on vett tanks very time consuming, scrubb, let dry, inspect, scrubb again, mirror check the shadowed places, diy tools etc, $100 / hr dealer charges .also some oil in the cylinders, oil filters change any other place water might soak into, at the dealer?
Old Apr 3, 2018 | 02:53 PM
  #64
Speedthrill's Avatar
Speedthrill
Originally Posted by 87Z52
Certainly sorry to hear of your troubles. Question though...you said you had a full tank of gas? How was that much water able to be added to the tank if it was full?
Full tank of gas when stored...yes. But I don't fill to the absolute maximum...like beyond when the pump stops initially.
Old Apr 3, 2018 | 02:57 PM
  #65
Speedthrill
So finally spoke to her. She is admitting to taking stuff out of the house, but adamantly denies that she touched my car.
Is there absolutely any way that water could magically end up in the fuel tank....through natural means....when stored with 94 octane fuel, full tank, in a dry garage!??! I have stored every car I've ever had in the same conditions and circumstances, and never ever had a problem. I don't use fuel stabilizer or anything, but always full tank with quality fuel in dry garage. But I wanted to know if this is at all possible to have happen without tampering.
Old Apr 3, 2018 | 03:17 PM
  #66
LsLegacy's Avatar
LsLegacy
Yeah, natural as in someone put the water there. No there's no way condensation can form enough an amount to send a car with full 94 octane gas into whack.
She did something, of course she's going to deny, it's a corvette. proceed with the charges and don't let your feelings get in the way of justice.
  #67
Icecap's Avatar
Icecap
If you would have picked up bunch of bad gas with water in it at the gas station I'm fairly sure you wouldn't have made it home especially if they pumped 6" of straight water into a jar. That much condensation is also virtually impossible in a full tank and garage stored car. Last week I took our Vette out of storage. It has sat outside but sheltered and covered with a car cover and was hooked to a battery tender. It hasn't run for 6 months and has been exposed to temperatures anywhere from minus ten to the 40's Fahrenheit. It started right up and ran just as well as if I had just driven it yesterday.
Old Apr 3, 2018 | 03:26 PM
  #68
the kid C6's Avatar
the kid C6
But, what about the dog?
Sorry about the car. Break-ups can be very messy.
Old Apr 3, 2018 | 03:30 PM
  #69
dryadsdad's Avatar
dryadsdad
I've twice picked up some really bad fuel. Never fuel if you see a fuel truck refilling the station's tanks. That stirs up water, sludge and gosh knows what else and you pump it into your car.
I cannot see condensation creating nearly that much water, tho.
Old Apr 3, 2018 | 03:32 PM
  #70
artz66's Avatar
artz66
depends on how much fuel was in the tank when he tipped it off. Unlikely but there could have been enough fuel to get it home. I mean he backed it out and ran it for a little bit before it died. That’s more likely than he filled it full and she just happened to pour enough water in it to dilute it that much. She would have had to siphone fuel out and out it somewhere.
Old Apr 3, 2018 | 03:35 PM
  #71
ruxvette's Avatar
ruxvette
2016 C6 of Year Finalist
I would probably have an attorney write a letter to both the ex-wife and her parents and, describe the issue, not threaten, and list the possible ramifications to each party if legal action is initiated.
Just sayin.
Old Apr 3, 2018 | 03:41 PM
  #72
R&L's C6's Avatar
R&L's C6
Unless he can prove it was her (and he cant) it's a waste of time.
Old Apr 3, 2018 | 04:01 PM
  #73
mikeCsix's Avatar
mikeCsix
Ruxy's idea may bring results without having to go to trial. Sounds like she likes to play hard ball though. She or someone she knows most likely is the culprit. Since water is heavier than fuel, if you would have pumped bad gasoline into the tank you would have certainly noticed it within a couple of minutes of driving. The thing about water in the fuel, it can form some really small droplets that take time to come out of suspension. Those droplets though would have quickly made their way into your fuel system and to the engine. It is bad enough the engine ran on this emulsion, but be glad it was parked on not on the freeway someplace.
As for the water in the tank, there is no way I would run alcohol through the system to try to dry it out. The suspended water will still damage the injectors and detonate (as steam) in the combustion chambers. The best way to fix the problem is to drop the tanks and clean them out, then flush the fuel system all they way to the fuel rails and through the injectors. It's the steam that ruins engines and craters pistons.
There is such a thing as a fuel polisher. You see this from time to time on boats where condensation can be a real issue in fuel storage tanks. It is a sophisticated filtration system that traps the water when it is pumped out, then returns it to the tank, swirling the the contents. I've used both methods in 150gallon storage tanks on boats (diesel), so the hazards are not nearly as high as working with gasoline.
Good luck with your ex. If no kids its much easier and be glad of it. Better to find out now than 20 years from now.
Old Apr 3, 2018 | 04:27 PM
  #74
Wayne88's Avatar
Wayne88
Update. Had car flat decked to dealership. Explained in detail to treat forensically due to my suspicions. Got the call later in the day....drew six inches of water into the jar from the initial fuel line test. So confirmed at a minimum that water was put into my fuel tank. Will see if anything else comes up as they tear apart. But told me about $3k in work and parts at this point. Pull fuel tanks, clean out lines, injectors, plugs, etc.
I have already spoken with the police and got the info I needed to move forward with trying to file charges and will take to court for damages, etc. Beyond that...just want my car back and hope there isn't further damage.
Just saying: Maybe it wasn't her, you say her parents were there, maybe it was her father who did it, without her knowing it.
Women don't really know too much about cars.
Old Apr 3, 2018 | 04:43 PM
  #75
JasonAndrew's Avatar
JasonAndrew
So first of all, to set the scene. Just finishing up a separation from my wife. I went away for a day while her and her parents were clearing out some of her final things before moving out. I get a text a day early that they are done, leaving, and that she's taking one of my dogs. Try calling, no response. Get all the way home, and the bitch robbed my house and took my dog....and headed to the coast in Vancouver. I live 4 hours away.
So...today...trying to forget about what has happened. I decide to take my 2010 Grand Sport out of storage. Took the battery tender off. Started the car up....started right away no problem. After running a minute or two, backed it out into my driveway and left it running. Came back out after a couple minutes maybe, and noticed car running rough. Looked in car and whole bunch of service notices came up. Service active handling, traction control, ABS, etc, etc. Car started running more and more roughly...until finally it completely died. Tried starting it again, and just turns over through cycle of pressing the start button....and won't start.
So I thought maybe battery. Went and bought a new battery and installed it....what a ******* bitch on a GS or Z06 as people mentioned. Went to start the car again....same thing. Just turns over and over and won't start. Tried a couple times...no luck.
I'm trying not to think the worst here, but I definitely wouldn't put it past my wife to have put sugar in the gas tank or something. I checked at the cap...don't see any sign at all of any sugar crystals or anything, but I guess it's possible that could have been super careful with a funnel or something. I don't know. Pray to God that isn't the case.
Checked spark plug wires, all on....and as I said, it started up perfectly and ran right the first couple minutes before it started running rough and **** the bed.
Car ran perfectly when it went into storage 5 months ago. And started perfectly. But won't run at all now.
Anything I can be checking???? Car is stuck in the driveway now, because it's a fairly steep incline and can't get it back into the garage. And it's Easter weekend and won't be able to get it flat decked somewhere until Tuesday if I can't get it running.
Is it easy to check the fuel filter? Everything I read says if someone puts sugar in gas tank that it won't make it to your engine and destroy it or anything....that it would collect in fuel filter and not allow gas to get through. Full tank of gas when I put it into storage.
FML
Not everyone puts correct gas or stabilizer in the tank. How is the gas?
Old Apr 3, 2018 | 04:45 PM
  #76
JasonAndrew
Car was unlocked in garage. She put vinegar in my coffee maker, and in mouthwash bottle. Would vinegar in gas tank do anything bad???
Vinegar is used to clean a coffee maker. What did you do to her?
  #77
Corvette_Ed's Avatar
Corvette_Ed
Really now. They don't, huh? My oldest daughter is currently (yeah, right now as of this posting) swapping out a busted CV joint on her car. My youngest daughter, who can't even drive yet, can perform all regular maintenance on a car, including oil, trans, & diff fluid changes, swap spark plugs & wires, and drain/fill a radiator. She even helped me sand and polish a CAI for my C5 when she was 9.
Welcome to the 21st Century.
To PLEASE HELP! Major car problem
Old Apr 3, 2018 | 04:52 PM
  #78
JasonAndrew
THIS. I knew a girl up in washington who had to have her car pumped because the gas was mixed with water. Did you go to a cheap gas station? I use only Shell or BP.
Old Apr 3, 2018 | 04:59 PM
  #79
Mcrider's Avatar
Mcrider
You can't be serious to make a blanket statement like that.
Old Apr 3, 2018 | 05:01 PM
  #80
Mcrider's Avatar
Mcrider
You have a lawyer, the police are involved. Leave thes self proclaimed forum legal experts to bleat and just listen to YOUR lawyer and the police.
