Throttle Controller Popularity Poll
You're right.... It does help..... And you don't need to be an "engineer" to know it....
Sometimes the smarter people "think" they are.... the harder it is for them to see what's really happening.
Your foot CAN NOT do what the CoW BOOSTER! can do.....
The other point is that the CoW BOOSTER! is NOT a throttle control "device" or "fooler" like the others.
If you got it... you know what it does.
If you're an "engineer" then you'll appreciate (or should appreciate) why ALL competitors products are risky
and unsafe.
If you're one of the many people who has a "plug in" throttle controller that has "needed to be re-calibrated" or caused
no start or engine "REP" (reduced engine power), or random engine shutdown, or a device that just simply needed to
be replaced.....then you know what I'm referring to.
If you've seen evidence of "unexpected engine shutdown" on THIS and/or the CAMARO forums.... EVEN JUST ONE SINGLE INSTANCE....
then that should be enough to convince any engineer that adding cheap Chinese connectors, sub grade wiring, circuit boards that power LEDs,
and additionally fake or substitute actual pedal position data before it goes to the ECM, your engineering degree should tell you that those
products are trash. A 1% failure rate... which they have easily exceeded. should convince most people of average intelligence that, those products
are not at all safe.
GM spent BIG money to guarantee that the throttle blade of any LS or LT engine is EXACTLY where the computer expects it to be AT ALL TIMES
without exception, as the consequence ( if it's not where it thinks it is) is not just simply "reduced engine power" or "unintended engine acceleration"....
The consequence could easily be FATAL....So, the 1,000% safety margin (failsafe) action is to enter "reduced engine power" and shut the car down
should there be a problem with the throttle system.
Introducing cheaply made "faker devices" into a purpose built VERY tightly engineered calibrated system....IS JUST PLAIN STUPID.....
And you engineers..... should know this.
The CoW BOOSTER! is NOT like other throttle devices and FAKES NOTHING and has NEVER, NEVER messed up....Ever.
Some electrical engineer.... Please state your credentials and lay your license on the line here.....
And tell us that you would put your stamp on something like that, which already has shown a considerable failure history......
Oh, and if you fell for the "our engineers here in the USA DESIGNED AND BUILT this product"....shame on you.....
For anyone interested, please e-mail me and I'll send you some screen shots of the website in China that sells them for $1. each
if you buy 50 or more..... and the'll put YOUR name on the device if you buy a few of them.
Again, the CoW BOOSTER! is 1,000% safe and DOES NOT send false, erratic messages to the ECM potentially leaving you
in an unsafe situation.
Let's try comparing products that are the SAME next time..... Shoot me an e-mail....
Chuck CoW
and unsafe.
Chuck CoW
The Vitesse has been on my car for over 4 years and has never needed recalibration. It works just like it did when I installed it, and works in concert with the other changes I have made with HPT. Different choices are appropriate for different people, for reasons they can best determine.
BTW, throttle controllers don't change the acceleration/deceleration ramp rates of the stepper motor.
BTW....yes, it does...
Edit: In the interest of full disclosure, mine did take longer than 15 minutes to install because I put it in the ashtray compartment. Hooking it up and calibrating it took no more than 15 minutes.
I contend that the carrots would be fully cooked after 1-2 hours of driving -- making them useless for throttle enhancement.
BTW, are they covered or uncovered? Makes a bit difference as to how quickly they cook.
But having grown up driving 50s-60s era cars, there is a glaring difference when stomping the pedal from a standing start from those cars to a modern Vette.
FWIW: To me, it's not so noticeable (or annoying) once at speed and then stomping on it, it's mostly at a SS or very low speed.
If you don't know how to do it..... you can brick controllers. The competitors throttle controller has a failure rate easily 10,000 times greater than the
possible number of ecms failed during re-flash.... Still considering those non professionals and hobbyists....
There is no risk whatsoever with our flash process.... Additionally, I have 100s of these ECMs here and should anything ever happen to someone's ecm...
I just take one off the pile and replace it as simple as that....
BTW, I'm still waiting for one of the electrical engineers reading this to rubber stamp the Plug in throttle controller idea.... or maybe some of you
know better than GENERAL MOTORS engineers that designed the throttle system..... Please speak up.... Tell us that these plug ins are a
SOUND ENGINEERING PRACTICE......
BTW, if you're happy with your "american made" little box and wires from China.... Good for you. OH, where exactly is the manufacturer located???
A PO BOX in New Jersey?
Just asking for a friend.
Chuck CoW
Chuck CoW
I really don't care where it's made; it works just fine and that's all that matters. It's also very likely that the GM ecm is made in China, so I guess that qualifies them as junk? I purchased parts from China for almost 30 years, and just like in the US there are junk suppliers and state-of-the-art suppliers. You have to QUALIFY them prior to purchase order release.
I previously read the documentation about the Camaro, so why don't you fill the folks asking about it in on the details?
Do tell.
