Keyless Start
Old Aug 9, 2004 | 09:54 PM
  #41
Shylor's Avatar
Shylor
I understand the early years of the C4 also had this reverse thing. I just don't get why it has to be reverse. Why not 1st?
Old Aug 9, 2004 | 10:09 PM
  #42
glassfan's Avatar
glassfan
Originally Posted by Chief Pontiac
If you have a 6-speed you will be putting it in gear before you shut it off anyway right?
By putting the manual trans in reverse its the only way to turn off the ignition.This is to prevent accidental shutdown(locking the steering column) while driving.
I know your comment is 100% correct, but could you explain why reverse gear has something to do with the steering column????
Is the column lock problem solved with the C6????
Old Aug 9, 2004 | 10:57 PM
  #43
Vette_DD's Avatar
Vette_DD
I read in another thread in this forum that there's a different vendor for that equipment, so they think the problem is solved for the C6.
Old Aug 10, 2004 | 04:31 AM
  #44
jimman's Avatar
jimman
Originally Posted by wwashing
I'd suggest that your personal experience is anecdotal and does not represent a valid statistical sampling!
So do you think they picked reverse just to irk everybody?
In other words everyone else's including yourself is valid or are you just trying to tick me off. So how would you find the truth or are you just another arm chair quarter back with all the answers.
Old Aug 10, 2004 | 07:53 AM
  #45
Scissors's Avatar
Scissors
☠☣☢ Semper Ebrius ☢☣☠
Cruise-In IV-V-VI-VII Veteran
St. Jude's Donor '06
Because reverse is the shorter gear. Simple.
Old Aug 10, 2004 | 08:51 AM
  #46
Shylor's Avatar
Shylor
And that means what?
Old Aug 10, 2004 | 09:10 AM
  #47
Scissors's Avatar
Scissors
Shorter gearing is when the input RPMs are greater than the output RPMs. This results in it being easier for the engine to turn the wheels, giving torque multiplication and thus greater acceleration. This is why you accelerate better in first than in sixth gear. First gear has much shorter gearing than sixth. Same with the 3.15 axle versus the base axle on the automatic.
On the flip side taller gears, those which take fewer input revolutions per output revolution, result in less torque multiplication in exchange for output RPMs. These gears trade acceleration for speed capability.
In manual transmission C6es the reverse gear is the shortest gear of all. This makes it the easiest gear for the engine to use to turn the wheels. This also means that it's the hardest gear for an outside force to use to turn the engine, overcome the compression, and thus move the car. This is why shorter gears give the best engine braking: because gearing reverses when the input and output reverse. 9:1 when the engine turns the wheels becomes 1:9 when the wheels try to turn the engine.
Old Aug 10, 2004 | 02:20 PM
  #48
Lazerwolfe's Avatar
Lazerwolfe
From: I am Jack's out-dated Fight Club reference. MD
Why are people complaining about the Vette using new technologies? If we went by you guys, we'd all still be using cassettes because you're afraid of those new fangled "CDs."
Old Aug 10, 2004 | 02:38 PM
  #49
wwashing's Avatar
wwashing
There is an obvious improvement in CDs over Cassettes.
What is the improvement of the push button over the key?
Old Aug 10, 2004 | 02:54 PM
  #50
John George's Avatar
John George
From: All of the true things that I am about to tell you are shameless lies. --Bokonon
St. Jude Donor '04-'05-'07
No key scratches on the dash? Something new to lose? You can now say "I've lost my keyless access device."? Your friends won't ask for the keys to the car? You'll impress the women by starting the car with just a touch? Maybe you'll be able to do the same with them? (For political correctness choose the gender of your preference.) One less key to bang around on the keychain?
I'll give it a try. Like I have a choice?
Old Aug 10, 2004 | 03:15 PM
  #51
Matt Gruber's Avatar
Matt Gruber
the main advantage to keyless start?
i've had this feature for 29 years on my 61. it was standard on all 55-57 chevys too.
OK here it is, drumroll please!
I pull up to my house and i can hand my passenger my keys, and she can hop out and unlock the house door while i park.
Obviously you all have worked around this minor inconvenience, and i'm sure you will chime with clever solutions.
Old Aug 10, 2004 | 03:54 PM
  #52
jimman's Avatar
jimman
Good one
Old Aug 10, 2004 | 04:07 PM
  #53
beary58's Avatar
beary58
>>I pull up to my house and i can hand my passenger my keys, and she can hop out and unlock the house door while i park.<<
I use my keyless entry (garage door opener) to get in our house.
I like the keyless idea and look forward to it in my next car.
That reminds me, I need to get a battery on way home tonight or I will be locked out of the house.
Beary
Old Aug 10, 2004 | 07:12 PM
  #54
Shylor's Avatar
Shylor
Not complaining the C6 using new technology, just wanted to know why reverse was used to turn off the ACCY power to shut the car off.
Old Aug 11, 2004 | 06:09 AM
  #55
Matt Gruber
the bean counters saved $3 by combining ACC and OFF, using a reverse switch to create a virtual LOCK position.
the C7 will surely imo have an OFF switch and a seperate LOCK switch.(and the c7 will cost $$$$$$$ more as a result )
Old Aug 11, 2004 | 12:20 PM
  #56
Lazerwolfe's Avatar
Lazerwolfe
I didn't mean the push button specifically. I meant everything as a whole. The Nav, the door locks, etc.
First the Vette gets hosed for using old stuff (the Leaf Springs) which apparently work fine, and now it's hosed for using new stuff (push button start, door locks, et al.) because it'll be hard to break from the old pattern.
No one on here even has a C6 yet. It very well could turn out to be a nifty feature once it gets in the hands of people. But it (seems) like it's being ragged on just because people feel they won't be able to change old habits and put it in R instead of 1st despite the multiple warnings that will eventually get you to change anyway.
I could argue power windows are bad because I was so used to rotating the window lever that I don't think I'll ever get used to pushing a button down.
Old Aug 11, 2004 | 02:18 PM
  #57
Scissors's Avatar
Scissors
Not according to audiophiles.
To Keyless Start
Old Aug 11, 2004 | 02:19 PM
  #58
Scissors's Avatar
Scissors
Already answered. Several times.
Old Aug 11, 2004 | 02:24 PM
  #59
bramwellt's Avatar
bramwellt
Originally Posted by curvesman
Corvette junkie says the car will shut off in any gear?
They are wrong.
Old Aug 11, 2004 | 02:25 PM
  #60
bramwellt's Avatar
bramwellt
Originally Posted by Scissors
Pretty much eliminates the chance of locking your key in the car.
No fumbling for your key (for those with big pockets or who keep their key in their purse.)
Competition is doing it.
What key?
