Edelbrock E-Force?
You and I definitely have the same plan, I too am going with the interceptor gauge the way that Gotcha did his. I love the flush factory look that he did even though I am not excited about cutting into the dash. I can measure everything I need from that one gauge without the big triple pod.
LM_DIN 591.8/LR_DIN 494.9 on SuperFlow WinDyn V2.8
Got the German/US octane count mixed up so I had regular unleaded instead of premium..never again!
Also opted for a custom tuning aimed at sustained German Autobahn driving and lessening the torque management just a bit.
Also opted to feed both the BAP vacuum engagement switch and the NPP exhaust vacuum feed via the 1/8 NPT port - that's what is there for and it allow us to leave the brake vacuum alone.
Personal takes on the 1591 after installation:
Pros:
Great finish and professional build
Relative ease of install
Enough power and torque for me!
Save the obvious umph on the throttle I noticed minimal car Noise/vibration/whine behaviour changes which is what I wanted.
Heat - After few dyno runs before the final power meausurement the S/C unit felt extremely hot but after a three hour HGW drive and some city driving the unit felt much colder so I could verify good results on the cooling both at the gauge and the the touch.
Cons:
After a three hour HGW drive I resumed city driving and some "resonance" vibration/high pitch whine showed up and low rev acceleration but this morning it is all gone so for now I am going to associate it with normal "break in" behaviour.
Something has to give...Subjectively - this car has now lost that soft and smooth gentle shift and noise feeling at low revs.. - I know this begs for a laugh - obviously I cannot ask for extra 152 horses without something giving.
I may follow up with the tuner/Till and ask to revert to complete stock/TM to see what happens.
To me this E-force is a 8.5 out of 10 and yes I am a hard grader...I suspect the ZR-1 LS9engine feels like a 10 so I can leave with what I have for the price. Infact when I have my car at 200Km/h at sub 3000 RPM I feel great!
How do those dyno numbers translate to values that we are more accustomed to on this side of the world? Are those straight across horsepower/torque numbers or something else?
Another noticeable change I forgot to mention is gas consuption as I feel as I can almost see the gas gauge actually "move up" but could be my new faster driving as well. One think I should have done is take instant measurement pre and after to actually make an objective compare but subjectively speaking that gas gauge seems to be moving way fast :-(
Final numbers came in after heat soaking the unit so it was about real numbers vs testing to get the highest numbers which the tuner could have probably easily done..
Opted for BAP with Racetronix harness instead of replacing the pump (for now).
Pros:
Cons:
It makes sense though, your sitting in the garage in Florida with the motor runing and no air blowing across the H/E, it can't cool it self off. That head unit I am sure gets over 200+ F which is going to heat the water. When you get a chance do some data logging of temps at crusing and then how much do they go up when you get on it. I am curious how well the H/E is going to cool it down, and how fast it will cool the water. Thanks again, love the gauge!
For those that don't know about this gauge it gives you the ability to simultaneously monitor 8 functions of your choice. I can manually choose which ones I want it to display by pushing a button or I can set the gauge to cycle through all 8 at a refresh rate of my choosing. Those two LEDs at the top of the gauge are configurable to flash on a low or high value off of any of those 8 parameters. For example, let's say I don't really think I need to watch fuel pressure all of the time because everything I know tells me life is good there. BUT....I damn sure want to know if my fuel pressure starts to go low so I set fuel pressure as one of my 8, choose not to display it all of the time, but have the LED annunciator go off (idiot light concept) if/when my fuel pressure drops below a value of my choosing....pretty cool feature.
One thing I do know for sure...I'm going to start work on fab'ing up a Halltech like "Beehive" enclosure for the air intake. I'm certain there is benefit to be gained by isolating the engine bay from the intake on this setup. It's a proven mod.
Thanks for the update
http://www.dealextreme.com/details.dx/sku.16921
