C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Edelbrock E-Force?
Old Apr 23, 2010 | 09:09 PM
  #181
Motorhead-47's Avatar
Motorhead-47
Yet another observation....prior to installing the supercharger I was running a Halltech KillerBee with the BeeHive shroud and I am absolutely convinced the Beehive shroud made a big difference in IATs when the car was in traffic. I wish I had the skill to create a "BeeHive" like shroud for my E-Force air intake to isolate it from the heat of the engine bay.
Old Apr 23, 2010 | 10:50 PM
  #182
jim2092's Avatar
jim2092
Veteran: Marine Corps
St. Jude Donor '08
Originally Posted by Motorhead-47
The Edelbrock kit was designed for a 100% stock car. Should not run hot at all given that fact. My car has a few more mods than stock.
The Edelbrock tune does mod the fan settings. Here they are. I didn't fully understand Edelbrock's logic in the selection so what I'm running now is a bit different than their tune.
These fan setting and no true cold air intake - Edelbrock or a certified E Force installer, can someone explain this when IAT's are so critical?
Old Apr 24, 2010 | 09:19 AM
  #183
Motorhead-47
I've never seen anyone present themselves on this forum as being an Edelbrock tech rep. It would be straightforward enough for those with the resources to build a "BeeHive-Like" shroud. This would give you a head start on IAT's before things had a chance to begin to heat soak. As for the fan settings...beats me.
One thing I've noticed since day one of owning this car is just how long after I put it away in the garage the stock engine compartment stays warm. I could go out there several hours after shutting down my stock car, pop the hood and find a lot of very warm to the touch areas. Adding the mass of the Edelbrock doesn't help things. More mass to cool off and less open airspace to dissipate it.
Old Apr 24, 2010 | 10:05 AM
  #184
RoadRebel's Avatar
RoadRebel
Not sure if that is a Read/write bug or something they changed but the current supplied tune fan setting are not that way on the one I just did.
Old Apr 24, 2010 | 10:09 AM
  #185
Motorhead-47
Interesting...what values do you have and what year car was it?
What I did was squirt the Edelbrock tune followed immediately by a read and save with HP Tuners. What is in that image is what HP Tuners tells me were the Edelbrock settings. Strange. The only alibi I have is that the car wasn't sporting the OEM tune when I squirted the Edelbrock tune.
For S&G's I may go push the C6 OEM stock tune back in the car and then run the Edelbrock installer again to see what happens.
Old Apr 24, 2010 | 10:23 AM
  #186
71'AirStrike's Avatar
71'AirStrike
while that may have no direct benifit to you, I would be interested to see the results of that effort.
cheers
chad
Old Apr 24, 2010 | 11:02 AM
  #187
Motorhead-47
cheers
chad
You got it....went out to the car and reinstalled the 100% factory stock tune that was in my car when new. Here are the fan settings as verified with a read after the initial write...
Here is what I have after installing the Edelbrock tune over the top of the stock tune...
And finally here is what I have in the car after installing my HP mod'd tune...
Old Apr 24, 2010 | 11:09 AM
  #188
71'AirStrike
thanks motorhead!
HUH? thats odd with with the canned tune?
my gut tells me it was a 'oops' on their end (not earth shattering mind you), but that tells me that the Quality Control is not at 100%.
Not a deal breaker, but a tiny crack in the Armor of a new product.
Old Apr 24, 2010 | 11:20 AM
  #189
Motorhead-47
I'm not sure what to say but what you see is what I got. I've verified that my fan pretty much performs as you see in both the upper and lower setups but I never ran the Edelbrock fan settings. What I did initially was install their tune, read it with HP Tuners, did a compare with my tune and then went to work tweaking from day one.
Eventually I'll dump all of the Edelbrock stuff and get this car professionally tuned on a dyno by someone who really understands the E38 ECU but the only guy in this area who has me convinced he knows his stuff is "RWTD" and he is a hard guy to nail down.
Old Apr 24, 2010 | 11:26 AM
  #190
Motorhead-47
thanks motorhead!
I'm just guessing but maybe their test mule was a 2008? My car is a 2009 and there were changes in the 2009 ECU that may have some impact...dunno
Old Apr 24, 2010 | 02:46 PM
  #191
jcase10's Avatar
jcase10
St. Jude Donor '10-'11
I too noticed the heat from the extra mass, but the actual unit seems cool. The cast aluminum covers get a lot of the heat and am thinking about taking them off unless they act as some kind of heat sinks that draw heat away .
I'm glad I had my headers coated. For those on the fence get them coated.
Also, when I get home and park in it the garage I open the hood up to help with heat dissipation. Not sure if it actually helps.
P.S. Road Rebel referenced his install, it was on my car
Old Apr 24, 2010 | 04:09 PM
  #192
Motorhead-47
I don't think the covers serve any purpose other than to hide all of the plumbing and dress things up a bit...purely cosmetic. Just this morning I was giving strong consideration to taking them off and leaving them on the shelf in the garage. They get warm and stay warm. Like you I also run coated headers. They cool down faster than anything else under the hood!
Are you running the stock tune in your car? Any ideas what your fan temp settings are?
Old Apr 24, 2010 | 07:06 PM
  #193
jcase10's Avatar
jcase10
No clue about settings, it is not the base Edelbrock tune, hopefully Road Rebel will chime in soon about that info. I am thinking also about removing covers...
Old Apr 24, 2010 | 07:39 PM
  #194
RoadRebel's Avatar
RoadRebel
This is from Jims 08. Stock cal with edelbrock installed
0,0,0,10,23,75,90,90,90,90,90,90,90,90,9 0,90,90
On a side not, they flat out missed the spark calibration pre 4800rpm on the 08 for sure and probably the entire line.
You can easily pick up 40lb+ torque through the entire bottom/midrange.
Old Apr 24, 2010 | 08:03 PM
  #195
PowerLabs's Avatar
PowerLabs
From: Greater Detroit Metro MI, when I'm not travelling.
Maybe that was done on purpose to limit cylinder pressure for reliability reasons?
Old Apr 24, 2010 | 08:07 PM
  #196
Motorhead-47
I haven't touched the spark tables yet but have noticed virtually zero spark retard in my logs. I assumed the table was probably very conservative.
I ran a quick compare in HP Tuners between the Edelbrock and ZR1 High Octane Spark tables. Here are the differences...
Old Apr 24, 2010 | 08:59 PM
  #197
Z06PA's Avatar
Z06PA
With those fan speeds at 192 and 196 the fan will always be on with a stock thermostat - no? I've never seen my car under 196 unless cruising on the highway where it drops to 192 on a cool day and I don't have the blower yet... I have an 08 also...
To Edelbrock E-Force?
Old Apr 24, 2010 | 09:18 PM
  #198
Motorhead-47
I believe the stock thermostat is stamped 86c which converts to 187f. If I remember correctly that is the value at which the thermostat begins to open. You are correct that once the coolant temps reach 192 my fan will come on at 25%. I am ok with that. I'm also running a Dewitts radiator which from everything I've seen seems to keep the coolant temps much more stable than the stock radiator. I don't see those instantaneous climbs when I come up to a light. I see your point and depending upon where you live, how you drive and the hardware in your car, putting anything in the 192 field could keep your fan on virtually all of the time.
Don't forget to factor in the "Fan Desired % vs AC Pressure" table. I think you pretty much have the fan running all of the time the minute you hit the AC button.
Old Apr 25, 2010 | 10:10 AM
  #199
Motorhead-47
I've had a couple of people ask about how much boost pressure the E-Force builds. As best I know it here is the math by pulley size.
- 3.875" = ~5.5psi 554fwhp 515fwtq (#1590 kit)
- 3.5" = ~7.5psi 599fwhp 547fwtq (#1591 kit)
- 3.25" = ~9.5psi
- 3.00" = ~11psi
- 2.75" = ~13psi
Old Apr 26, 2010 | 03:36 AM
  #200
SGT's Avatar
SGT
Edlebrock has posted a E-Force software update (04/20/2010) on their web site for the 2008 – 2010 Corvette and the 2010 Camaro. I have no idea what was changed. Both the Corvette and Camaro files have the same number assigned to them. So, who knows what was changed?
