C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
E-Force?
Old Dec 10, 2010 | 04:12 PM
Motorhead-47's Avatar
Motorhead-47
Originally Posted by coolhand5599
But when I hit the brakes it went away so I played with this and sure enough every time I hit the brakes it goes away.
What he describes sounds very repeat-able. What would you attribute the "hit brake...noise goes away" to?
Old Dec 10, 2010 | 04:19 PM
PowerLabs's Avatar
PowerLabs
From: Greater Detroit Metro MI, when I'm not travelling.
I have no idea. That's why I didn't speculate on it. It could be that under deceleration the gear lash / rotor gap gets taken out by the constant load, but if that was the case the blower would go quiet when he downshifted and took his foot of the gas pedal. I just don't have enough information here to do any kind of diagnosis.
Old Dec 10, 2010 | 04:28 PM
Motorhead-47
Coolhand,
Post up a video if you are able to duplicate the condition/noise in your driveway.
Old Dec 10, 2010 | 06:25 PM
old motorhead's Avatar
old motorhead
I have my brand new front drive Maggie TVS2300 sitting on my kitchen counter. It came in while I was out of town. I can put my hand in the t'body opening and hold on to the rotors while trying to turn the drive pulley. There's absolutely no slack in the drive system. Nothing like the earlier Maggies. If the EForce's drive is similar, I can't see where there would be any rotor knock from a rough running cam.
Old Dec 10, 2010 | 09:48 PM
Motorhead-47
I believe it is the same TVS2300 rotor set in both superchargers...
Old Dec 10, 2010 | 10:20 PM
coolhand5599's Avatar
coolhand5599
OK, here it is. The sound quality is not the best from my phone but you can here it. I am in my driveway, you will hear it stop and start again. When it stops i am hitting the brake.
http://www.youtube.com/watch?v=daOLrLkkRug
Old Dec 10, 2010 | 11:08 PM
Z_Rocks's Avatar
Z_Rocks
I think they wanted you to record the sound from the engine bay area, so they can hear it more distinctively.
Old Dec 11, 2010 | 08:03 AM
coolhand5599
ok this is from the engine bay. I do not hear it as much brom this area. At the end I also went behind the exhaust with the M2W
http://www.youtube.com/watch?v=Ndgg2bObARU
Old Dec 11, 2010 | 09:04 AM
Motorhead-47
I'm not going to be of any help from the videos. I can't pull any specific unusual sounds from the two clips....not enough fidelity for me. If I put my ear ON my supercharger head unit I can hear most of the same sounds that I hear in your videos.
If I force myself to listen closely I can almost convince myself I hear a header/exhaust leak but I wouldn't put any money on that.
I do like the sound beginning at about minute 1:45 in the second clip....sounds wicked!
Old Dec 11, 2010 | 09:25 AM
Z_Rocks's Avatar
Z_Rocks
I was going to suggest that. After I had put headers on, and as I would slow down, I could hear a clicking sound coming through which I was told it was a leak from the header gasket.
If I remember correctly, wasn't it one of your friends who installed the unit? Perhaps he can detect where it's coming from.
Old Dec 11, 2010 | 10:28 AM
coolhand5599
I can't hear anything from the engine bay. It just sounds like a roots blower. I only hear it from the inside. Today I am going to the drags so I will see if I can get better audio of it
Old Dec 11, 2010 | 02:10 PM
old motorhead
Yes, I knew the rotors were the same, just wasn't sure about the drive. On the older Maggies, there's actually some slack between the drive pulley/input shaft and the drive gears. There doesn't seem to be anything like that on the TVS units though. It's amazing how slow you can turn the pulley and still feel air moving.
Old Dec 11, 2010 | 02:56 PM
  #33
PowerLabs's Avatar
PowerLabs
The pulley is pressed and keyed into the shaft, which is in turn pressed and keyed into the gears. There can't be any slack there since those are parts that do not move relative to one another, ever.
The slack comes from the drive gears. There has to be some there since they need to expand to accomodate for thermal expansion, and it has a tendency to increase as the unit wears in... Those gears synchronize the rotors and keep them turning at the same speed and same relative spot to one another so that the lobes do not make contact.
Here is what they look like. This is on the back of an MP112, but all roots blowers look similar. You can actually see the gap where the teeth mesh, although it is the tooth-to-tooth clearance that you hear rattling:
This is a bit OT. I still do not understand why applying the brakes would have any effect on blower noise when the car is idling. Makes no sense to me.
Old Dec 11, 2010 | 04:00 PM
  #34
old motorhead
I wonder what the dowel pins are used for that are on the gear on the right... Hmmmm. Do you think they might have something to do with the drive? They just might have a little "play" where they connect to the drive pulley housing.
Old Dec 11, 2010 | 04:57 PM
  #35
PowerLabs's Avatar
PowerLabs
I don't think so.
Old Dec 11, 2010 | 05:32 PM
  #36
old motorhead
I don't think so.
I do think so. We'll agree to disagree on this one.
Old Dec 12, 2010 | 10:27 AM
  #37
Skunkworks's Avatar
Skunkworks
I saw this once, was helping tune a car and went the wrong way (brain fart)... Car bucked around 1000 RPM and supercharger was audibly louder, even at idle. Got tune straightened out and supercharger (centri) was back to normal. Hitting brake loads engine a little differently or smooths it out.
Not saying that is the case, but have seen cammed cars rattle supercharger gears pretty good.
Just food for thought.
Mike
To E-Force?
Old Dec 12, 2010 | 10:50 AM
  #38
RoadRebel's Avatar
RoadRebel
You win, the 3 pins locate and transfer energy from the drive coupler. The coupler is a spring dampened isolator between the drive pulley/shaft and the rotor asm. Its pretty much the same on the Zr1/CTS-Vs
Old Dec 12, 2010 | 02:56 PM
  #39
Vetteman08's Avatar
Vetteman08
3rd Gear
Coolhand,
Place your palm on the center of the unit and press down. Does the noise dissipate? I thought mine was chattering too much so stopped by Lingenfelter and had them give a listen. The folks thought the sound was normal but may be magnified by resonnance from the cover (I put mine on in February so they may have modified since). Lingenfelter had another in the shop and it sounded the same, just less pronounced. My sound may be different than yours though, can't hear it untiil car is warm and has no relation to braking (6 spd). Edelbrock said they considered a center stud. Anxious to see what you find out.
dw
Old Dec 12, 2010 | 06:50 PM
  #40
PowerLabs's Avatar
PowerLabs
A Mechanics' Stethoscope is an inexpensive way of identifying where noises are coming from... Might be worth a try; most auto parts stores carry one:
Fifteen bucks... Touch the probe on various parts of the engine and blower and you may be able to narrow down the general direction the noise is coming from
