If it hasn't been customized to report what you want it to, it will probably default to whatever PIDs are programmed into the device when it ships. I can't remember if mine came pre-loaded with PIDs or not.
It has 8 pages x 4 profiles that all have stuff on them from the factory, so you'll have some stuff to play with even just plugging it in the first time
Well got it working and got some stuff customized. Once home. Stupid I had to find a PC bull **** my
mac but what ever. Now to get a map sensor that reads more then 0psi.
I placed an order from Palmer Performance on 4/4/19 for the C6 kit with the PLX wideband sensor. My order still says pending, nobody replies to the contact form, and I can't find a phone number. Any ideas guys?
Just configured dashlogic and have everything I want to see on 4 pages. Is there any way to delete any unused pages so I don’t have to scroll through all 8 pages? It would be nice to only scroll through the 4 pages that I’m using instead of having to run through all 8.
i thought there was a way to enable and disable pages once it’s connected to the car. I believe you have to push the light dimness **** in twice quickly to get into setup to do it
I've tried searching, but can't find the appropriate PID for adding fuel pressure from DSX Tuning (https://dsxtuning.com/products/fuel-...ure-sensor-kit) to my Dashlogic. I don't believe I'm getting accurate readings.
Has anyone figured this one out?
Sounds like you had it right then. Maybe his equation for the sensor isn't perfect, maybe you just have more fuel pressure than you think, I'm not sure. Regardless, you can still use it to see if pressure is dropping even if the absolute value is off 8psi or whatever
I'm going to use a ZR1 map sensor for my supercharger install. Do I need to create my own boost PID or can i use the pre-configured ZR1 boost PID that comes with the Dashlogic?
