Torque Management System - C6
Old Jul 12, 2006 | 07:16 AM
  #161
SpinMonster's Avatar
SpinMonster
Originally Posted by jschindler
I've got a lot of runs in two C6's I've owned. As long as TC & AH are completely off, neither of mine has ever fallen on their face when shifting. Any one who does not believe me is more than welcome to trek on down to Houston for a ride.
When TQ managment jumps in it doenst fall on its face. It pulls a few degrees timing.
You can feel the timing being pulled but it doenst feel like active handing or traction control shutting down fuel flow. The AH/T-control you are talking about is a complete shutdown of the air/fuel flow and is not what TQ management is nor is it what is being asked about. Disabling this with the console button doesnt remove TQ management.
I can turn it off with HPtuners and back on again...over and over and you can tell the difference.
Old Jul 12, 2006 | 10:13 AM
  #162
jimman's Avatar
jimman
Interesting that Charlie at A & A tuned mine with both HP tune and LS2 edit and didn't observe what you are saying. In fact no read me file jumped out from the raw computer only what the tuner sofeware presented. In fact Hp went up when timing was reduced from the 26 degrees that LS2 edit allowed to 16 degrees as per HP tune and the ping went away. Of course timing will be affected with different load and rpm conditions but not this sinister plot of GM to save a transmission maybe to save a piston. Of course if I would have stayed at a Holiday Inn Express I might be able to understand better.
Old Jul 12, 2006 | 10:30 AM
  #163
Ranger's Avatar
Ranger
As reader of this thread assess the credibility of the engineering-challenged members claims that TM is a myth, please read the following...from the tuner Jimman claims told him TM doesn't exist.
A&A Corvette's CF advertisement
We have just upgraded to the newest Dyno Jet 224 X with eddy current load cell. Only a true load cell allows the tuner to hold the vehicle at any load and throttle setting for a predetermined amount of time. This, in turn, allows us to analyze each end every "fuel trim cell" for proper fueling. The standard 248 DynoJet with a "brake" simply can't do this. It can only add load by dragging the brake to slow the run down in order to gather more data. Not the same thing. I did a lot of research before investing in this particular dyno and determined that this model would be the best available unit for tuning, not just measuring horsepower and torque. I've also just invested in a module to log boost and fuel pressure as we tune. This gives us more needed information to tune supercharged cars properly. With the latest versions of LS1 Edit, LS2 Edit, HP Tuners, EFI Live, Ease and GM's Tech 2 editing and diagnostic software, we have the capability to tune your LS1, LS6 and LS2 powered vehicle for optimum power and driveability. Fuel and spark curves as well as torque management and transmission settings are optimized for your combination of performance modifications. We also have the capability to tune more radical vehicles in "Speed Density" to enhance driveability dramatically. We are the only shop on the West Coast to have all this in our tuning "arsenal" Please call or e mail for appointments and information.
So they told you TM doesn't exist, but their own advertisement say is does. Who are we to believe, you or our own eyes?
Enough of the spinners and game players. This is deceipt, plain and simple.
Ranger
Old Jul 12, 2006 | 10:36 AM
  #164
shurite44's Avatar
shurite44
My tuner told me he tuned out a large percentage of TM. He used HP tuner. I really know very little about it, but my A6 definitely hesitates on the launch. My 60 times are slower than my C5. I have not run it since the tune, might go to the track tonight if it dry's up around here.
Old Jul 12, 2006 | 10:38 AM
  #165
jschindler's Avatar
jschindler
I'm not the one who is saying that TM causes it to "fall on it's face". I'm simply responding to those who say their car is falling on it's face and blaming it on TM. Honestly, I think most of them are not turning Active Handling and Traction Control off.
Old Jul 12, 2006 | 10:40 AM
  #166
jimman's Avatar
jimman
Ranger
with the A4 and torque converter management.
Old Jul 12, 2006 | 10:42 AM
  #167
Ranger's Avatar
Ranger
That is also my experience. I have 90 rwhp more in my C6Z than my C5Zs; but the C6Z is no faster in the 60' and 330'. The reason is TM.
shurite44, you may want to visit your tuner again and further tweak the TM and related values.
I'm stuck with TM until satifying myself I've found the bottom of my ETs with the car bone stock.
Ranger
Old Jul 12, 2006 | 10:44 AM
  #168
Zig's Avatar
Zig
From: stafford country, va. Avatar: Me on turn 3 @ Bristol (The World's Fastest Half-Mile)
... we have the capability to tune your LS1, LS6 and LS2 powered vehicle for optimum power and driveability. Fuel and spark curves as well as torque management and transmission settings are optimized for your combination of performance modifications. ...
is the ls6 used in four wheel drive vehicles, i understand the ls2 is.
doesn't the tuning software allow you to 'edit' a variety of vehicles ? not all functions in the software apply to all vehicles.
how can one trigger a tm event. would it be possible to use your launch technique to cause a tm event. does it feel like a slight miss or is it just a very slight hesitation ?
if we could identify the sensors or how it's monitoring the 'system' would we be able to interupt the 'signal' and therefore disable tm ?
Old Jul 12, 2006 | 11:14 AM
  #169
dennis50nj's Avatar
dennis50nj
This is why you cant tell if it happens because you don't know how to activate it. it has been stated many times the better the traction the slower the 60 ft. and 330 and even if you drive around it and pickup your 60 ft. you don't get similar1/4 mile gains of better et.as you would with a none TM. car pick up 1/10 60 ft get 2/10 et. when you heat tires take off at Maximum power and traction TM activates have someone stand behind car and they will hear it on and off throttle sound in the exhaust note.when car spins it doesn't activate so if you cant drive. you cant activate it or feel it auto or stick you will feel it in the shift to depending where you shift at. of course you have less torque at redline.you guys with autos heat your tires floor it off the line you wont spin the stock tires slow 60 ft times drive off easy roll into throttle faster 60 ft times try it I cant believe people give you pointers to faster times and the reason why and you dought us we are trying to help everyone go fast so you represent corvette well I am tired ofpeople saying the are dogs because you guys cant drive
Old Jul 12, 2006 | 11:20 AM
  #170
Zig's Avatar
Zig
using this argument i would need to have faster times than someone else in order to prove my point ?
Old Jul 12, 2006 | 11:35 AM
  #171
jimman's Avatar
jimman
So let me see how this works. Sitting at the line in a 3200 lb car with NO wheel spin allowed, launch at say 2000 rpms which means car should move at around 15 mph. So the car will instantly reach 15 mph or will the engine rpm back off to meet that new 0 mph speed for a moment. So is this TM, that instant of clutch engagement when engine wants 15mph and car is at 0 and GM is worried that the transmission might break and a warranty claim will ensue. I think I would want timing to be pulled so as not to get pre-ignition and punch a hole in a piston that is in the wrong place at that moment in time. Or do we just go for the gusto and advance the hell out of it because Bubba and Billy bob are on break from Wal-Mart’s door duty and will tune your car. Sorry just couldn’t resist.
Old Jul 12, 2006 | 12:21 PM
  #172
RSR_427TT's Avatar
RSR_427TT
Originally Posted by Newton06
TM is defintely there & can easily be edited out (defeated) by any knowledgable tuner. I watched Jeremy Formato canel mine during a tuning/dyno session.
Do you know his contact info. I would like him to tune my car as well, but can't seem to find his # anywhere.
Old Jul 12, 2006 | 01:11 PM
  #173
dennis50nj's Avatar
dennis50nj
look on DC corvettes
Old Jul 12, 2006 | 01:19 PM
  #174
dennis50nj's Avatar
dennis50nj
no i don't think your driving technique activates it. you know how some drivers can relay info to there crew chief of what the car is doing. the rest of the story you know.
Old Jul 12, 2006 | 01:20 PM
  #175
shurite44's Avatar
shurite44
Hey Ranger, .
Well I have not been back to the track since the tune. Hopefully tonight.
I will not be able to tell precisely where my gains will come from though. I added quite a few bolt ons this weekend. I gained around 45-50 HP on their dyno.
Similar TM type scenario happened to me when I went with wider sticky tires on my A4 C5. Hesitated enough that my racing buddy asked me what happened when he saw me launch. I have a suspicion that the auto has more TM programing than the M6 but who knows. The guys with HP tuner seem to have a handle on it though, I will find out tonight I hope. I should be able to cut a 1.8 60 with my setup I think, I hope anyway. My C5 ran a 12.71 with a 1.83 sixty foot (CAI, cat back, Hypertech tune), I sure hope I can beat that with my C6 with LG pros, high flow cats, corsa sport, vararam, and a dyno tune.
Old Jul 12, 2006 | 01:33 PM
  #176
dennis50nj's Avatar
dennis50nj
Lets just see have you ever raced your c6 at any track and what are your times.do you have any goals of going faster or racing any more.if yes we would like to hear them. if no why do you care about TM.
Old Jul 12, 2006 | 01:38 PM
  #177
dennis50nj's Avatar
dennis50nj
Hey Ranger, .
Hey Gary how did the rims work out did you try them on the car yet
To Torque Management System - C6
Old Jul 12, 2006 | 01:45 PM
  #178
Zig's Avatar
Zig
if that's what it will take, then fine, i'll bite.
i just got my car back from the shop. had the clutch replaced, my vehicle was covered under the 6k high rpm shift tsb.
now that i have the 'new' clutch i'll take it out and see what i can do for you.
Old Jul 12, 2006 | 01:48 PM
  #179
Ranger's Avatar
Ranger
Hey Ranger, .
Tuners handle edits to TM in various ways, because there are muliple tables with TM impact, but the impact of changes is not linear. This is because the various algorithms themselves, which draw upon values in many different tables, are not precisely understood, since they are embedded in proprietary firmware.
So there is some experimentation involved for the tuner. And you may benefit from an ongoing dialog with your ECM tuner as you start making passes in your C6. On-board data logging at the track would be best. That data combined with your slips and some hand-held weather station input would be ideal.
Ranger
Old Jul 12, 2006 | 02:24 PM
  #180
dennis50nj's Avatar
dennis50nj
Rob thats the only way to no. good luck but if you want just think all 06 c6 have better 60ft times after GM changed out the back rear and all 05 c6 have a slower 60ft because GM put less TM in the 06 because it had a stronger rear.
