Biggest Rubber under C6
Old Nov 7, 2007 | 04:00 PM
bunzaroo's Avatar
bunzaroo
Default Biggest Rubber under C6
I am planning to purchase 18X9 - 19x11 z06 reproduction rims for my 2008 c6 w/z51. What are the largest tires that will fit in the rear without widebody or sticking out. Anybody w/ pics running this setup please post. Doesn't have to be the zo6 wheels. thanks
Old Nov 7, 2007 | 04:30 PM
lyonsac4242's Avatar
lyonsac4242
I'm curious too for future plans on my 05 Z51. Anyone?
Old Nov 7, 2007 | 05:36 PM
Anthony @ LGMotorsports's Avatar
0Anthony @ LGMotorsports
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
The absolute largest that you are going to fit under the stock GM body work would be a 275 or 285 front tire and a 325 rear.
There are some track guys that are running up to a 305/335 combo but they tend to stick a little past the body lines.
Old Nov 7, 2007 | 06:19 PM
lemansbc6's Avatar
lemansbc6
Default need traction
i also am curious to see pics....might consider this an option rather than buying z06 fenders painting them..blah blah. i need traction after the recent addition of lg lontubes, lg cam and 4:10's. cant wait to see some pics..anyone???
Old Nov 7, 2007 | 06:21 PM
codename Bil Doe's Avatar
codename Bil Doe
I run 315's front and rear at the track with no sticking out past the fenders and no rubbing on the control arms or tie rods. I added Z06 ducts which do rub barely at full lock. Otherwise they fit fine. I'll be switching to 315f/335r for next season.
Here is from last Saturday. You can see the tires tuck in nicely. Pics by BryanH
Old Nov 8, 2007 | 10:36 AM
Wayne O's Avatar
Wayne O
CF Senior Member
I'm running CCW SP16A wheels, 9.5” x 18” front / 11” x 19” rear with Goodyear Eagle F1 Supercar EMT’s...275/35ZR18 front / 325/30ZR19 rear...stock Z06 tires. The rear tires stickout from the body panel about 1/4" or so...not much.
Old Nov 8, 2007 | 11:13 AM
HAIL THI$'s Avatar
HAIL THI$
Honestly, on the back I wouldn't go bigger than 315 if its a daily driver. 305 is probably a great size if your looking for meat with solid traction. Plus the the bigger the more $$$$
My 2 cents...
Old Nov 8, 2007 | 11:22 AM
FloydSummerOf68's Avatar
FloydSummerOf68
I thought there have been problems with the 305 due to the height difference between front and rear and it causing the traction control to go crazy or something because it thinks it's spinning quicker than it should be compared to the front?
Old Nov 8, 2007 | 11:41 AM
Cavallo GT's Avatar
Cavallo GT
St. Jude Donor '07
I'm running 265/35/18 on 18X10 CCW505's front and 305/30/19 on 19X11's on the rear and the heights worked out almost perfect. Better than the stock sizes as I recall. I'd like to go to 275 and 315 next but the tires are hard to find. Abolutely no problems whatsoever with this package other than keeping the wheels clean!
Old Nov 8, 2007 | 11:47 AM
FloydSummerOf68
Very cool...it was just something I thought I remembered hearing.
I'm glad to hear they work out just fine. What brand of tires are they?
To Biggest Rubber under C6
