C6 1/4 Mile Performance Challenge
Old Jul 18, 2010 | 11:17 PM
  #4501
dicky's Avatar
dicky
Originally Posted by JHawk65
I have a 2010 GS A6 with the Edelbrock supercharger, Dynatech headers, and a tune. My best 1/4 in Kansas City was on July 9th @ KCIR with DA @ 2,357.
60' 1.840
330' 5.002
1/8 7.576
1/8 95.74 MPH
1000' 9.769
1/4 11.612 @ 122.010
I am think of going to a 3.15 differential becuase I will pick up 15% more acceleration (Gs) through 4th gear. If I went to the 3.42 I calculate 25% more Gs; however, I think I would have to shift into 5th gear to get through the quarter. I have ran the 1/4 at 124.74 with an ET of 11.643. Do you have any thoughts regarding 3.42 vs 3.15, and my 5th gear calculation on 2010 A6?
nice times
i have the 3.42 gears but on the strip i run 275/40/17's which is about 25.66'' tall and i hit about 122-123 mph most of the time. my car tries to shift into 5th right at the finish line but my car also has the stock cam so my shift points aren't really raised.
there is a guy on here (his screen name is subfloor) that has 3.42's with the same size tires as me but he has an LS7 with a cam and his rev limiter is raised quite a bit, i belive his can hit mid to high 130's with his setup.
dicky
Old Jul 18, 2010 | 11:22 PM
  #4502
JHawk65's Avatar
JHawk65
7th Gear
Do you have a before and after changing gears ETs, and what was your gear before you put in the 3.42?
Old Jul 19, 2010 | 12:25 AM
  #4503
dicky's Avatar
dicky
i didn't get a good before and after comparison because i put the FAST 92 on there at the same time but i would say its good for anywhere between .1 to .2 on the ET, i know not as much as you would think but every little bit helps. before i went to the 3.42's i had the stock 2.56's.
Old Jul 19, 2010 | 01:10 AM
  #4504
PRE-Z06's Avatar
PRE-Z06
60' 1.840
330' 5.002
1/8 7.576
1/8 95.74 MPH
1000' 9.769
this should help http://www.f-body.org/gears/ going from 3.42 to 4.10 I picked ~.3 and that was with an extra shift(~.2), if you're already shifting to 4th you should see at least that assuming you can hook up
Old Jul 30, 2010 | 08:21 AM
  #4505
theofel's Avatar
theofel
St. Jude Donor '10-'13
If you want better ET's...315's or 342's in conjuction with a 3200-3600 stall will do the trick! That combo will get you well into the 10's.
Old Aug 2, 2010 | 09:40 AM
  #4506
Mike Campbell's Avatar
Mike Campbell
I have a dumb question. I was checking out the 1/4 times list and I noticed a ton of cars listing a "cb" mod. What is a "cb" ?
Old Aug 2, 2010 | 10:17 AM
  #4507
dicky's Avatar
dicky
i think its catback
Old Aug 2, 2010 | 10:58 AM
  #4508
Mike Campbell
dicky:i think its catback
Hmmm, that makes sense. Thanks!
Old Aug 2, 2010 | 04:48 PM
  #4509
Check-Mate's Avatar
Check-Mate
4th Gear
jeez 11.00 sec, thats awsome. props
Old Aug 3, 2010 | 07:20 PM
  #4510
Tropic Thunder's Avatar
Tropic Thunder
Originally Posted by Silver Bullet C6
I'm new to drag racing, but here's my best effort so far.
I was car #13 on the left.
My car is an '08 LS3, A&A Si-trim supercharger, 3.42 gears, meth kit, stock stall converter. This was my 2nd visit ever to the 1/4 mile track, so I hope to improve and get into the 10 second club.
Great pass!
Old Aug 3, 2010 | 07:25 PM
  #4511
Tropic Thunder
The DA was 2329... very good for Texas in July
Wow! Even more impressive!
Old Aug 3, 2010 | 11:48 PM
  #4512
Silver Bullet C6's Avatar
Silver Bullet C6
St. Jude Donor '10-'11-'12
Thanks, Check-Mate & Tropic. I hope to hit 10s for sure in Sept.
I'm getting a flip-drive and smaller pulley for the supercharger installed. Even with a 1.8 sec 60 ft. I should hit 10s.
Old Aug 18, 2010 | 12:24 PM
  #4513
1988Bullitt's Avatar
1988Bullitt
Great Pass! With that MPH you will be well into the 10's with a little harder launch, very nice
Old Aug 18, 2010 | 02:39 PM
  #4514
Silver Bullet C6
Thanks.
You're right about needing to launch harder... I saw a video of one of my runs and the "launch" looked i was leaving my drive way. It needs work.
Old Aug 27, 2010 | 11:09 PM
  #4515
turboffr's Avatar
turboffr
St. Jude Donor '10
Default 11.3@135
Only got one test pass and got kicked off for no roll bar. There's a lot left as you can tell by my 60 ft. I came out real easy to see how/if the drag radials would work. They hooked and I bogged real bad..
'06 MN6, cam, intake, headers, cats, ECS Paxton 9 psi, meth, drag radials
4. Year Corvette-2006
5. Type of Trans-MN6
6. Type of Suspension-stock
7. Stock Performance options - Z51
8. Tires utilized - drag radials
9. Modifications if any-Cam, intake, headers, supercharger, meth
10. Dyno numbers if you have them-646/593
11. 12. Typed in the post (as some time slips get deleted & etc after being posted)
___ New England Dragway
___ Date of the pass & weather conditions-8/27/10
___ 60'.............2.115
___ 330'...........5.208
___ 660'...........7.63
___ 660’ mph....101.54
___ 1000'.........9.682
___ 1320'.........11.37
___ 1320’ mph…135.29
Old Aug 28, 2010 | 12:48 AM
  #4516
LS1LT1's Avatar
LS1LT1
Originally Posted by turboffr
Wow nearly identical sixty foot times, then you proceeded to put a full 3 seconds on him from there LOL, there are definitely 10s in the car.
Old Aug 28, 2010 | 07:27 AM
  #4517
turboffr's Avatar
turboffr
St. Jude Donor '10
I know. I wish I could have gotten in a few more runs. This was just my first pass ever with the blower so I took it a little too easy out of the hole. 10's are there to be had, but I need a roll cage if I want to do it.
To C6 1/4 Mile Performance Challenge
Old Sep 19, 2010 | 05:42 PM
  #4518
GTkiller97's Avatar
GTkiller97
What's up guys i just took my 05 M6 to the track this past friday night....DA was 1700 and temps were around 80-85 so not great weather for making some passes but my best was a 12.72 at 111MPH with a 2.07 60ft, car is stock. I'm looking to run a 12.4x or 12.3x here in the next few weeks, this was my very first pass after driving to the track and after only a week of having car. Will keep ya'll posted if i can get down there and post up a new record here pretty soon!
Old Sep 29, 2010 | 11:22 PM
  #4519
C6Phil's Avatar
C6Phil
2005 A4...CAI, headers, B&B exhaust. Everything else is stock including the rubber. 1st ever attempt at drag racing...what a blast!
Old Oct 3, 2010 | 09:29 PM
  #4520
GTkiller97's Avatar
GTkiller97
Can you please update list...I am going to attach the timeslip and fill out form as needed below.
1. Your entire profile completed-yes
2. A copy of your entire time slip posted to the thread as in post # yes???
3. The complete the details of your pass using this template in your post-yes
4. Year Corvette-2005
5. Type of Trans-M6
6. Type of Suspension-Z51
7. Stock Performance options (as in optional gears with the automatic, & etc.)-Z51 package.
8. Tires utilized- Nitto Invo's
9. Modifications if any-no
10. Dyno numbers if you have them-none
11. As much info you may want to add about the run, launch techniques, tire air pressure & etc -slipped clutch hard launching around 2800rpm, clutch was staying engaged partly on each shift due to dirty fluid
___ Name of the Track-Fayetteville Motorsports Park
___ Date of the pass & weather conditions-10/3/10...68 degrees DA-780
___ 60'.............1.9573
___ 330'...........5.3884
___ 660'...........8.2024
___ 660’ mph....88.51
___ 1000'.........NONE
___ 1320'.........12.6273
___ 1320’ mph…111.69
