C6 1/4 Mile Performance Challenge
Old Jan 24, 2011 | 02:40 PM
  #4901
FloydSummerOf68's Avatar
FloydSummerOf68
Larry is running almost 101mph in a car with similar mods carrying more weight (I would assume at least 150 pounds).... why is 102 so hard to believe when 100.75 isnt?
Originally Posted by theofel
If this is an accurate statement.....You would be able to install a stock LS2 or LS3 engine into the much lighter ZO6 and run as a stock LS2 or LS3. That would be totally wrong and not fair. Just my 2 cents.
I wouldn't have a problem with that.
Can someone with an LS2 C6 not do weight reduction and still be on the list?
As long as it's in a C6 I could care less.
Old Jan 24, 2011 | 03:05 PM
  #4902
dennis50nj's Avatar
dennis50nj
yep he sure did, 100 isnt 101 and -1071 da. also that weight with the reduction listed doesnt add up, as far as the coastal air i guess the west coast air is really better then the east coast, as tom ran slower when at etown
Old Jan 24, 2011 | 03:19 PM
  #4903
HOXXOH's Avatar
HOXXOH
Hey you guys are really getting your panties in a wad over this.
Is it just because I have a west coast car in the 10's or that you can't find anyone else with my particular combination of mods and tune for comparison? Of course, it's only the LS2 guys that seem to have that problem.
I've provided far more information about my car, the mods, the race conditions, and other aspects than anyone else on this list. I've followed the posted rules that even require looking at a different website to find definitions and find nothing that would change anything.
I think you guys are going to have to resort to different tactics if your intentions are to discredit the results. Maybe try things like Sacramento fog contains nitromethane or alien beings provided dilithium crystals.
Old Jan 24, 2011 | 03:31 PM
  #4904
Joe_G's Avatar
Joe_G
St. Jude Donor '08
It's all good.
I think the 2925 weight says it all. Theofel's car weighs 3250 IIRC. That right there is the difference. Mike knows he could make his car lighter - but it's his street car and he's happy with it. It does look great.
Old Jan 24, 2011 | 03:43 PM
  #4905
dennis50nj's Avatar
dennis50nj
believe me its more then just the east coast guys, and ls2 guys. maybe the east coast ls2 guys are just trying to learn how it happened, but it just doesn't add up. despite what any ls3 owners say, the ported fast intake evens the playing field of the ls2, hp to hp, many c6 a6 ls2 and now a c6 a6 ls3 cam LG Motorsports, highest dyno cam car, didn't reach 102 or 10.81, so why would yours with such minimum mods and weight reduction, the spreads dont add up
I crunched the numbers and there is a problem with your timeslip.
1. As I pointed out the 102 mph is very high for your horsepower regardless of the converter.
2. your two slips at Speedworld are nearly identical which gives a good baseline. The problem is that your incremental time from the 660' to 1000' is nearly identical for all three passes. (2.095, 2.097, and 2.097) your pass at Sacramento would need to be incrementally faster since your 1/8 and 1/4 mile trap speeds are greater.
3.your Sacramento pass picked up about 0.16 from the 60' to the 1/8, 0.00 from 660' to 1000', and 0.10 from 1000' to the 1/4. Something is off. Either there is a timing issue between the two tracks or something else is going on. maybe a little nitrous after the 60 ft to the 330 giving a little kick in the 1/8 at both tracks
Old Jan 24, 2011 | 03:49 PM
  #4906
dennis50nj's Avatar
dennis50nj
Originally Posted by Joe_G
It's all good.
Joe
so i have way more mods, a 1.41 60 ft 10.62 et and i dont hit 102, also that great east coast atco air, and of course weight reduction, if he was 2925, i was lighter
Old Jan 24, 2011 | 03:56 PM
  #4907
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Originally Posted by dennis50nj
Joe
I still don't believe the timer on the 102...if you lay out his slip and Tony's like I did above, they make good sense, and the ET's tie out, all except the 102. If his 1/8 mph was 99 nobody would raise an eyebrow.
If the 102 was real, I think his 1/8 ET would be lower.
And I hate to be harping on the guy, he does his own work and drives many miles to get the slip. I have to respect those facts.
Old Jan 24, 2011 | 04:03 PM
  #4908
dennis50nj's Avatar
dennis50nj
what about the 660 t0 the 1000 ft mark times being so close to each other at arizona to sacramento with such a DA and altitude change between the two tracks, that has nothing to do with the 1/8 mph timer
Old Jan 24, 2011 | 04:05 PM
  #4909
Joe_G's Avatar
Joe_G
St. Jude Donor '08
I think his e/t down the strip makes sense, and are similar to Theofel's, it's just that 102 mph that looks odd to me. A 102 mph should be a 6.8 or better I think 1/8.
Old Jan 24, 2011 | 04:07 PM
  #4910
dennis50nj's Avatar
dennis50nj
also same trans gears converter to tony, ls2 to ls3 but we seen tonys cam dyno numbers more then the ls3 bolt/on im sure, tonys was a base unit with weight reduction more rwhp, better da at atco, better 60 ft, and yet tom runs better et
Old Jan 24, 2011 | 04:11 PM
  #4911
HOXXOH's Avatar
HOXXOH
It's all good.
A 325# weight difference and 500+ feet DA can easily account for the ET difference and still leave some leftover for his extra HP. If Mike dropped to equal weight and comparable DA, he'd easily gain .4 to run in the mid 10's. But then he'd be the target of the non-believers.
Old Jan 24, 2011 | 04:15 PM
  #4912
dennis50nj's Avatar
dennis50nj
exsplain the 660 to 1000 ft times, so close at his two arizona passes at 11.06 to the cali time at 10.82 , all three passes 2.095 2.097 2.097 what happened to the extra weight removal, and the better da
Old Jan 24, 2011 | 04:16 PM
  #4913
Tony B4's Avatar
Tony B4
St. Jude Donor '08
Hi Joe,
The MPH didn't tie out in the 1/4. If he would've went faster then it would have made sense, but he went slower than my mph in the 1/4?
Christopher had his buddies LS2 Cammed, geared, stalled, bolt ons LS2 there and the best he could muster up was a 10.85@125+mph. Now are you gonna tell me that Christopher's friend with an all out LS2 with more power is going to go slower on the same day as this guy? Christopher's jaw must have been hanging when he seen HOXXOX go faster since I believe Christopher has been helping, working, advising his buddies C6 LS2 Vette. Remember, if HOXXOX had great air, so did Christopher's friend.
Old Jan 24, 2011 | 04:18 PM
  #4914
Tony B4's Avatar
Tony B4
St. Jude Donor '08
I see you speak about weight reduction...So what weight/items did you remove?
Old Jan 24, 2011 | 04:19 PM
  #4915
HOXXOH's Avatar
HOXXOH
Try launching in 2nd one time and notice the difference in the 1/8 ET and MPH. I'm sure you'll be surprised.
  #4916
dennis50nj's Avatar
dennis50nj
the time slips you provided don't lie, different tracks different da, lighter weight, almost identical 660-1000 ft, something fishy is going on
Old Jan 24, 2011 | 04:23 PM
  #4917
Tony B4's Avatar
Tony B4
St. Jude Donor '08
So thats what you did in order to get 102mph? You launched in 2nd gear?
To C6 1/4 Mile Performance Challenge
Old Jan 24, 2011 | 04:28 PM
  #4918
dennis50nj's Avatar
dennis50nj
i see your trying to come up with an answer, that one is pure, i watched your videos, all had three shifts, now if you did start in second hit nitrous the rpm would go up quick enough so it would shift into 4th. explaining the 102mph and 3 shifts also once you turned the spray off, it would be like letting off the throttle and in forth two soon lugging you down to those 23mph back half
Old Jan 24, 2011 | 04:33 PM
  #4919
HOXXOH's Avatar
HOXXOH
Originally Posted by Tony B4
Hi Joe,
Nice try there Tony, but Mike G's car is over 200 # heavier and the same converter. Christopher has been a help to me too and yes he was cheering us both.
Now, wanna try explaining why the third Arizona car with no changes after running 11.11 two weeks earlier at Speedworld could only manage a 11.20 in CA?
Old Jan 24, 2011 | 04:34 PM
  #4920
dennis50nj's Avatar
dennis50nj
tea it gave him 102 mph in the 1/8 a faster et in the 1/4 then he pulled it into 1st to slow down the 1/4 mph
