Trick flow install underway
Old Apr 28, 2010 | 08:09 PM
  #181
ctusser's Avatar
ctusser
Originally Posted by LSCHLEM
3. The drive at slow speeds was the same as before and when I gave it a shot in 1st, 2nd, & 3rd seemed to have more torque instantly down low. Did not have it over 4800 RPM on this initial test but I can feel it
maybe 15 or 20 at the most is what I figure.
I think a lot of the seat of the pants feel when going to a bigger manifold is b/c you are getting more air at partial throttle input with the larger setup. When I went with a FAST 90 over my ported LS6 setup I could've swore I gained a bunch of torque in the low end b/c at partial throttle the engine was much more responsive. But upon dyno checking I actually lost a little low and mid range torque at WOT, but gained about 6hp at peak.
Old Apr 28, 2010 | 08:16 PM
  #182
Craigster05's Avatar
Craigster05
St. Jude Donor '07-'08-'09-'11-'12
Just a thought....
It looks like you still have the PVC delete that your tuner installed way back. You may want to rethink that...having those two open hoses just hanging under your car where they can suck in dirt and debris instead of using a catch can (or using the stock PVC system) may bring some major problems to all your hard work.
Old Apr 28, 2010 | 08:23 PM
  #183
LSCHLEM's Avatar
LSCHLEM
St. Jude Donor '08-'09-'10
Originally Posted by Craigster05
Just a thought....
Craig, That is probably my next mod. Somehow it got Oil into the intake anyway. Currently the Valley Line and the Passenger side are going to vent. I did notice Oil at the end of the Valve cover Hose. I think Norris
the guy who did the initial writeup has A nice Can and will probably go with that.
Old Apr 28, 2010 | 08:34 PM
  #184
Craigster05
Take a look at the Cartek Can....Joe did a write up on the one I gave him....I think it is the best one out there.
Joe_G Catch Can Install
Old Apr 28, 2010 | 10:53 PM
  #185
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Craigster I updated that thread, I thought I had already but hadn't .
I've removed it, as my oil was getting really dirty really fast. I think a daily driver like mine needs some vacuum to get rid ofnthe blow by while in traffic. If a car wasn't used like mine it would probably be fine. I'm using a regular catch can now and it's catching a lot of oil so it's working.
Old Apr 29, 2010 | 12:28 AM
  #186
PRE-Z06's Avatar
PRE-Z06
Originally Posted by Joe_G
You will need more than one fluid change Leon, trust me.
You are going to be at the limit of the stock clutch IMHO based on my observations of nodded c6Z's, but you should be ok for your use. My friend Retrotech had 550/460 in his Z on the stock clutch and ran 10.68 @ 133 and got 1.5's on the stock clutch. At that power level the clutch is the weak point and cannot handle harder launches or the pedal just falls to the floor if you try to launch harder.
He is a hotshoe driver, but it gives you something to shoot for.
Here is a vid. I never get tired of watching it. Lol.
agreed, it's holding up in a friends c6z making 570/500, but he's only cutting 1.6s launching at 4k
Old Apr 29, 2010 | 09:07 AM
  #187
LSCHLEM's Avatar
LSCHLEM
Flush the heck out of that fluid before and after each drive, flush it two or three times and pump the clutch a lot between each flush.
And take out the pedal spring.
You might be able to bring it back and it's nearly free to try.
Done with the Fluid flushes. Where is the PEDAL SPRING ?. I'm not
seeing it. Going to test it out now. Then the tractionmonsters.
Old Apr 29, 2010 | 09:21 AM
  #188
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Super easy. I take them out at the drag strip in 30 seconds. Put a rag down on the floor as they are greasy and they fall out.
Thanks to our buddy Clevite Kid for the pics.
http://forums.corvetteforum.com/c6-t...ing-in-c6.html
oh and the c5 spring kept my clutch pedal down too. Don't bother with it if you race.
Old Apr 29, 2010 | 11:58 AM
  #189
LSCHLEM's Avatar
LSCHLEM
Default Ported 102 really goes.
Wow, Problems. Clutch OK now. Gave the Car A Performance test this morning. Got CEL. PO171 & PO173. Luckily I had my predator with and pulled over to check it out. Cleared the CEL. Then system indicated I was out of gas. LOW FUEL. Gauge was pegged empty. Went to Gas Station and filled. Thing is only took 10 GAL of GAS then it was overflowing. Sounds weird and done A short scan on the way back home. I want to tell you the Car goes like it never did. Tach seems like it wants to go to 10,000 immediately glad the REV Limit is set to 6900.
I may need A tune in spite of the increase from the " PORTED FAST 102.
Old Apr 29, 2010 | 12:44 PM
  #190
Joe_G's Avatar
Joe_G
St. Jude Donor '08
P0171 is normally a vacuum leak....better check the install again..
Old Apr 29, 2010 | 12:54 PM
  #191
LSCHLEM's Avatar
LSCHLEM
Joe that dual gas tank sensor at low fuel The Logic tells me it inhibits wot
or shuts down the fuel injector banks. I guess Ill have to get the schematics out and see. It only did it that one time and the scan on the predator looked good. Ill do A more comprehensive one with my HP TUNERS. The Predator is just A nice tool to have along without dragging the Laptop.
Old Apr 29, 2010 | 01:01 PM
  #192
Joe_G's Avatar
Joe_G
St. Jude Donor '08
I've never heard of that, but I sure don't know everything.
p0171 & p0173 will be accompanied by LTFT's +25 on a scan. Did you see that?
Old Apr 29, 2010 | 01:12 PM
  #193
LSCHLEM's Avatar
LSCHLEM
LtFT's were at -3.45 or something near that with 12.89A/F . Timing was in the 26 Deg area. I did not have the cel's when I did the Scan.
Old Apr 29, 2010 | 01:20 PM
  #194
Joe_G's Avatar
Joe_G
St. Jude Donor '08
You need to scan if and when you get the CEL again. It takes some idling to set the CEL after cleared code but the LTFT's will go up quickly if you have a vacuum leak. Might be as simple as the MAF coming loose from the silicone.
Old Apr 29, 2010 | 03:43 PM
  #195
LSCHLEM's Avatar
LSCHLEM
Definately check it out Joe. Thanks for all your help here. Too good to be true to just install A set of Heads and your off & running. The Car is performing Quite well. This 102 is PORTED and it works. I wish I had it on At G.BERG last week. Who knows what it may have made.
Old Apr 29, 2010 | 09:20 PM
  #196
Joe_G's Avatar
Joe_G
St. Jude Donor '08
You MUST make a return trip soon. Look at all the posts and views you have on this.
Oh did I mention that you need to get the .drf files!! We will be able to really analyize the difference then. Oh the HP tuners scans would be good too.
Old Apr 30, 2010 | 11:58 AM
  #197
All_Motor_C5LS6's Avatar
All_Motor_C5LS6
When can we expect updated numbers with the addition of the ported FAST 102? My guess is 509rwhp 461rwtq with the ported FAST 102
To Trick flow install underway
Old Apr 30, 2010 | 12:03 PM
  #198
All_Motor_C5LS6
I am using TF 225's. They come stock at 65CC and I had them cut to make the Chamber size 59Cc. It did check out well with the rather crude apparatus I used. I now have peace of mind. There is no way of knowing
without checking it. Leon
What' your compression?
Old Apr 30, 2010 | 02:05 PM
  #199
LSCHLEM's Avatar
LSCHLEM
Default Compression ?
Static compression with A Gauge is 230 PSI. On the other hand depending which formula you use average is 11.8:1.
Old May 1, 2010 | 01:13 PM
  #200
LSCHLEM's Avatar
LSCHLEM
Default Dont count the fast 92 out yet.
I know the FAST102 Feels like it has more snap than the PORTED 92
which we all know is overported. I sold the stock heads so I cant show this unless I pull the 102 off which is no big deal 10 MIN and its off, Fuel
rails and everything.
I have some ideas on the 92 which we know has bigger runners. If the
problem area was corrected It may very well run as good or better than
the 102. Im working out A deal with the tuner to do A A/B test and in retrospect at the time of the dyno the swapouts would have been more time consuming and getting everybody nervous. I would like to do this
before moving on to phase of the build.
