Just ordered cam!!!
Old Jun 22, 2010 | 10:56 PM
  #41
tx_zo6's Avatar
tx_zo6
Originally Posted by hungryhippo
I wouldn't want to wait either. I'm going to slap it all on my credit card, haha.
I've done that before and it got me in big trouble. I'm 30 now and I've barely recovered from my spending habits from my early 20's. Now i pay cash, if I don't have the cash then I can't afford it.
Old Jun 22, 2010 | 11:17 PM
  #42
dsp300c's Avatar
dsp300c
ditto
Old Jun 23, 2010 | 02:18 AM
  #43
PRE-Z06's Avatar
PRE-Z06
Well the car is only 4 months old (to me) it was bone stock when I got it and my mods are done as money comes in. I'm a blue collar worker and have to sacrifice a lot to make ends meet while trying to build a fast car. I would like to upgrade the clutch and rear but haven't got to that point yet. If you have any advice or can help as you suggested I'm all ears. Thanks!
I understand the fact that money doesn't grow on trees and am all about the bang for the buck mods...in case you aren't aware the '05 diffs are pretty weak and if you're planning on a sticky tire, which I think you'll need to go 10s even with heads, especially if you don't have z51 gearing...be prepared to need an upgrade, depending on which tires you run will determine what gears...imo a 17" is lighter and a 275/40 is cheapest and is plenty to cut a 1.5x as I know of a few who have done it with a stick Here's a gear calculator to help ya determine what rpm you'll be in when crossing the traps, http://www.f-body.org/gears/
Old Jun 23, 2010 | 02:19 AM
  #44
PRE-Z06's Avatar
PRE-Z06
Originally Posted by dsp300c
ditto
x2!
Old Jun 23, 2010 | 04:30 AM
  #45
SpinMonster's Avatar
SpinMonster
Its not far from what Ls2's do. I wasnt doubting. its just not typical. Your spike at 4600 is from not having it smoothed to '5'. Also most dynos posted report SAE numbers not STD as your pull was in. Im not sure how that affects things but it could explain why the numbers are unusual.
Good luck with the mods.
Old Jun 23, 2010 | 05:37 AM
  #46
venomws7's Avatar
venomws7
I say 465rwhp 420rwtq...
My friend made 445rwhp with Boltons/Fast 92intake and same cam on 01 C5 ZO6.
Old Jun 23, 2010 | 10:04 AM
  #47
tx_zo6's Avatar
tx_zo6
Originally the smoothing was set at 5 and it yielded 398rwhp, I wanted to see 400rwhp so I had them set it at 0.
Old Jun 23, 2010 | 10:23 AM
  #48
All_Motor_C5LS6's Avatar
All_Motor_C5LS6
Yes, that is correct. I will be installing TF 235's inside the next 45 days.
235s are too big for the LS2. You're better off with the 225s
Old Jun 23, 2010 | 12:27 PM
  #49
tx_zo6's Avatar
tx_zo6
Yep, with the cam I'm using I'm looking at the AFR 225's and the PI's...
Old Jun 23, 2010 | 12:51 PM
  #50
dsp300c's Avatar
dsp300c
So u haven't bought heads yet? If so buy tf 225. Not afr.
Old Jun 23, 2010 | 12:58 PM
  #51
tx_zo6's Avatar
tx_zo6
Im gonna consider both, I will make sure I do my research before I buy anything. Thanks for the advice, though.
Old Jun 23, 2010 | 01:20 PM
  #52
dsp300c's Avatar
dsp300c
Np. After my research tf was the way to go. You'll see the same thing. Me, braciole, and Chaz all run tf 225s and all have the fastest ls2 h/c timeslips. Trust me.
Old Jun 23, 2010 | 01:22 PM
  #53
tx_zo6's Avatar
tx_zo6
Np. After my research tf was the way to go. You'll see the same thing. Me, braciole, and Chaz all run tf and all have the fastest ls2 h/c timeslips n
Well then it looks like trickflow is the way to go.
Old Jun 28, 2010 | 12:27 PM
  #54
tx_zo6's Avatar
tx_zo6
Going to the shop tomorrow......dyno vid by friday!!!!
Old Jun 28, 2010 | 03:49 PM
  #55
dsp300c's Avatar
dsp300c
Sweet
Old Jun 28, 2010 | 04:55 PM
  #56
LSCHLEM's Avatar
LSCHLEM
Sweet
Hey, I have Tf's and I dont have any 10 sec time slips ????
Old Jun 28, 2010 | 05:22 PM
  #57
dsp300c's Avatar
dsp300c
Sweet. That's means I don't have to worry about another contender. Lol. Jk. You will get them once you go to the track in cooler weather. Have you been since the heads?
To Just ordered cam!!!
Old Jun 28, 2010 | 05:30 PM
  #58
LSCHLEM's Avatar
LSCHLEM
The Heads are really great. They got me to 500Rw in april. Tried these manifolds out and got the 102 to work. Im making more Hp/TQ maybe 10.
Got clutch stuff to work out but I have good tires
Old Jun 28, 2010 | 05:39 PM
  #59
dsp300c's Avatar
dsp300c
So with 102 in cooler weather what you think you may dyno? My stock clutch never went out. I just replaced it before it needed it bc I don't have a spare car. My vette is my dd.
Old Jun 28, 2010 | 05:51 PM
  #60
LSCHLEM's Avatar
LSCHLEM
Well if I take the APRIL DA as we do in drag racing at 56 Degrees and
apply the gain in HP/TQ that I got in 99 Degree weather. Logically it should reward me with with the same Hp at 56 Degrees + the Gain. I will never Dyno A car in 99 degree weather Again. It's Stupid.
