Well I pulled the trigger on my cam this afternoon! Specs are .647/235 .608/240 111* LSA. It's the Tsunami by Comp. So far the car has a Halltech/Fast 102/American Racing LT's, O/R X-pipe/Corsa Extrmes/Qa1's. The car has made a best of 400rwhp and 409tq on the dyno at Lethal Performance.
I'm shooting for around 450-460rwhp and 420ishtq. We'll find out next Friday!
Well I pulled the trigger on my cam this afternoon! Specs are .647/270 .608/289 111* LSA. It's the Tsunami by Comp. So far the car has a Halltech/Fast 102/American Racing LT's, O/R X-pipe/Corsa Extrmes/Qa1's. The car has made a best of 400rwhp and 409tq on the dyno at Lethal Performance.
That cam is huge. Post some sound clips if you can. Is it an LS2 car? I bet you make over 460.
Just to clarify you posted comps advertised(.006) duration specs the more commonly referred to specs at .050 are 235/240, still a healthy cam and bet you'll see your numbers as it did well in a buddies camaro
Yes, that is correct. I will be installing TF 235's inside the next 45 days.
Ok. Without the heads you Probably will hit your goal of 450-460. With the trickflows you should hit 500. I have the 225's and love them. You will be impressed with trickflows. Keep us posted on the dyno numbers.
