Dropping your C6's drivetrain, Version 4.0
Im guessing this helped me get back in line.
BTW, to the OP, this thread really helped me get things done. It was really informative. I ended up doing a Torque Tube rebuild and a clutch change. Id be happy to help anyone with any ?'s. Im an average Joe, not a pro.
BJK
BJK
I just pulled the extension housing off the trans and cleaned, RTVd, and reinstalled. hasnt leaked in 20k miles since!
Welp, I'm just going to soldier on anyway and drop the torque tube. At the very least, I can upgrade my current slave to the new Z06 one that's sitting in my kitchen. Might as well while I'm down here. I think I might put the car on hold for a few days while I ship in a remote bleeder, too. Not gonna go through this again for no reason.
What is the difference between a base slave and a Z06? With all my engine work, I think my stock clutch won't last much longer so I have a Z06 clutch waiting to go in. I'm debating changing the slave while I'm in there even though the stock one hasn't given me any trouble.
Anybody know of differences b/w stock slave and a Z06 slave in terms on reliability and strength?
Sean
..... I was hoping this wasn't the case. Will get it on a lift and confirm soon.
Even with the guide pins it has a lil slop. Theres no need to scribe though. It really easy to see the shiny aluminum under the bolt to get her lined up. Again im really not sure how critical this really is.
BTW, I ordered a few things from Mike at ECP myself. He really knows his stuff and answered alot of my questions along the way.
Also, can you confirm Slick that there is a gasket between the tranny and diff? Seems as though mine is leaking from the top somewhere.
Attached is the only pic I have, hope it helps
First off; I ordered the GM Service Manuals. The damn things are Pink. Now I know why. Some Lawyer wrote 'em. Between the "see 7-154.06 subsection c paragraph w.631 (in one of the other 4 books) to unplug one wire and the disclaimers "refer to section 4.7333.b-rwe to unhook the battery cable to prevent personal harm"... I damn near went nuts. They do however provide a general guide on what you are looking for if you have fortitude...
As to the pics;
First pic is my Bud Zeus. Just as usless as Slickshoes Bulldog but when he snuggles up to me he doesn't drool (plus he purrs...purring is BIG in our house). This look tells me:"I'm an inside cat but I'll be pullin' for ya'".
Fourth picture is of the "stooge" I made due to the fact that all my friends are airplane guys who declined assistance on "car" work. An old creeper, a jackstand and some Redneck Rubberbands did the trick...
The tranny jack is a $160.00 score from Harbor Freight; an ATV jack that worked great for lifting and stabilizing the tranny/trans/propshaft.
Other observations:
The right rear brake line runs under the diff/tranny so you do need to open the brake system. Don't bother to take the caliper loose. Use of a good rubber plug will limit the flow and not require bleeding the brakes.
GM uses cheap crappy and useless fiberglass (ITCHY) insulation in the tunnel. Near the bellhousing when you go for the bolts attaching the bellhousing to the motor you would be advised to be aware of this crap. Most high end cars went to ceramic insuation years ago. Wear a long sleeved shirt, goggles and gloves and tear this crap out around the clutch bellhousing. When you have the bellhousing bolted back up attach some stick-on insulation from Lowe's, Home Depot, etc...
I dropped the motor (front bolts at the bottom and rear bolts off) an inch or so plus loosening of the motor mount bolts when doing this and had no problems with the intake touching the firewall and could get to the two top bolts of the bellhousing with a bit of persevernce.
For putting her back together I'm going to install the driveshaft/clutch/slave cylinder and then mate the tranny/rearend to that. This way I can test/bleed/work the entire front end (clutch) prior to mounting the tranny/diff.
I'm of the read but verify crowd...
Chris
Here's my question: I'm a capable wrencher, but new to the C6. Assuming the right tools and no major snags, about how long is this process from 1) start to cradle removed and 2) from cradle removed to fully disassembled (meaning trans, diff, and TT removed)? Not including putting the car up on stands
I know times vary based on many factors, but are we talking 2 hours, 8 hours, or 3 days?
Thanks again!
Thanks again!
First time I dropped my drivetrain it took about 6-7 hours but I was very slow and took more apart than I needed to (wheel assemblies, half shafts, etc) for a TT rebuild. Now I can drop everything behind the flywheel in about 3.5 hrs, including the headers. You can separate from the car at the upper control arms, upper shock mounts, 4 cradle bolts and front torque tube bolts to get everything down together. ont forget the clutch line and rear brake lines along with all the electrical connectors...
I would plan on an entire day to drop the drivetrain and then pull everything apart. Take pics along the way, it really helps you to remember how the wires and cables are routed through the cradle.
If you are doint a TT rebuild, it will take another hour or so to get it apart. The 5" snap ring is a real bear to get off.
I havent separated the tranny or diff from the cradle yet, but there isn't much holding it on. Maybe another 30-45 min?
Most importantly, run a search to find other DIY articles with pictures. It's very important to know what you're up against before you start wrenching away. that helped me a ton.
Hope this helps.
Sean
Thanks again!
***** happens...sockets hide, cuts must be mended, beer breaks must be observed...
The only time you're back to a wall is if you need the car for primary transportation or you're in a race setting, otherwise enjoy working on your car and forget about the shop that could do it in 9 hours. Have fun, learn stuff and by all means take pictures and post in the Forum(s).
PS:
It took me two days to remove my drivetrain. I wasn't in a hurry, I did a LOT of the Slick Shoes Siestas
, looked at this wonderful forum for info and bought tools I thought I needed and enjoyed the process.JMPO and YMMV
Chris
That's how long anything should take!
It looks like some of you guys are local to me (So Cal area). Any others who are on the fence and are within driving distance of me, I'd be happy to drop by and help with guidance.
