Installed my lightweight Deka battery
Old Feb 1, 2012 | 11:38 AM
  #41
FloydSummerOf68's Avatar
FloydSummerOf68
It has half the cranking amps of the Deka
Old Feb 1, 2012 | 11:39 AM
  #42
JUIC3D's Avatar
JUIC3D
St. Jude Donor '11-'12-'13-'14
Which in lamens terms means...it can't turn over the relatively high compression LS3?
Old Feb 1, 2012 | 11:44 AM
  #43
FloydSummerOf68
It may be able to turn it over, but I wouldn't trust it for a daily driver. The size and compression of the motor would make it pretty tough for that little guy.
It actually has LESS than half the cranking amps. The Deka is rated at CCA (0 degrees F) and the Braille is rated at CA (32 degrees F). CCA is a tougher test.
It also has twice the reserve capacity of the Braille (in the event of alternator failure)
Old Feb 1, 2012 | 11:45 AM
  #44
JUIC3D's Avatar
JUIC3D
Interesting info. Thanks for sharing Shawn--ETX18L it is
Old Feb 1, 2012 | 11:50 AM
  #45
FloydSummerOf68
The Deka is awesome...even now that I have the blower on the car it has no trouble cranking it up
Old Feb 1, 2012 | 11:53 AM
  #46
JUIC3D's Avatar
JUIC3D
Sounds perfect. I still have the OEM battery in the car and I get the 'no fobs detected' warning about once per week or so. I know I'm on borrowed time with it so it needs to be replaced.
I'm going to swap to smaller rotors/C5 brackets so I can run the GTO spares w/o the adapters too so overall, I should be shaving ~30 lbs off the front end with 15 of that being rotational weight. Woo hoo
Old Feb 1, 2012 | 12:02 PM
  #47
FloydSummerOf68
Are you sure you don't just need to replace the battery in your FOB?
I just recently replaced both of mine.
Old Feb 1, 2012 | 01:23 PM
  #48
JUIC3D's Avatar
JUIC3D
Ya, that was the first thing I did, replace those batteries. I even replaced them twice as I still got the same message after the first time.
It does other 'battery on its way out' things too-the doors won't unlock/open right away when I try and get in, etc..
Old Feb 1, 2012 | 02:14 PM
  #49
FloydSummerOf68
Lol, mine did all of that....all was resolved when I replaced the FOB battery though
Sounds like you definitely need a new battery if your FOBs were recently "re-batteried"
Old Feb 1, 2012 | 02:16 PM
  #50
JUIC3D's Avatar
JUIC3D
Ya, just to be sure, I replaced the fob battery with a new set of batteries a second time around and in fact, I swapped the battery out in the Walmart parking lot after purchasing, and it did the same thing.
Even if my current battery is not 100% dead, it's the original one from 2008 so I know its a good idea to replace it, plus I'll save 17lbs off the front end. Win-win
Old Feb 1, 2012 | 03:25 PM
  #51
LS1LT1's Avatar
LS1LT1
Originally Posted by Justinjor
What are the reasons for not using the 6lb braille battery? I see a relatively small price point difference of $90 vs $150 but you would save an additonal 11lbs off the front end.
Is there some reason that the 6lb braille is no good?
I drive my car at least 3 or more times per week and sometimes I daily drive it--would the 6lb battery be ok for that duty?
http://www.braillebattery.com/index.php/batteries/b106/
I just don't think that's going to be 'enough'. These cars have LOTS of basic drain going on even when parked and it does take a certain 'minimum' of power to fire them up as well, especially after being parked for a few days in a row.
I just don't think the '6 pounder' will cut it.
Old Feb 3, 2012 | 11:36 AM
  #52
mikeCsix's Avatar
mikeCsix
With the Deka having only 300 CCA's, I think what you will find is it will only last half as long as a battery with twice the CCA's, so figure on replacing it in 3 years instead of 6.
Old Feb 3, 2012 | 01:29 PM
  #53
Don 79 TA's Avatar
Don 79 TA
also just becareful with those Gel type batteries
i've broken many of them in my jetskis
they DO NOT like vibrations that well, they break internally
especially those POS Dekka's
although i tend to land hard on my ski, some soft landings have also given me that dreaded click-click as well, let me just say.... not so much fun when your not near the marina, and sucks when you have a full tank of gas too and no start....
i gave up on those type of batteries in the skis
tried all sorts of things (padding wise to help), still had issues
the standard wet cell cheap batteries have turned out better, boy... have i wasted alot of $$
i just say this as a caution because the Dekka's mentioned in some of these posts i have used, and if you are doing some hard racing, just make sure you have something to back you up
some of the dessert racers i have talked to mention the same type of issues, granted these may be more hardcore scenarios and you may not even have a problem
guess anytime you try things, to make sure to investigate
Old Feb 3, 2012 | 02:57 PM
  #54
MP35N's Avatar
MP35N
Default Good Info
Thanks for the warning. I've heard of one forum member going back. Lucky for us that they're not sold by one of our vendors.
Old Feb 7, 2012 | 10:29 PM
  #55
mikeCsix's Avatar
mikeCsix
If you really want to save weight, these folks make a battery that has over 500 CCA's and weighs less than 5 lbs.
http://www.shoraipower.com/c-1-batteries.aspx
Old Feb 7, 2012 | 10:43 PM
  #56
oldmansan's Avatar
oldmansan
St. Jude Donor '09
I have a Shorai in my ZX-10R and it's been flawless. Saved a lot of weight as well. No battery tender required. If my Deka ever needs to be replaced I'd look at the Shorai.
San
Old Feb 8, 2012 | 08:04 AM
  #57
FloydSummerOf68
Lol....that's not a concern.
To Installed my lightweight Deka battery
Old Feb 8, 2012 | 08:08 AM
  #58
el es tu's Avatar
el es tu
Originally Posted by corvet786c
Where to buy this at?
autozone sells them
east penn is the manufacturer the part number ETX18L is the same
Old Feb 8, 2012 | 08:09 AM
  #59
JUIC3D's Avatar
JUIC3D
My deka arrived yesterday and I went to Autozone to pick up the J hooks and other stuff to mount the battery. As I'm looking for the items, what did I see? The whole LINE of Deka batteries right there on the shelves, including the one I just ordered. If I knew Autozone carried them, I would have bought it and avoided the delay in shipping. I paid $90 shipped from Battery Mart. Autozone had it listed for $95.
Lesson learned I suppose.
  #60
JUIC3D's Avatar
JUIC3D
Originally Posted by el es tu
autozone sells them
that would have been helpful to know 3 days ago
