Old Tech vs. New
Old Nov 30, 2011 | 07:22 AM
d48mclain's Avatar
d48mclain
Bill
Just a wild swing with the bat but that may have been Dave Strictland with his “Bad News” 62 Chevy. He was teamed up with Grumpy Jenkins back then and Dave did all the driving. Was the car white? I do know they were from PA.
In 63 they had one of the very first Z11 Impalas which I saw run a 12.27 around 112 mph.
Denny
I remember going to the drags in Northwestern PA back in the early 60s. There was a 62 409 that ran AHRA Superstock with slicks that would turn consistent mid 13s. Then this guy with another 62 409 (with the fastback roof style) showed up from York, PA. I don't remember his name now but he was a big time touring racer and he started turning low 13s and was challenged as violating the rules. After a quick inspection revealed they had a large tool box in the trunk (it took two beefy guys to get it out) he was allowed to run again. His next run netted a 12.9 and a bunch of PO'd competitors. A year or so later a guy in a 64 Hemi Dodge was the top dog but his times never got out of the 12s. All of these cars were set up for drag racing by pro shops that knew what they were doing and were driven by experienced drivers. They met all of the so called stock rules but weren't the same as the day they left the dealership.
Bill
Old Nov 30, 2011 | 08:01 AM
d48mclain's Avatar
d48mclain
My assumption is you’re speaking of the new Ford and Morpar factory drag pack race cars and the new SS class that people like Don Gartlets and Roy Hill race in.
To my knowledge the only enforcement back in the 60’s where I was at was to protest a car and pay a fee to have it torn down. I’m wondering about the qualifications and knowledge of the people actually doing the tear downs and inspections. Martin Mi in the 60’s wasn’t necessary the NHRA Indy finals or Monaco Grand Prix. It was pretty much blue collar factory worker territory with limited track facilities. No special paint on bolts as I watched a couple being torn down not having a clue as to what I was seeing. Tasty hot dogs though as I recall.
Was pretty young and dumb at the time (old n dumb now) so no expert, but in the “stock” category you could push the engines quite a bit. You could port match intake and heads up to 1/8th inch and I’m sure the big boys all did things like decking the block and running thinner head gaskets for more compression. Wonder how “Dyno Don Nickleson” got his Dyno Don name? The stock class at the higher levels really wasn’t very stock at all. There really was quite a bit of work behind the scenes to get the cars to run as fast as they did.
Saw my neighbor go out and buy a half a dozen rocker arm sets keeping only the longest ones and his racing budget was at the low end of the scale for sure.
Denny
Originally Posted by Rebel 1
I also live near a dragstrip and raceway, Bristol. For over 36 years, i have been to Bristol dragway for every event. I have raced on this strip many times and have met nearly all of the big names. Drag racing gets in your blood.
I know of the Stock and pure stock you speak of. Very familiar with it.
Sure there was probably some cheating from some racers back then. For this topic however, i am speaking of Certified Stock.
Pure Stock musclecar drag racing now is just that, Stock. For official numbers they must be Registered Certified Stock. People are taking this very seriously to not only to be the best, but to put to rest many of the rumors and speculation about the old musclecars Performance.There are several in the 12's but quite a few in the 13's.
As stated, for a car to be Certified Stock there can be very little deviation from factory and everything is checked and inspected. As stated, special paint is used to seal key engine bolts. If at any point, the racer has to turn a bolt, an inspector has to re certify the component and mark it.
As for Hot Rod and other magazines posting of mid 13's for the 73-74 SD 455 Trans Am, i was at a BOP event and watched 2 of them running mid 13's stock.
I own a 87 GN that i bought new. I ran a best of 13.85 @99 mph off the showroom floor. Maybe not spectacular now but in '87 a new Vette was running mid 15's.
Old Nov 30, 2011 | 10:17 AM
d48mclain's Avatar
d48mclain
Bill
Just dawned on me that I lied to ya. The Strictland/Jenkins car was "Old Reliable" while Haden Profits car was "Bad News." I'd bet money it was the Strictland/Jenkins car you saw.
See what happens when you don't get your nap.
Denny
Originally Posted by d48mclain
Bill
Denny
Old Nov 30, 2011 | 10:37 AM
66biskwik's Avatar
66biskwik
One interesting point was when I was with a Top Alcohol Dragster team there was a cubic inch limit. Early on they used to pump down to check displacement. They always used to pump down #1 cylinder. It was rumored one racer finally got caught because he was running larger motors by keeping #1 the correct bore and the other 7 larger. Now they random pick the cylinder. This person won a lot of races in the late 80's and early 90's. So why couldn't the stock classes have done the same thing.
Old Nov 30, 2011 | 12:08 PM
musicman2's Avatar
musicman2
Default Stock
Originally Posted by fnsblum
May I start by saying the devil made me open this topic. I am sitting here watching Pass Time on the Speed Channel. I have read a lot of post here about how much faster the new 427 is compared to days gone by. I like new technology but grew up in the days of watching the big blocks duke it out every Friday night. I just watched a 67 Fairlane 500 running AA/S turn 10.10 @ 132. The owner/driver looked old enough to have run it back in 67. He claimed it was as it came from the factory except for some bolt owns like headers and slicks. Also had a full interior. Interesting to say the least. Later! Frank
IN 1963 I bought a NEW--Ford Galaxie--427--425 HP----Bone stock, street tires---Martin Dragway-----15.03--101 mph -- set the car up to run LEGAL A stock-----13.55---108 mph---never won any races--the 409 Chevy's were faster---!! Now own a Vette---LS2 full NA engine---will the 2013-- 650 hp Mustang beat me ??!!
Old Nov 30, 2011 | 12:47 PM
FloydSummerOf68's Avatar
FloydSummerOf68
Unless you have a very healthy amount of mods on that LS2 yes, it should easily pull away from an LS2 vette.
Old Nov 30, 2011 | 01:11 PM
musicman2's Avatar
musicman2
Default Ls2
Is my A6 with---435 rwhp enough ?? MY Vette is 3120# with 1/4 tank
Old Nov 30, 2011 | 01:33 PM
redzone's Avatar
redzone
Originally Posted by wide one
FYI/ I have a friend w/ 2010 Shelby KR put a kenny Bell sc and some suspension modes with MT street radials ran 9.6 at 140 something.
Not bad for a car with power seats, air, and had to have a full cage installed. Guessing the car weighs 38 to 3900 lbs.
I thought we were talking about stock cars. There's Pinto's running in the 9's modded too.
Old Nov 30, 2011 | 01:40 PM
redzone's Avatar
redzone
I highly doubt it.
Old Nov 30, 2011 | 03:36 PM
musicman2's Avatar
musicman2
Default Rwhp
Originally Posted by redzone
I highly doubt it.
So that means--that all the stock C6--ZO6--will be put on the trailer by the 2013 --650 hp Mustang----------YIKES !!!!
Old Nov 30, 2011 | 03:40 PM
FNBADAZ06's Avatar
FNBADAZ06
I doubt that
Old Nov 30, 2011 | 03:50 PM
fnsblum's Avatar
fnsblum
Bill
Denny
I watched the Old Reliable Chevy run a couple times. One was a best out of three with one of the original Ram Chargers at Vineland, NJ. Later! Frank
Old Nov 30, 2011 | 04:03 PM
  #33
Kenny94945's Avatar
Kenny94945
Old timer may not be telling all his secerts.
Certainly rear tire traction compound is required for a 10 second run.
Hidden nitrous perhaps?
Special trans and clutch?
Old Nov 30, 2011 | 04:18 PM
  #34
FloydSummerOf68
I wouldn't be surprised by it beating most stock Z's.
It has a superior power to weight ratio over the Z06 at 5.9lbs/hp verus a Z's ~6.3lbs/hp
Old Nov 30, 2011 | 05:03 PM
  #35
musicman2's Avatar
musicman2
Default H.p.
I agree-----Corvette needs to take their H.P. way UP !!! I talked to the head engineer of Corvette at Carlilse this year & expressed my thoughts on MORE HP for the Vette & also ZO6 with an A6---no comments, other than he said most people have trouble handling the power they have now---I see Chevy is coming with a NEW small block, probably be in the 2014 --C7----I think it's a shame Ford is after G.M. on & off the track---the competition is---the JAPS-- KOREANS-GERMANS---look at the 2012 GTR !!!
Old Nov 30, 2011 | 09:33 PM
  #36
jpee's Avatar
jpee
I don't remember who it was, (might have been Greg Anderson) in NHRA Pro Stock was DQ because the "wrist pins" in his engine were too light...
Talk about "CLOSE INSPECTIONS" they NHRA even weigh the wrist pins, and push rods....
I saw a J/SA (305 ci Camaro 1985 I think) was DQ because the heads didn't meet the cc rule.. the combustion chambers were too small (making more compression)
Its very tough to cheat today in NHRA...
Anyone remember when 2 pro stock driver/owner hid a Nitrous bottle in the oil tank of the dry sump oiling system, and when they heated up the oil the bottle of NO2 exploded....
Old Nov 30, 2011 | 11:34 PM
  #37
Rebel 1's Avatar
Rebel 1
Denny
No, it's going on now. I have been interested in this since 2001.
You can find it on www.purestockdrags.com. There you can also find the section on Certified Stock. If a person wants to race their musclecar, they can find all the info on this site.
There is a strict set of rules the participants have to abide by. The inspectors find one infraction, you're out until it is corrected. You then have to go thru inspection again. The way the car came from the Factory is the way they run with very little deviation. These Pure Stock events are growing larger each year. Been interesting.
It seems some people like to compare musclecars to the ones today. Don't know why. The truth is, these were and still are badass machines and command a High Premium on the market.
Out of All of the Big Block Chevy's i have owned or built, not ONE has had a Single failure. Solid engine for sure.
I know about what you're talking about from the old days. The envelope was pushed pretty far. Seems there was always someone trying to put one over to gain an advantage, rules or no.
I am Very familiar with "Dyno Don, "Grumpy" Jenkins and Sox and Martin. Legends.
Bob
To Old Tech vs. New
Old Dec 1, 2011 | 01:00 AM
  #38
Tommy D's Avatar
Tommy D
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
St. Jude donor in memory of jpee '14
Bob
We ran a 68 Road runner in G/SA optional back in 1970. It held the class record at 13.2xx for a couple of weeks in 70. Our experience in the stock classes, you pretty much knew who was screwing around and what you could get away with. If someone thought you were cheating they put up money for a tear down. That was then.
One of my friends bought Dick Landys 1972 Pro stock body (no engine or trans) which we raced as a C/G car. We ran 9.90s and 150 mph in the mid 70s with it.
That body was acid dipped, the windows were plexiglass, the interior was tin and aluminum, the body was altered (the seam in the rocker panel was moved because the tech inspectors measured the from the seam). There were two large ammo boxes for ballast in the trunk. The front suspension was six cylinder torsion bars with the minimum adjustment and I could go on.
We ran a 426 hemi with almost 45 degrees of timing backed up with a doug nash 5 speed and then a 727 clutch flight.....what a ride
We received a entirely new "education" in racing with that car. You could see all the different items that were tweaked to get by tech. From what we experienced, most of the pro stock racers shall we say "bent the rules"
At the time those cars pushed the limits as tire technology among other things sucked.
Today I can run low 11 second quarter mile times with a mild bold on LS2, remove the drag radials and travel up & down the east coast with the AC on while getting almost 30 MPG and the car can stop & also turn too..... these are the good old days.
Old Dec 1, 2011 | 02:32 AM
  #39
Rebel 1's Avatar
Rebel 1
Impressive Were you ever at Bristol? If so, i was there. Track was IHRA then.
Stock class was like a game back then, someone always pushing for any advantage, right or wrong. Trying to get over on the inspector. Times/Rules have changed quite a bit since.
I wondered what happened to Dick Landys car. There is another good one. Yep i remember some of the "tricks" used years back for the win.
Ah the Elephant! How were you able to run that much timing? Jetted rich? fuel?
I liked the Nash 5-speed. Used in 1 car of mine and for someones car i built.
TF 727 quicker? Auto was for me.
In the middle 70's, i was running a 74 Vega 414 cubic inch (402 + .060) big block w/ Powerglide, tube subframe with 8 point cage and 4.88 12 Bolt. Street and strip car ran low 10's @134 at Bristol. Car was scary fast.
I agree with you that Now is the good ole days. I never would have thought years ago we would be driving the cars available today. Would have been impossible to have built these fuel-sipping missiles we have now.
The LS engines are going in about everything for the last 5 years. They just have So much advantage over the small block, many people are using them instead. Technology marches on.
Bob
Old Dec 1, 2011 | 08:49 AM
  #40
wazslow's Avatar
wazslow
My Turbo Mustang ran 8.17 @ 172mph(race fuel) (8.80's on 93 octane pump gas @ 3570lbs) and I used to drive it on the street all the time. Took the car to dinner, get my hair cut, everywhere... Me and a few friends built the car in my 2 car garage, wasnt anything exotic. Its incredible how much faster you can go today vs 40 years ago.
