Solid Axle Conversion
Old Mar 2, 2023 | 10:11 AM
  #101
skydaman's Avatar
skydaman
Originally Posted by C5 Pete
Not really AWOL…. Just way behind….
taking the car to Fark’s on 3/15 for scaling and alignment.
3/18 is the date with the chassis certification guy.
may rent the track on 3/20 to do some shake down stuff.
Getting close! Do they give you some baseline suspension settings during that alignment?
I've been watching those Kevin Wilson videos to try and get more understanding of what the bar changes actually do.
Old Mar 2, 2023 | 10:15 AM
  #102
C5 Pete's Avatar
C5 Pete
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
Yes, Fark’s will set it up for a good starting place. I think you probably know this, but they are a full on race shop. Fabrication and race day support, is their thing. I’m sure you’ve seen their 5th gen camaro.
I, too, watch Kevin’s videos. I wish he’d put more out.
Old Mar 2, 2023 | 10:32 AM
  #103
skydaman's Avatar
skydaman
Cool, that helps a lot! Yes seen the Camaro many times.
Old Mar 2, 2023 | 10:44 AM
  #104
brandon1566's Avatar
brandon1566
Was this an aluminum frame car or steel? Been wanting to 4 link my z06 but the aluminum frame has been a deturrent
Old Mar 2, 2023 | 11:18 AM
  #105
skydaman's Avatar
skydaman
I would sell the Z06 and pickup a minor wrecked steel car if you are going this route, could make out on that deal and almost fund the whole build.
Old Apr 3, 2023 | 12:27 AM
  #106
bmfvette's Avatar
bmfvette
Welp, the inaugural NMCA Orlando race has come and gone. Been home a week, the car has cooled off and the driver has calmed down... I entered the car in two classes. The main class I run is Street Kings, and to get more seat time, Open Comp. Both are Index classes. Open Comp takes your highest qualifying time and subtracts a 10th of a second and thats your Index, plus your response time is how you stack on the qualifying ladder. There are some badass racers in OC and they know how to cut a tree. For example at Indy last year (last race of the year), there was four .000 on a 500 pro tree and always at least 40 cars. My Index for SK's is 9.50 and in SK's the closest to your Index (without breaking out) is how you stack in the qualifying ladder. So in a perfect world between the two classes you want your Index to be as close to the same so not jumping through hoops cause they run these two classes almost back to back (there actually was two classes (this race) between them), so you barley have time to get back to the staging lanes. OC was 1st up and I managed to cut a .009 light. I didn't change my tune because I knew they would call SK's before I made it back to the lanes so I had to hit the brakes before the strip trying to get close to a 9.60. Think I ran like a 9.70 something because I hit the brakes too soon. 2nd qual I managed a 9.60 which put me at 9.50 for both classes.The air was good all week I was running in the low 9.40's during the test and tunes..(a whole lot to slow a car down). 1st SK round still hitting the brakes managed to run a 9.57. So I was at least on the board for both classes. Long story short, I rode the .009 and the 9.57 through all 3 rounds of qualifying as the car really wasn't liking being hot lapped. That .009 got me 9th on the qual list (there wasn't any .000 but there was two .001's out of 32 cars) tuff crowd.... SK's 9.57 landed me in the 4th spot... I made it to the semi's in SK's and lost to my good friend Cody who ran a 8.75 with a 1 (8.75 index) and I broke out with a 9.47. Cody went on to win SK's and start the defense of his title from last year. In OC I made it to the finals and lost to another good friend on a double break out. I broke out more than he did (9.37). All in all it's a great start to the season. I'm #2 in OC and #3 in SK's. The car and driver did a couple personal best this weekend. My 1st round of OC the guy red lit on me and I let the car eat. Ran a 9.297... pretty strong for a NA non stroked LS3 car. We're off to Rockingham, NC. in 2 weeks for the 2nd race of the season.
Old Apr 3, 2023 | 01:29 PM
  #107
bmfvette's Avatar
bmfvette
Open Comp Finals (Scott managed a perfect light)...
File Type: mov
File Type: mov
Old Apr 3, 2023 | 01:43 PM
  #108
bmfvette's Avatar
bmfvette
Street Kings..
Cody's and my car .
File Type: mov
Old Apr 23, 2023 | 05:17 PM
  #109
skydaman's Avatar
skydaman
Well new 4 link is on the ground, and it’s not terribly heavy! Saved about 130lbs losing the rear frame rails.
Old Apr 23, 2023 | 05:21 PM
  #110
C5 Pete's Avatar
C5 Pete
AMP Racing
Damn!!!
Old Apr 24, 2023 | 09:38 AM
  #111
skydaman's Avatar
skydaman
That was with street wheels as well, drag fronts should save another 35lb or so.
Old Apr 24, 2023 | 04:04 PM
  #112
C5 Pete's Avatar
C5 Pete
AMP Racing
Um, yeh…. I’m gonna need you to give me a run down of your weight loss program…
I’m about 2550 without me in it.
Also, what turbo headers are you using? I may, in the future, change my setup and I’d prefer down/forward vs the up/forward I have now. When I flip mine theyre too wide to fit between the frame rails…. I suppose I could modify the frame rails a bit.
Old Apr 25, 2023 | 10:51 AM
  #113
skydaman's Avatar
skydaman
Well the tube front and rear certainly dropped some pounds. I don't have any interior trim, if I recall you put carpet and things back in. I have two Kirkey seats in mine but otherwise its fairly sparse but still fine to me for cruising around.
I'm currently running some hot rod headers from CPP, they are kinda heavy cast iron center exit chrome plated units that can be used either direction. I've had up and forward and down and forward previously that cleared the frame rails fine, granted I had to ditch the brake booster for the up and forward.
Old May 1, 2023 | 10:58 AM
  #114
skydaman's Avatar
skydaman
Had to redo one of my turbo drains but was great to get the car fired up this weekend. While going over everything and tightening things down, I adjusted the bar angle to a relatively soft 120% A/S for some street testing, and widened the bar spread on the axle that Kevin Wilson says works well for street/no prep. IC appears to be fairly long at about 55" and set pinion angle to 1.5* so we'll see how she goes once this rain stops.
Old May 1, 2023 | 11:18 AM
  #115
C5 Pete's Avatar
C5 Pete
AMP Racing
I do have carpet and interior trim stuff including door panels. Only 1 Kirkey seat though.
You’re about 250lbs lighter than my car…
I gots work to do…
Old May 18, 2023 | 12:17 PM
  #116
skydaman's Avatar
skydaman
Finally got to drive this thing with the new 4 link setup. First test front suspension was way outta wack, so adjusted the front shocks and alignment. Second try damn thing ripped perfectly straight, feels so much better! It certainly does not take a lot of power to make a car this weight feel fast.
Old Jun 25, 2023 | 07:45 PM
  #117
bmfvette's Avatar
bmfvette
Photographer: Brian Hogan
To Solid Axle Conversion
Old Jun 26, 2023 | 10:42 AM
  #118
skydaman's Avatar
skydaman
Looking good!
Old Jul 4, 2023 | 06:12 PM
  #119
bmfvette's Avatar
bmfvette
Thank you sir! Managed to win the "ring" Open Comp Super Bowl Shootout last month at the World Wide Technology Center (STL).
Happy 4th of July! Celebrate the Red, White, and Blue!
By the way... your car gets any lighter... we can attach wings to it!! That's awesome bro!
Old Aug 29, 2023 | 10:34 AM
  #120
4head's Avatar
4head
Did you ever take the car back out?
I'm confused 1.25 60' with 2100lbs and turbos on a 4 link???? You're running 15" wheels too?
