Tech 2 issues/ missing special features
Old Dec 17, 2023 | 10:20 PM
KLJM's Avatar
KLJM
2nd Gear
Originally Posted by TimboC6
I wish I could ... it's literally been a while since I had anything to do with my Tech2 setup. I traded up to a C7 and my scanners are in a drawer in the shop sitting unused for over a year approx.....
so unfortunately I've forgotten the errors/trials etc I went through. Wish I had a better response. I do remember that I read at least 50 articles on slightly different procedures until I stumbled on the one that worked for me.
anyways.... hope you find your solution sooner than later 👍
thanks for the reply. I did get it sorted out good enough on the 32 bit machine so I could do a relearn on the TCCM, which was then primary reason for getting it. Like you said, I had to trial and error a few different install methods others had posted before I got it to work also. Thanks again for all the info that you supplied here as well as to the others who had suggestions as well.
Old Dec 18, 2023 | 12:15 AM
Dano523's Avatar
Dano523
VX tech2win has a glitch.
To get to BCM data menu for BPS relearn (or any other BCM type needs) for 06~12 C6, use 2013 as the year of the car in the tech2 win set up.
Note, If car is 2005, then use 2005.
Anything other module needs for 06~12 c6, just use the correct year when you go into Tech2win they will work as needed.
So North America, mdi1, UBS device with nano plugged in for the 3 pop up screens before you get to the tech2win blue screen, then diag, 2013, passenger car, chev, Y body type, then select the needed part of the car to get you to the BPS relearn selection.
