LT1 forced induction
It took a little while to find this, and you may have to go back a few pages to get a better idea of the context, but this is basically it:
http://ls1tech.com/forums/16947735-post348.html
From this page:
http://ls1tech.com/forums/generation...-block-18.html
Now, I know this is a page where a lot of the information "Bigg_Gunz" is giving is *possibly* false information, but a few of the builders on there believe he's at least knowledgeable enough to be creditable at this point.
Of course, I could be totally wrong and GM does something unexpected and gives us no wiggle room to do mods. I doubt that, though. I'm quite sure that there's PLENTY of room in this motor's tuning so that GM can bolt on a blower without any added cost to the motor and ECM. Less different part numbers = less cost.
personally until these issues are hammered out fi will be out unless your OK with a hacked additional Injection or alky Injection.
Also, they're using this same engine for forced induction, so it has to be ready to make a LOT more power. It's not like any motor GM has ever produced was out of fuel for upgrades stock. Every motor they've came out with had injectors big enough to add power without replacing the injectors. There needs to be wiggle room for bolt-ons. Period.
Because they're not allowing anyone to mod the fuel tables. This engine is basically going to be a bolt-on motor. Based on the fact that it has so many sensors (including EGT sensors), it should be able to self tune for just about anything.
Let me fist say i HOPE I am wrong but there alot of assumptions in the above statements.
Who even has an ECU to hack yet? How do we know that fuel tables cannot be hacked? If fuel tables cannot be editted then how can 1000hp be possible? There are no aftermarket DI injectors available.
So every motor GM came out with had big enough injecocts to add power? So with 2006 and later C6 we can just bolt on a blower and go? We know the answer.
Self tuning isnt the end all of tuning. That doesnt mean that bolt on a blower and let ecu do its thing. How do we even know that itll be in closed loop during PE?
cobb tuning has already cracked the ford focus ST ECU. which has DI and a turbo. the car has only been out since the fall i think.
so as an example, it may be possible to quickly crack the new vette ECU once it becomes available.
though i dont keep up with every car out there, many cars have had ECUs initially considered impossible to crack, the Nissan GTR is probably the best example, only to be cracked eventually.
there are simply too many aftermarket vendors for corvettes for GM to decide to make it impossible to crack the ECU but only time will tell.
the carbon build up on the valves is a well known issue with DI and i've yet to hear of a solid fix for it though some sort up upstream injection would seem to be the answer.
) but I recall the injectors on the DI ecotecs being able to make 500HP without new injectors... That's a big increase over their stock 260HP. (Almost double)
From this page:
One of your links also talked about the tri-lobe fuel pump drive:
The LT1 appears to be far less complex, and lower parts count than a supercharged 4.5L DOHC V8. Or were you thinking of a two cylinder?
The biggest hope for the aftermarket would be for GM to have some high output (supercharged?) version up their sleeve where the parts required to make bigger power (injectors, pump) may become shelf items for those looking to "roll their own."
No measurable forces??? BS! That's like saying it's a perpetual motion machine which we all know defies the First Law of Thermodynamics. Pressure is developed by the pump, a lot of pressure...there has to be some forces somewhere.
The engineers at all auto manufactures have had robust solutions for years, but marketing, legal, accounting/budget, and the brass have nixed all due to added cost and the fact that marketing studies show nearly all buyers will NOT accept an additional maintanance step (heck, most dont even open the hood to check oil between changes, and how long has it been since any manufacturer included a trans fluid dip stick?). The only way is to stop and trap it all before it enters the intake air charge, and almost no "oil catchcans" catch more than 40-70% of the oil present in the crankcase evac vapors. (the RX can is guaranteed to, but look at the internal design and see all the steps the crankcase vapors go through in the RX cans and you can see why so few work well. ALL catch oil, even a beer can, but only a few brands actually catch 80% or more).
Currently most all pretend it is not an issue and when the customer complains about lost power and fuel economy they sell a throttle body cleaning and upper induction treatment that helps, but is temporary and the lossened hard deposits cause verticl scouring on the piston skirts. So aside from a robust aftermarket solution, dont expect much more than what you see on the newer LSA motors addressing the cleanside only (responsible for only a few percent of the ingestion).
) but I recall the injectors on the DI ecotecs being able to make 500HP without new injectors... That's a big increase over their stock 260HP. (Almost double)On the 3.6 v6 GM DI motors we use a progressive methanol injection system and run 100% meth to supplement the fuel above 9-10# of boost (have pushed it to just under 700hp with C16 in the tank, but that wont work on the street). We also do standalone systems where we add an injector rail to the intake manifold and tap into the primary pump (on the camaros & caddilacs we use the ZL1 or CTS-V lift pump) and pull signal from the current coil paks and injectors...but that is a pricey solution and not practical at this time.
What we have had is regional GM rep bring in this past summer (unannounced....no call ahead of time) to have our system installed on both a new 1500 series truck and a 2012 LFX DI camaro, but no official contact (we share data with GM/Ford/Chrysler engineers we have met over the years and they share off the record info back, but nothing official or sanctioned to be released).
Chrysler has resisted going to DI but they will have to follow, and look at the difficulty in cracking the PCM/ECU on the 2011 & 2012 hemi's. (standalone systems are still our best solution when building big boosted late model hemis).
The real hurdle here with DI is marketing demographics. Accurate info will rarely be released pertaining to the intake valve "gunking/coking" issue just as it has been suppressed to date by all the early DI manufacturers. Officially none acknowledge there is an issue, and that wont change IMHO.
I would like to see the tech diagrams as to how they are doing it (none we have had in are like that) as that would be a partial solution....depending on how much fuel is introduced upstream of the ports it could help alot, but that negates the benefits of the DI to some extent then as fuel mixture is in the combustion chamber through the entire intake and compression stroke so you couldn't run as high of compression w/out detonation.
Interesting.
some applications, gasoline direct injection enables a stratified fuel .... and US markets in 2005 with the 3GR-FSE engine found in the Lexus GS 300. ... The range will include some turbocharged derivatives, including the 1.1 L, .... based on a 5.0L V8 engine block but uses E85 cylinder injection and gasoline port injection.
Vital Stats
Engine : 5.0 L., 8-cylinder
Power: 416 hp
Torque: 371 ft-lbs
8-speed All-synchro
Innovative technologies help to maximize efficiency and reduce emissions, including the SFI D-4 fuel injection (direct-to-cylinder injection system wîth secondary port injectors) and the Electronic Throttle Control System wîth intelligence (ETCS-i). Essentially, SFI D-4 integrates two types of fuel injection: A direct-type high-pressure fuel injection system, which provides a cooling effect in the cylinders and enables the high compression ratio (11.8:1) employed to extract maximum energy from the fuel; a set of low-pressure port fuel injectors that help produce a precise burn to optimize power and efficiency under light- and medium-load conditions.
A dual air-intake system uses a primary intake passage for low and medium engine speeds. In the higher engine speed range (above 3,600 rpm), both the primary and secondary passages are opened, helping boost high-rpm power.
With the IS F 5.0-liter V8, Lexus made a leap in valve-control technology wîth the Variable Valve Timing wîth intelligence by an electric motor (VVT-iE). An electric drive motor alters the intake camshaft phasing, which made it possible to expand VVT operational range to lower engine speeds, where engine oil pressure is usually not high enough to operate conventional VVT. The exhaust camshaft uses hydraulically controlled variable valve timing.
A scavenge pump forces oil from the cylinder heads back to the oil pan, ensuring a reliable oil supply even during cornering that exceeds one g. The low-restriction dual-exhaust system terminates in distinctive stacked quad diffusers.
Looks like alot has been implemented from watching the aftermarket.....Lexus & Yamaha always at the lead in technology.
Interesting.
