Rev Match?
Old Jan 22, 2013 | 04:14 PM
  #101
Daekwan06's Avatar
Daekwan06
Originally Posted by keeks2915
Think how many retards would be dead now the way corvettes are driven if they didn't have some of these safety / improvements
What makes you think a Corvette owner is interested in safety/improvements. Clearly all Corvette owners know how to drive the car:
Old Jan 22, 2013 | 04:16 PM
  #102
keeks2915's Avatar
keeks2915
http://www.youtube.com/watch?v=kzlg3oQMze4
Exactly
Old Jan 22, 2013 | 04:18 PM
  #103
jcosta79's Avatar
jcosta79
Originally Posted by SUPERCRUZ
Nissan 370Z has this feature and I believe the driver can turn it off.
Yes. My 370 has it and I love it. It not only rev matches on downshifts, but on upshifts as well.
It is particularly nice when you put the car in neutral and let it coast for a while. The revs die down to idle and you can coast as long as you want, and then just throw it into any (reasonable) gear without trying to figure out the correct revs needed.
You can skip multiple gears (up or down) and get perfectly matched shifts every time.
I like it.
Old Jan 22, 2013 | 04:25 PM
  #104
keeks2915's Avatar
keeks2915
I like it.
Do you have or turn it off every restart or how is it selected/ deselected.
Old Jan 22, 2013 | 04:40 PM
  #105
jcosta79's Avatar
jcosta79
I know if you leave it on, it stays on the next time you start it. I believe the opposite is true; turn it off and it defaults to off the next time you start the car.
Old Jan 22, 2013 | 04:43 PM
  #106
Guibo's Avatar
Guibo
Originally Posted by Subw00er
ABS braking on track = cheating and lame. 'nuf said.
To be clear, I dont have a problem with ABS and I dont have a problem with RM. What I do have a problem with is when they make us use it by default. ABS I dont mind so much because I'll only ever see it when I need it. RM on the other hand I'll see every time I shift, so that will force me to shut it off, which is annoying. I'm not lazy, I'm just a fan of a good user experience.
Actually, what jvp said about different surface coefficients make perfect sense. That was entirely the point behind multiple-channel ABS systems. They give a level of control that no driver could achieve, as each individual wheel can maximize braking performance irrespective of differences in surfaces, as well as changes in vehicle load. Back in the day, R&T did a test of a Mercedes equipped with an ABS cutout switch. The only difference was being able to select whether a computer could determine the maximum braking performance. In just about every case, the ABS stopped shorter than the driver could in threshold braking. And processors nowadays are even faster. Also, go check the road tests of the old Viper before and after it received ABS; huge difference in braking distances there. Basically the same car, same tires, etc.
If all it takes is a tap of the paddle to disengage rev-matching, one could argue that you're somewhat lazy. And unlike ABS, it is something you can defeat. You should hate ABS even more.
The non annoying way they COULD HAVE implemented it would be to only have it activated by default when the car sensed it would be in a situation where the rear end would engine brake enough to lock the rear tires and initiate a spin. For example, you've entered a corner hard, downshift and drop the clutch while turning = instant spin. But for literally every other time, I don't want see, hear or feel it.
But that takes away control of the car by the driver, which is a sin...
I genuinely feel bad for those of you that never really spent the time to learn how to properly integrate with and drive a sports car because there is nothing like it (maybe just motorcycle riding can top the feeling). Its not your fault, its just ignorance; you dont know what you're missing.
You couldn't be any more condescending. Sheesh.
Have you tried it? It sounds like you haven't. There are people who drive quite well, who can heel and toe (even in amateur competition settings), who enjoy using it.
Old Jan 22, 2013 | 04:55 PM
  #107
keeks2915's Avatar
keeks2915
No takers on going back to bias plys like the good old days of performance, man's man, driving?
Old Jan 22, 2013 | 05:15 PM
  #108
Subw00er's Avatar
Subw00er
You can dissect what I'm saying till you turn blue. I'm not being condescending, I really dont think you guys know what I'm talking about and I am not capable of explaining it any better.
You either get what I'm saying, or you dont.
Old Jan 22, 2013 | 05:25 PM
  #109
keeks2915's Avatar
keeks2915
I get it. As long as you can shut it off once and never have to bother with it again you have zero issues.
So, if that ends up the reality you will be another satisfied C7 owner.
Old Jan 22, 2013 | 05:31 PM
  #110
383LPE's Avatar
383LPE
we get it, your against ABS
Old Jan 22, 2013 | 05:52 PM
  #111
Daekwan06's Avatar
Daekwan06
I like it.
But.. But.. But.. all the C6 diehards, who have never driven a C7 by the way, believe that the rev-matching in the C7 will suck. And they absolutely need to turn it off. Forever. Because it sucks that much.
How could they possibly be wrong?
Old Jan 22, 2013 | 06:21 PM
  #112
jimmyb's Avatar
jimmyb
I get it. If you can turn it (rev matching) off ONCE and it never comes on again until YOU turn it on, you're a happy guy!
On the ABS subject, with all respect, you cannot out brake ABS on a track in spite of how good you are (or think you are). ABS was outlawed (along with traction control) in F1 because the feeling was that the cars were getting TOO automated (which they were and are).
Jimmy
Old Jan 22, 2013 | 07:52 PM
  #113
Subw00er's Avatar
Subw00er
LMAO! Actually I was referring to the plight of the sports car enthusiast in an electronic age, but yes, thats pretty much what my problem is!
Well, that and they have to make it pretty, but thats another thread.
BTW, on the topic of ABS I don't think I ever said I didn't want it on my car, I actually said its a good idea on a street car. What I was saying is that I dont use it on the track because I am anti-nanny. Using it on track is basically cheating because it doesn't take any skill, and for all of you who ABS-brake on the track, you're a bunch of weenies! Using it on the street in a panic stop is obviously great!
You cant compare F1 to enjoyable street or track driving because they aren't doing it for fun, they're doing it to make money and that's a whole other ballgame. .01 sec shifts may matter in a race as tight as F1, but on the street in a street-prepped car? Come on give me a break! Even motogp and rally is lame now with sequential shifters and the like. I think they should ban all that technology. Then watching F1 and high paying car racing wouldn't be so boring and a driver would be rewarded for their entire skill set again.
Old Jan 22, 2013 | 08:05 PM
  #114
johnglenntwo's Avatar
johnglenntwo
Did they need it for the 0-60?
Old Jan 23, 2013 | 09:49 AM
  #115
hig4s's Avatar
hig4s
I'm for every high tech improvement a car can have, provided it has an override if I don't want it.
I love the automatic headlight, but they can be turned on or off when I want.
I hate the auto dimming mirror, it never reacts fast enough when some clown pulls in behind me with brights on, and it has no manual override or manual sensitivity adjustment.
As far as rev match, I would probably like it, but wonder if you press the gas and rev the engine too much during shifting does the rev match ignore your input and slow the engine back down?
Old Jan 23, 2013 | 10:32 AM
  #116
Raitzi's Avatar
Raitzi
Well if it does, It will enable shifting flatout.
Old Jan 23, 2013 | 10:59 PM
  #117
1analguy's Avatar
1analguy
Originally Posted by SCM_Crash
I'm not sure you know what a player piano is. A player piano would be better represented by a car that totally drives itself. ARM would be more like a piano that pressed down the sustain peddle automatically instead of you pushing it down with your foot. I happen to be a pianist, and I can tell you your analogy is as wrong as it gets...
I wasn't so much referring to the use of ARM as to the effect it will have on my enjoyment of my car, so I stand by my player piano analogy. For me, ARM removes all of the art and challenge of achieving perfect rev matches without any help. For you, I would think sitting at a player piano would have the same effect, no?
Originally Posted by Kappa
I'd like to mention that Porsche also has this tech on all of the new 991's and Boxsters and BMW has it on both the M5 and M6 manuals.
Porsche does indeed have this feature...on 991s, but unless they have made a mid-first-year running spec change, the manual-transmission-equipped 981s do not, as yet, have it.
Originally Posted by spinkick
So many old guys fear technology, its unreal
Lighten up. "Old guys" have invented most of the technology that seems to make you think you're so special. We just don't use the word "awesome" to describe almost everything that doesn't flat-out suck. We also demand that technology should actually improve our enjoyment of our lives, rather than just changing them for the sake of change...
To Rev Match?
Old Jan 24, 2013 | 12:40 AM
  #118
SouthernSon's Avatar
SouthernSon
The ONLY person that dislikes the ABS while tracking is the person that has put back to back 3 perfect laps of threshold braking. Will the liar that wants to claim that please raise your hand.
Old Jan 24, 2013 | 01:27 AM
  #119
Aaron Keating's Avatar
Aaron Keating
Um. You do know what ABS is actually for right? It's not for panic quick stops. While it helps there, it is actually designed primarily so you can still corner while braking, which also leads to another skill set of trail braking, and throttle leading.
Damn straight I'll use my ABS on a track. I'm not a friggin idiot. I drove a Gen 3 Camaro Pre ABS (85 Camaro). I know precisely how Not Fun that can be. ABS for me. Especially with a car that, just to get a base line decent stock condition cost me 6k. (my C4) Let alone god help me if I get a C7 and throw down 55k. And let's be honest, there's no way in hell anyone is ever going to match the performance of an ABS car on a track, unless either A the car is that much more Hero than their competition, or B there's an absolutely huge disparity in driver skill (ie Non Pro, against a Pro). ABS got banned from F1 because it's too good not because it was some how hindering the driver's ability. For that matter in the Speed GT series that ran for a few years one of the first Nerfs they'd do to a car that was running away from everyone was to take away it's ABS system. The car would sink like a rock through the field for the rest of the season as long as it didn't have ABS and the other cars would. I wonder why that is. Hell I'm not terrible behind a wheel either myself and I can tell there is a world of difference in braking between my ABS C4 and what my Gen 3 Non ABS car had. Immediately. Not "oh you won't notice" no it was definitely apparent. The Gen 3 car was out right Diabolical especially on wet conditions if I had to get really hot and heavy on the brakes compared to what my C4 has going on. I don't even think twice with the C4.
That .01 second is over Every Shift (and that's assuming you nail it perfectly Every Time on your non rev matched car. More likely? You're looking at a .1 difference on average.) Think about that for a moment. Unless you hit it dead perfect every time (yeah right), that's going to add up over a 2.5 mile track, hell that's going to make a pretty big difference in autocrossing. If I'm driving my car fast enough to warrant wanting to hit my marks, then yes not having ABS or Rev Matching would impact my enjoyment.
If having tech at my disposal negatively impacted my enjoyment, then I'd be driving a 60s Musclecramp.. I mean Musclecar. Not a Gen4 and up F Body, a C4, and within the next few years a C7. (assuming I don't just break down and buy a C5 first.)
I'd much rather focus on my line, throttle management, braking points, and where the other cars on the track are than whether or not "am I going to lock up the brakes?" or "am I about to snap my poor car loose on a down shift" Especially when there's clowns on the track that think they're better than they really are who decided that "why yes I can drive without the assists!"
Old Jan 24, 2013 | 01:48 AM
  #120
SCM_Crash's Avatar
SCM_Crash
But you still put the shifter into each gate and YOU still press the clutch and decide what gear at what time.
A player piano doesn't have anything for you to do but hit the on button. Maybe we're arguing semantics but I just don't see how your analogy works if you still have to do a lot of the work. If anything, a fully automatic transmission makes more sense rather than just a manual with ARM.
BTW, I think manually rev-matching is a LOT of the fun of driving a manual as well. I rev-match for many reasons, but these days I've gotten so go at it that it's really second nature and sometimes I catch that super perfect shift that makes me realize I do a lot of rev-matching.
