Corvette's Rival
the c4 to c5 jump was a big deal. I was hoping for a big deal again. The c5 to c6 was such a little move that I felt by now they were able to make the next leap in engineering. They did not. So it has not changed the game. Why then spend the dough?
So everyone who has Ferrari stuff from a dealer (post up the receipts) is a Ferrari owner? That's gold. I don't care about your crap. I want to hear some of your answers to my questions in this thread: If segment timing is so fake, why are there so many independent tests of Porsches within 0-7s of Porsche's claim?
Why did you refer me to a company that makes no claim about providing timing equipment to the Nordschleife (which is effectively a public toll road and has little need for official timing since the F1 track already takes care of timing of VLN races)?
Where is the independent NRing run for the CTS-V?
Where did I say that turbos help low elevation?
The reality of multiple independent tests confirming Porsche's lap times without segmented timing? You think you can end it, yet you keep coming back.
http://www.autoblog.com/2013/02/19/2...-drive-review/
No fangs, no black plastic snap-in vents on every surface, no Camaro-esque tailights. What's to like?
If 40 percent is baffling, 57 in C7 must be mind blowing to anyone outside of C7 section.
And how dare of the ***** to not only trim the weight but also disclose the results. This is totally unacceptable.
All things aside, this is one of the best lines I seen in a car review. Almost as funny as Jeremy Clarkson saying the ZR1 is made of "teeth and jelly".
The problem with what you just mentioned is that upcoming Cayman is more rigid than Porsche's own 911. Now, why would Porsche do this and BS on a cheaper car, not top of the line, uhm, flagship?
If you think the C7 frame really looks like the old one, you ain't much of an engineer of any kind. But then, that seems pretty obvious.
Any changes in shape, thickness and length of beams, among the claims GM makes results in INCREMENTAL improvements, it is the overall open design that dictates the rigidity or lack of such.
Now with the Cayman, in the typical German way, the structure is overbuilt, being based on super rigid FLOORPAN of the boxter that is triangulated through the roof support and further through the stressed aluminum skin. There are considerably more variables here to manipulate to increase rigidity than the chasis of corvette, apparently you either cannot or refuse to understand this part. Is there a purpose to increasing this rigidity? I actually doubt that it will be felt in the real life considering how rigid the original design was. Porsche actually has been conducting rigidity studies over many years, due to its racing angle. Would I doubt Porsche numbers? I do not think so. Would I doubt the real life effects of this accomplishment? I think so, Porsche uses a lot marketing BS, however, their BS has a differernt angle than the one GM cranks out.
Obviously, you have no idea what you are talking about. Stating that a 57% increase in stiffness isn't possible because it is an open frame design is just clear ignorance.
I misunderstand nothing. You have no independent testing (that you insist GM provide) to verify anything and yet don't expect that from Porsche and you keep evading that. You simply choose to promote Porsche and denigrate team Corvette and call them liars.
What's really funny about it is you are picking up Porsche's work now as an argument about what GM has done which make absolutely no sense. Porsche can improve the comparative stiffness of new vs old and GM can do the same. It has nothing to do with how stiff Porsche's frame is to C7's. They each have completely different requirements to deal with.
